Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
Track, Auto-X & Drag Racing sponsored by Bimmerparts.com Discuss "organized" racing, bmw club racing, car set-ups, driving techniques, track tips, events, driving schools, maintenance and more. www.bimmerparts.com.
Old 11-08-2009, 12:19 PM
IWannaBMW's Avatar
IWannaBMW IWannaBMW is online now
Ultimate Breaking Machine
Cars: 325i
Clunking in the back and front after new suspension
So last night at 1 am, we took my car out for a test drive after installing H & R touring cup kit on it from tire rack. Car is very tight, responsive, worth every penny IMO. But when i go over slight bumps it clunks in the back and the front a little. Sounds like something is not tightened up. SO i checked the rear shock mounts, and the bolt was tight, i mean it was turning the rubber bushing under it, so i figured that's good.
As far as the front goes, once we installed the springs we used an impact to tighten the strut bearing nut, we tried putting a little more torque on it once the car was on the ground but it just spun the shock, so we left it alone.
I've read it could be the sway bar links in the back. I dunno about the front. The car got new control arms, bushings, tie rod ends, and sway bar links back in February.
What could it be? Should i get hollow sockets so i can stop the shock from spinning and tighten the bearing nut a little more?
Four Door Mafia # 69 - Vice president
Old 11-09-2009, 12:09 PM
diffsonline's Avatar
diffsonline diffsonline is offline
Supporting Vendor
Diff Builder
Supporting Vendor
Cars: #02 95 M3, 2.9L
you didn't really tighten the struts with an impact gun...right?
Old 11-09-2009, 12:11 PM
kharv kharv is offline
Cars: '87 325 '91 318is
^^ or do you mean torque wrench?
Old 11-09-2009, 01:46 PM
IWannaBMW's Avatar
Cars: 325i
Not tighten them just get them on there good n tight while the strut was off, i didn't torque them to any specific number or anything
Old 11-09-2009, 01:47 PM
Supporting Vendor
Diff Builder
Supporting Vendor
the impact gun will ruin a strut if the gun spins the shaft. What struts also? I know there were some Koni which rattled.
Old 11-09-2009, 09:13 PM
IWannaBMW's Avatar
Cars: 325i
It's a h & r strut that came with the springs. How does it ruin it?
