Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1975 - 1983 (E21)
1975 - 1983 (E21) (1975 - 1983) The original 3 Series. Known for its unique body styling and racing heritage, the E21 3 Series is a light, nimble, tail happy sports sedan with classic late 70's lines offering a connection to the road that few newer cars can match.
Old 11-09-2009, 11:34 PM
M202002 M202002 is offline
Cars: 2.7 E21, 2002, E30's
Volvo 240 gle 4 pot calipers on e21?
Hi, is this the volvo caliper which is used on the brake upgrade for the e21's?
cheers
Old 11-10-2009, 12:23 AM
DrewDude320i's Avatar
DrewDude320i DrewDude320i is offline
Cars: 10 cyl, 1 snail.
I don't see am image, but the 240/242/244 caliers were all the same from about 75 to 1991, just make sure you get the ones for vented rotors, w/o abs. Part numbers are listed in the FAQ thread.
Old 11-10-2009, 01:51 AM
jrcook320's Avatar
jrcook320 jrcook320 is online now
Cars: 81 E21 320i, 99 E46
Send a message via AIM to jrcook320
Andrew, you mean 1975 to 1991.
I'll copy a reply to a PM I just wrote verbatim, maybe I should add this to the DIY?
I assume you've read the diy in the faq thread? It's very thorough on this topic.
According to parts suppliers, calipers off of ANY volvo 200 series car (240, 240 turbo, 242, 244, 245, 264) from 1975 to 1991 with vented rotors will work. Some of the earlier cars used ATE calipers which are interchangable with the girling calipers. Parts suppliers no longer carry the ate calipers so you'll get girlings (more common anyway).
Here's the volvo naming convention:
1975-1979: three digits (in the format 2XY, where X represents the number of cylinders and Y represents the doors: 2 for coupés, 4 for sedans, 5 for station wagons)
1980-1985: trim level letters (the three digits were omitted in North American market)
1986-1993: 240 followed by trim level letters (third digit no longer reflected body style)
The cheapest deal on rebuild calipers I've seen is on rockauto.com.
'81 320i turbo | t25, 931 CIS, 250hp, 13.92@100mph | My e21Legion Page | My E21 Videos |
Old 11-10-2009, 03:48 AM
I just purchased some off a 240, they're for vent discs. I paid 200 for the two.
Old 11-10-2009, 04:13 AM
Yeah, my appologies - I was typign that from my phone and I didn't notice the mistake.
Actually, RockAuto is having a warehouse closeout special right now, where they're selling the right caliper, new (not reman) for like $20, no core charge. Check it out.
Old 11-10-2009, 11:09 AM
pommeree pommeree is offline
Cars: '82 E21 320i
I went to Rockauto out of curiosity and found.
"Wholesaler closeout 30 Day warranty $17.62"
For the Beck-Arnely Remans.
Heck, even if you pay full retail there, Raybestos remans, not loaded, are like $40.
Problem is, none of that's going to fit under my turbines!
Even if I had the wheels, I just finished chopping my brake lines out with a pair of pruning shears!
Ugh! I can't wait to do Volvo calipers!
Eric P.
'82 320i w 209K Mi.
BMWCCA #349298
Old 11-10-2009, 01:00 PM
jrcook320's Avatar
slot the caliper mounts, clearance grind the high points on the outside edges of the caliper and I bet they will fit. They fit under 13" steelies.
Old 11-10-2009, 02:04 PM
IRideFixed IRideFixed is online now
Cars: '81 320I
this is news to me! maybe i will do this instead of just the '77/323 vented swap. i originally planned on doing it but now i like the look of the 13's...
Old 11-10-2009, 04:55 PM
Cars: '82 E21 320i
Ah Josh, you're killing me!
I came within a hair of pulling the trigger on this just now.
However, when I threw the two discount calipers in the "Shopping Cart" I discovered that they were both RH and one was vented and the other *was not*
Even with one on clearance and the other retail w/ core plus shipping, it came to only $120 total!
But I got cold feet.
The devil on one shoulder was saying, "Just do it! You'll never find them this cheap again!"
The angel on my other should was saying, "They don't fit under turbines. And besides, dumbass, you've got 14 projects in queue already."
P.S.
When I do do it, I'm seriously considering getting a set of steelies and having them widened.
I don't know why I like those wheels so much.
Eric P.
'82 320i w 209K Mi.
BMWCCA #349298
Old 11-10-2009, 07:35 PM
What pads do i use if im using the volvo brake upgrade?
Old 11-10-2009, 07:48 PM
P.S.
Huh?
They have them marked which ones are vented and which ones aren't. The discounted one is vented.
Old 11-10-2009, 08:28 PM
jrcook320's Avatar
I bought PBR metal master pads from FCPgroton. I bought all my stuff from there, rockauto may have different options. I don't know of any high performance options but I'm sure they exist. Check with the guys on turbobricks.com.
P.S.
that's weird, I checked that out. $17 for a loaded caliper is outrageous. just get the left side loaded for the $80 and do it. While you're at it, you have the option of NOT slotting the caliper mounts, reversing the side of the mount ears they are mounted to and running 285mm mini cooper rotors. When my rotors are toast and I can justify spending the money this will be my next upgrade. I've only seen it done once and plan to document it well when I get there.
You will have to check for caliper to wheel spoke clearance.
Old 11-10-2009, 08:38 PM
Cars: '82 E21 320i
Originally Posted by DrewDude320i View Post
Huh?
Your point is the same as my point which was: I'm a moron.
I just grabbed the two discounted ones and threw them in the cart before I realized that they were both RH and only one was for vented.
I then looped back, this time actually paying attention ...
picked the right ones ...
and then chickened out.
Ahhhh! Stop it!
Must .... not ... buy ... more ... AWESOME ... STUFF!
(for my Inop. car)
Eric P.
'82 320i w 209K Mi.
BMWCCA #349298
Old 11-10-2009, 08:49 PM
But are they volvo pads or e21 pads i use?
Old 11-10-2009, 10:07 PM
Volvo. After all, the whole point of upgrading the calipers is to get a larger contact patch (amongst other things). Try Hawk HPS.
Old 11-10-2009, 10:14 PM
dhlthr dhlthr is online now
Cars: 79 & 81 323i Baur
I was planning on experimenting with Corrado G60 rotors (280mm) with Mazda RX7 calipers. Picked up calipers cheap so I ordered some Corrado rotors. I was hoping to be home this week to see what it will take for this setup. Work has just asked me to stay in Canada for another week and I'll be gone during Thanksgiving week so it may be a while before I can do a write up to see if I can make the Corrado rotors work with RX7 calipers and can I use the Corrado rotors with my existing volvo calipers.
