| 1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury. |
Thread Tools |
shaving head
how many thousands can you shave off the s52 head b4 piston to valve clearance becomes an issue ?
Just because something doesn't do what you planned it to do doesn't mean it's useless.
- Thomas A. Edison |
From Bentley:
Absolute minimum head height: 5.494 inches Maximum machining limit: .014 inch If more then .012 is machined then you must use a .3mm head gasket
cool deal thanks for the info
no does that differ if you have different cams??? i have a 325i but want to install s50 cams and deck the head for compression bump.
| Bookmarks |
| Thread Tools | |
