Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Forced Induction sponsored by Active Autowerke
Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water.
Active Autowerke
Old 11-09-2009, 11:19 AM
TheJuggernaut TheJuggernaut is online now
Cars: '87 325eS track car, '05 4Runner V8 cruiser
Standalone EMS comparisons
Hi guys,
Before this thread is deleted or totally crapped out, let me say that I've tried searching, extensively, and I've found some threads but I still don't get it. Most threads seem to compare the ecus by features, but the features some have over others are useless to me. I don't need telemetry, traction control or PnP.
I'm all but sold on VEMS and planning to order mine within a week but I can't shake the feeling that I may have regrets. I'm not rich but if I have to save up another few grand for an EMS that is far superior in how it will operate the engine then I'll do it.
The rocket science Bosch systems are out of my league. My upper bound is the Motec, lower bound being VEMS, with things like AEM in the middle.
The setup in question is an S52 which will be receiving a GT35r, with 550-600rwhp as the goal. The car is track only. A major part of the appeal of playing with standalone to me is the tinkering so the more involving the setup, the better - I actually don't want plug and play or any kind of auto-tuning.
So I guess what I desperately want to know is, are there any reasons why VEMS is an inferior engine management ECU, minus any other bells and whistles or setup ease - just its abilities as an EMS.
If someone can point me to a thread that answers these questions, with hard data and not "I personally feel this is better because it costs more and not put together by Hungarians", that's all I need. Otherwise, any input is very welcome.
Thanks a ton in advance!
D
Old 11-09-2009, 11:37 AM
DanR's Avatar
DanR DanR is offline
White Devil
Cars: 2001 540i/6
Send a message via AIM to DanR
Standalones are like politics. Good Luck. Alot of the things with a standalone will be the intangibles. Customer Support, Tuning Support, local tuners.
The best standalone would be the one you have the tuner most comfortable tuning. I wouldn't run anything on an E36 turbo setup that would not run atleast the injection full sequential. Running wasted spark is no big deal as most BMW engines RPM ceiling is pretty low anyway.
I PERSONALLY like Autronic, AEM, Haltech, Pantera EFI in that order.
I am sure VEMS will be perfectly capable. The more you spend the more bells and whistles though, however, I do not think that always equates to a better performing/driving setup.
Daniel Rogers
2001 540i/6
Old 11-09-2009, 11:42 AM
Thanks Dan.
My tuner said he's fine with just about anything. He explicitly said he's tuned a lot of MS and VEMS setups. And VEMS is fully sequential.
What features from the fancier EMSs would lead to better performance? EDIT: sorry, didn't get hooked on my fonix, I misread "I do not think that always..." as "I do think"
Old 11-09-2009, 12:03 PM
techno550 techno550 is offline
Senior Member
Supporting Vendor
Cars: 325is, SE36, 300D
Send a message via AIM to techno550
It isn't necessarily "features" that get you a better running engine, it is often functionality and precision.
Control strategy is important, but most will be speed density or alpha n. Table size does matter as well.
Michael McCoy TRM
Old 11-09-2009, 12:08 PM
Matt Matt is online now
///Marketing
Cars: G650Xmoto
Send a message via AIM to Matt
MIPS are pretty important but good luck getting that info out of ECU manufacturers.
"Anyone can do any amount of work provided it isn't the work he is supposed to be doing at the moment." -Robert Benchley
PM Box is full. Email me.
Old 11-09-2009, 12:09 PM
DTRguy DTRguy is offline
fabricator/welder type
Cars: 90 325is,89 325i24v
Send a message via Yahoo to DTRguy
I am running 034 Motorsport Stg 2c... Not as expensive as most, but has a lot of the features and is pretty user friendly. Check it out here:http://www.034motorsport.com/index.p...ml9qjb027uuus1
My favorite part of these systems as compared to others is that I have never had an issue getting a car started Immediately and driving within minutes of fire. Customer support is very good as well. I'm not the only one on here that has used the system as well. I have experience with Autronic, Wolf, and MS... by far my favorite to deal with is still 034 which is made right here in America... which makes it a lot easier if you do run into an issue.
Dreams To Reality Performance One Lap of America 2010 car build http://forums.bimmerforums.com/forum/showthread.php?t=1268384
Old 11-09-2009, 12:26 PM
DTR: Thanks but I'd rather stick to something with a huge user base with these engines.
Thanks. How does VEMS compare to the more expensive ones in those parameters?
Old 11-09-2009, 12:37 PM
Probably a good idea for a first time installer tuner. I have extensive experience with 034 ECU's... but honestly all ECU's are hooked up the same way, and do basically exactly the same thing. It's the user interface that counts to me. I understand AEM is used extensively and if I weren't an 034 type guy I'd probably use that.
Old 11-09-2009, 12:38 PM
clintjg's Avatar
clintjg clintjg is online now
Is kind of a d1ck.
Cars: '02 36/8, '02 TL1000
I've seen cars run very well on Autronic, but also consider ViPec and PecTel. I think either of the latter are pretty much complete with all the bells and whistles you need without the ad-ins. A respected tuner I know speaks very highly of the both but I have no direct experience with them. Yet.
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: UUC Exhaust w/ custom midsection & High Flow cats, CSL headers, and a fully built, low-compression Supercharged and aftercooled S-54
Driveline: Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob, Euro 6 speed, 3.64 diff w/ 40% LU
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE brake fluid, UUC/Willwood BBK 6f/4r piston, Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe Bushings, Racelogic Traction Control
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: Randy Forbes and then ?
Old 11-09-2009, 12:42 PM
a32guy's Avatar
a32guy a32guy is online now
is boostin' again :)
Cars: E36, E92
Vipec will be my next EMS. I hear they have new models being released shortly...
Old 11-09-2009, 01:06 PM
Senior Member
Supporting Vendor
VEMS, from what i recall, was a big jump forward from MS1, but unless it has been updated, is slower than a MS2.
In processing power the MS1, and things close to it, are pretty slow. That is a reasonable limitation in itself.
The "up" from there can be way up, and largely budget dependent.
Michael McCoy TRM
Old 11-09-2009, 01:23 PM
5mall5nail5's Avatar
5mall5nail5 5mall5nail5 is online now
Smell the Glove
Cars: 3
Send a message via AIM to 5mall5nail5
There's many, many, many options out there. Each and every one has a drawback.
Old 11-09-2009, 01:55 PM
So Live So Live is online now
Cars: 91 325i
Send a message via AIM to So Live
I like my AEM ems. Im using a 30-1050 from a honda. Its basically the same as the AEM universal ems minus the injector drivers but you can run plenty big injectors with out a driver. And i paid $1100 for it. I think its one of the better systems for the money and this box is well proven as the quickest bmws in the country run it. It has a TON of features too.
And you can buy the "plug 'n pin" kit which is the ecu connectors and pins for the honda box.
Good luck with your purchase dude!
-Chris
Old 11-09-2009, 02:13 PM
Smell the Glove
Cars: 3
Does the 1050 need an ignition module?
Old 11-09-2009, 02:36 PM
DanR's Avatar
White Devil
Cars: 2001 540i/6
Pantera EFI = 034.
I ran the Stage IIc on my turbo M3 and liked it.
The 1050 does not have a built in coil driver and will require an ignition box or driver from another car.
Daniel Rogers
2001 540i/6
Old 11-09-2009, 05:42 PM
Cars: 91 325i
Dan got it!
My $30 Nissan ignitor is proven to 500whp on a s50 w/ pump fuel only.
OK so a 30-1050 dosnt have peak and hold injector drivers OR ignition drivers. If thats worth ~$800 to you then so be it. I dont have an issue using high imp injectors and running an ignitor/cdi.
-Chris
Old 11-09-2009, 06:18 PM
SiGmA's Avatar
SiGmA SiGmA is offline
Cars: 93 325iSt, 86 325e
Send a message via AIM to SiGmA Send a message via Yahoo to SiGmA
Oh really? I need to talk to Ray about that before I buy my V88. We should chat Chris.
Old 11-09-2009, 07:28 PM
Cars: 91 325i
Chris is pretty knowledgeable with vipec/ autronic scene. Hes always been super helpful too.
-Chris
Old 11-09-2009, 07:45 PM
Originally Posted by DanR View Post
Pantera EFI = 034.
034 ftw
Old 11-09-2009, 08:56 PM
teamsoy's Avatar
teamsoy teamsoy is online now
Cars: blown 328is
Send a message via AIM to teamsoy
i dont want to thread jack but i am curious about the honda/universal aem ems. reason being is that i thought the only way was the 2k plus mike r set up.
Old 11-09-2009, 09:29 PM
highboostingm3 highboostingm3 is offline
Thick Member
Cars: Turd with wheels
Send a message via AIM to highboostingm3
That's because he is talking about the box only! You have to wire it up yourself. Good luck.
Old 11-09-2009, 10:02 PM
Cars: 91 325i
And figure out how to configure everything!
Mike gives you a start up file and its really plug n play. Cant fuck with that...
-Chris
Old 11-09-2009, 10:04 PM
thespeedfactory's Avatar
thespeedfactory thespeedfactory is offline
SOHC PIMP
Cars: 535i m30 turbo, 325i
I am running Haltech E11v2.
On board 2.5 bar map, built in low z injector drivers, fully sequential injection, can run LSX coils directly for direct fire ignition, full datalogging, and autotune.
If only I had a dyno...
HX55 535i
My turbo is bigger than your turbo
http://s255.photobucket.com/albums/h...espeedfactory/
Old 11-09-2009, 10:07 PM
SiGmA's Avatar
I just talked to Ray Hall, he said this is incorrect, there are no plans for additional models anytime soon. New firmware with lots more features is coming soon, but not new ViPEC models. Just a heads up! I'd love to hear what your friend has to say tho.
Yes, yes he is amazingly helpful! Great guy for sure, he was the final push for me to get a ViPEC.
2.5bar MAP? So you can only run 21.7psi?
Old 11-09-2009, 10:17 PM
teamsoy's Avatar
Cars: blown 328is
I understand the wiring part ect. like with most stand alones. Though I am curious how everything is done and round about running costs.
