Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > General BMW Mechanical Help sponsored by RM European Auto Parts
General BMW Mechanical Help sponsored by RM European Auto Parts Do you need help with general mechanical problems or have questions about maintenance procedures? Talk to your friends and RM European Auto Parts.
Old 11-09-2009, 03:41 PM
crazeetowntatto's Avatar
crazeetowntatto crazeetowntatto is offline
fast learner, artist
Cars: 93e36, 600sel w140
Send a message via Yahoo to crazeetowntatto
Post clutch is in now pedal goes to the floor....
i dont know where to start i put in a new clutch and i did everything right no extra bolts and now the pedal goes to the floor and wont engage the clutch to put it into gear.any ideas
wonder what the babies'll
look like..................
Old 11-10-2009, 10:29 PM
philakamrbean philakamrbean is offline
Cars: e30 track rat e36DD
Did you bleed the slave cylinder?
Old 11-10-2009, 11:03 PM
bmwdirtracer's Avatar
bmwdirtracer bmwdirtracer is offline
Cars: E34 535, E28 Racer, Lotus 7 clone
(Which is only really necessary if you undid the hydraulics, which a lot of people do, don't know why.)
Say you did: First, let's try to save you some work. Go make sure the reservoir is full . If it's lower than the blue hose coming off the side of the reservoir, that's air in the system. Push the pedal down and pull it back up about 50 times. If you get anything resembling a normal pedal, go drive the car, it will likely fix itself the rest of the way.
Secon, if that doesn't work: Go under and remove the two slave cylinder bolts, back it out a bit, turn it upside down, and more importantly downside up. Then gravity bleed the system, keeping reservoir full. Reinstall slave in correct position, try it again.
Don't take car down until the pedal works; you may not be done yet.
Chris Powell
Master Auto Tech, at an independent, formerly @ dealer
BMWCCA 274412 SCCA 334928
