| 2006+ (E90, E91, E92, E93) (2006) The quintessential sports sedan is back - and better than ever. With a powerful 255 hp engine featuring Valvetronic technology, a 5-link/5-beam rear suspension, performance and luxury are perfectly blended in a more powerful, more agile sedan. |
Thread Tools |
Fuse for flat tire monitor (FTM)
I have tried resetting the flat tire monitor multiple times after getting a flat fixed without any luck.
By doing a search I found that disconnecting the battery has worked to get the light to go off for others. However, I don't want to lose all the settings I have programmed into the bluetooth, homelink, and seat. I looked at the fuse map and it shows no.24 as the fuse controlling the (_!_) sign for flat tire monitor, but on my fuseblock there is no fuse there. Does anyone know what fuse to pull on a 2006 330i to kill power to the FTM system? Thanks in advance! Found my answer on e90post, and now I feel dumb but on the bright side the annoying FTM light is off. In case anyone is looking for this in the future: http://www.e90post.com/forums/showth...t+tire+monitor 1. Have vehicle running but stopped; 2. Access "computer" by using button #1 on turn indicator stalk (see manual to identify buttons) 3. Scroll to the TPM icon. It also has ">RESET" underneath (the ">" is an arrow or "sideways" triangle; 4. Press button #2 briefly to make the ">" disappear; 5. Then, press button #2 again and hold it until a box with a check mark in it appears after "RESET".
-Brian
2006 Graphite Metallic 330i - Stock for now Last edited by BMC330i; 11-09-2009 at 10:46 PM.. Reason: Automerged Doublepost |
| Bookmarks |
| Thread Tools | |
