Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 11-09-2009, 04:03 PM
cjh20 cjh20 is offline
BMW CCA Member
Cars: 93' 325i E36
Loud noise from the oil pump??
There's a loud rattle/clanking noise coming from the oil pump on my ' 93
325i. The noise on ly gloes away sometime I pulled it out and It's concaved in as if somethings hitting it on the side. I don't know whats making this happen.:think
Old 11-09-2009, 06:15 PM
wendall@cmwerks's Avatar
wendall@cmwerks wendall@cmwerks is offline
Cars: 1994 325is, mazda 3
You pulled out the oil pump?
There is a nut on the front of it that holds the sprocket on. This has been known to come loose in some cases and cause failure. Did you check that?
My cars has modded itself...
Fan Explosion
Hood Emblem Delete
Traction control delete
Auto unlocking doors
window twitch
check coolant
Old 11-09-2009, 08:58 PM
BMW CCA Member
Cars: 93' 325i E36
I haven't checked that yet, but im right on it.
Old 11-09-2009, 10:08 PM
travis325i travis325i is offline
Cars: 92 325i, 06 gsxr 600
Have you ever pulled it apart before or something happened to it to give it a reason to mess up?
92 325i- afe intake, bav auto coils, h&r springs, bav auto chip, bmp shorty headers, track pipe, gen3 knockoff exhaust, evosport pullies, fan delete kit, stewart water pump, bimmerworld silicone intake hose, uuc weighted shift knob, tint, euro tails, clear corners, carbon hood, m3 rear diffuser, europlate (confiscated by the police).
2006 suzuki gsxr-600- jardine gp1 pipe and power commander
Old 11-09-2009, 10:12 PM
BMWMPow3r BMWMPow3r is offline
Cars: bimmer
+1 you will want to thread lock it, make sure there is no oil on the threads or nut.
Old 11-11-2009, 11:24 PM
BMW CCA Member
Cars: 93' 325i E36
Exclamation
There's oil all over the filter and down in the middle of the pump, where the long-ass bolt enters down into and screws. Is this bad? There's also no washer on the bolt and i checked all threw out the pump and the washer is no where to be found?
Old 11-12-2009, 09:25 AM
That's not your oil pump man. Your oil pump is on the bottom of the engine hidden by the oil pan.
That is your oil filter housing. Did you do your last oil change on your own? Did the new oil filter (you did put a new filter in right?) come with a few different sized washers and o-rings?
Are you sure the noise is coming from the oil filter housing? I don't believe there are any moving parts in there. I think you might be hearing vanos noise or lifter tick.
I wouldn't go hog wild with any locktite on the oil filter housing either. Just wanted to throw that out there.
Here is a pic of the oil filter housing showing what parts should be there...
and here is a pic of the oil pump. The nut I was talking about earlier is number 18.
Fan Explosion
Hood Emblem Delete
window twitch
check coolant
Old 11-12-2009, 09:37 AM
jhstealth's Avatar
jhstealth jhstealth is offline
my_nameaintearl
Cars: 97 540i6
I was gonna say how did you know it was the oil pump, its sorta in the middle of the motor and would be hard to pinpoint that. Its also probably not the filter like ^^ said. Its probably a vanos problem or could honestly even be a water pump issue, allot of times it will even make noise up to that area.
VV Will trade for M3!!!
