Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39)
Old 11-11-2009, 11:29 PM
PatrickW PatrickW is online now
Cars: Volvo 850R 528i 00'
Tail light circuit??
So after seeing the brake light out indicator go on and off for the past few days i decided to investigate and switch some bulbs around and still the problem continues.. I know on the E36 that the actual circuitry inside gets corroded and whatnot but i didnt know if this was the same on the E39 and ifso where should i try and clean it up??
This is the first "problem" my 5er has given me since i got it 8 months ago
Old 11-12-2009, 12:39 AM
cal45fan's Avatar
cal45fan cal45fan is offline
Out and About
Cars: 97 528i 00 ML430
This is the same for E39 as well. Check the contacts for tight fit.
FS:
2003 E39 CELIS Tail lights $250
HAMANN CAPS 65mm O.D. $30
E34 A/C control unit no scartches like new $40
E38 E39 Heater Valve $50
Cruise Control Switch $5
Amber sidemarkers $10
Hood plunger switch $5
OEM Bosch Injectors X6 $50
Intake Air Temp Sensor $10
Read driver side door lock assembly (no actuator) $30
Used (10k miles) Water Pump with metal impeller $20
Fan Clutch $40
Radiator Fan (mechanical) $25
CD Changer from a '99 540i $150
Rear OEM tail lights 1997 (no scratches-pristine) $60
E46 (3 Series) Business Indash CD Player $150
PM me.
PLUS SHIPPING...
Old 11-12-2009, 05:25 AM
NNY528I's Avatar
NNY528I NNY528I is offline
Resident PITA
Cars: '97 528, 65/74 MG
Check your third center mounted brake light.
NNY528i, '97 528i, 156200 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler
BFC OT Lego Club #48
Old 11-12-2009, 09:21 AM
The third brake light works fine, its just the rear passenger side brake light.. all the running lights, turn signals and reverse work just fine.
Sorry if my inital thread didnt make much sense, my roommate was blasting some video of 2 hondas racing while I was trying to write this
Old 11-12-2009, 10:54 AM
Wolfen Wolfen is offline
Cars: BMW 540, 07 cherokee laredo
I had that happen on functioning bulbs. The issue was the filament wire looked rusted. Even though it worked it had a higher current draw and triggered the notice.
So don't just move bulbs around, Inspect them and their filaments, then replace.
First rule of politics - the voters don't decide the election, the counters do.
The appearance of the Law must be upheld, Especially when it's being broken.
Old 11-12-2009, 12:25 PM
mattmartindrift mattmartindrift is offline
Cars: 98 540i6
i suspect the roomate is the problem here.
Old 11-12-2009, 01:12 PM
tmpecus's Avatar
tmpecus tmpecus is offline
Raw and Organic
Cars: 2003 525i
Send a message via AIM to tmpecus
I had this problem about 3 months ago on my passenger side brake light also, but not only was my brake light not working, but either was my turn signal. Check the wire harness for any corrosion or rust. If there is some def clean it with some harness cleaner and a pipe cleaner. My ground prong on the male end was so corroded that it was completely gone, hence why my brake light wasn't working at all. I had to get a new male harness and rewire the ground. Works great now!
Old 11-12-2009, 01:15 PM
alright.. thanks guys!
