| 1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury. |
Thread Tools |
Hey everyone, I searched for some of this stuff but didn't have much luck, so any advice is helpful.
- Sunroof doesn't work, no sound or anything when I press the switch, but the fuse is fine so I'm not sure where else to look. - CEL with o2 sensor code, I plan on replacing it this weekend, but I read that this code can also be triggered by a vacuum leak, any common failure places I should check for vacuum leaks? - Tail light failure on OBC, which isn't actually true, PO messed with pretty much every wire in the car, so I had to put some stuff back together, but now all the lights on both tails work, so how can i clear this? - Possible rear shock mount failure on passenger side, there was no carpet covering that side, and it looks like the rubber top should be about 1/2" lower to sit flush/look right. I haven't checked what the driver's side looks like, haven't had much time to check it out, but my question is, is this a hard fix? I have basic tools, but I don't know if I could handle having to take the whole rear suspension apart. - Heat and A/C don't work. Air blows through really strong, but it's just the temp of the outside air, and actually, air comes through pretty strong even when the heat/ac is off and I have the vents spun to closed. - Pretty much every reading the OBC gives me is wrong, it always says it's negative 35 degrees F, with the F blinking, and always says I'm going 35.1-35.3 MPH. I'm not sure how often the MPG is supposed to change, but it always says ~21, even after I've been on the freeway for 30+ minutes with the in-dash MPG gauge at 28+. - The brake pad sensor light is on, I haven't gotten a chance to take off the wheels and check the pads, but I read that you have to replace the sensors to get rid of the light, and I was unable to find them online. How much do they run and where should I buy them from? - Possibly related to the brake pad sensor light, the steering wheel shakes, sometimes pretty bad, when I'm slowing down. It kind of feels like warped rotor(s), but it seems like the shaking would be faster if that was the problem, so I'm not sure. It's also more severe at seemingly random times than at others, so I don't know what that could mean. Please post if you have insight into any of these little problems, I'd appreciate it. Thanks! I think there was one more problem I was thinking of posting, but now I can't remember it...so there might be more to come ![]() Last edited by DBM10; 11-11-2009 at 01:58 AM.. |
![]() FS: "Hurricane"/Amaretta Cloth Door Panels FS: BBS RC041 (1994 M-Technic Rims) FS: OEM 6-Disc CD Changer FS:BBS Center Caps FS: 4 Toyo RA-1 235/40/17 Tires I can help reset your SRS Airbag light! and change your differential fluid(E36)! and wire your aftermarket headunit! |
| Bookmarks |
| Thread Tools | |
