Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39)
Old 11-07-2009, 01:37 AM
cal45fan's Avatar
cal45fan cal45fan is offline
Out and About
Cars: 97 528i 00 ML430
ATTN: OEM Celis tail owners---Please help
I just bought a pair of original CELIS tails (North American specs). The green circle will help you know if you have the North Amrican specs because it shows 4 LED lights on the side. I need your help in determining the supply voltage for the CELIS lights only. Please....
FS:
2003 E39 CELIS Tail lights $250
HAMANN CAPS 65mm O.D. $30
E34 A/C control unit no scartches like new $40
E38 E39 Heater Valve $50
Cruise Control Switch $5
Amber sidemarkers $10
Hood plunger switch $5
OEM Bosch Injectors X6 $50
Intake Air Temp Sensor $10
Read driver side door lock assembly (no actuator) $30
Used (10k miles) Water Pump with metal impeller $20
Fan Clutch $40
Radiator Fan (mechanical) $25
CD Changer from a '99 540i $150
Rear OEM tail lights 1997 (no scratches-pristine) $60
E46 (3 Series) Business Indash CD Player $150
PM me.
PLUS SHIPPING...
Old 11-07-2009, 09:47 AM
amancuso's Avatar
amancuso amancuso is offline
Who, me?
Cars: 318ti Z3 540i 330i
FYI, the N/A and Euro spec use the same voltage. If it will help you I can see if there is any info on the ballasts that came with my retrofit lights. The only difference between the retro ones and the stock N/A's is the cut out for the side lights (4 LEDS) and a reflector pattern on the side/bottom position. They also wire the brake light in differently to compensate for the different bolt-in position.
No, it's not a 525i
Old 11-07-2009, 10:33 AM
cal45fan's Avatar
Out and About
Please let me know about the ballasts, especially, the voltage. Thanks.
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-07-2009, 12:30 PM
mattmartindrift mattmartindrift is offline
Cars: 98 540i6
could you measure the voltage from the ballast(s) to the LEDs?
Old 11-07-2009, 01:10 PM
cal45fan's Avatar
Out and About
Yes you can. The boxes are not really 'ballasts' but voltage regulators. Just ground the black test lead of your volt meter then find the wire leading to the celis from the connector. Make sure to put your volt meter to 20V DC. Thanks.
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-07-2009, 02:11 PM
rrcompton's Avatar
rrcompton rrcompton is offline
.oOOo.
Cars: 2001 530iA Sport
I wish I had a cheapy MM....my Fluke isnt working and Im not sure why, I checked the fuses and theyre fine? I have to send it in to get them to look at it but I always forget about it.
Also the LEDs have been shipped out so they should be there shortly. Hope you get this figured out.
click my sig pic
Old 11-07-2009, 03:30 PM
cal45fan's Avatar
Out and About
You know what? I went to Wallie World (WalMart) and found a clearance light for RV's and they all have LED's in them, the same thing used on the CELIS which are commonly known as PIRANHA/FLUX LED. Oddly enough, the brand of those lights are Piranha. I will tear into those as a last resort. I just have to figure out how to tear into the resin that they use to secure the resistors, LED's and diodes to get the parts I need.
Anyway, I still need to know the voltage of the CELIS for North American spec tail lights.
I do not understand why folks here are standing on the sidelines and not helping. All the have to do is ground the black lead of their volt meter to the body and then just poke thru the insulation of the wire or the connector itself leading up to the CELIS. Then report back. I'd appreciate it very much.
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-07-2009, 03:44 PM
rrcompton's Avatar
.oOOo.
The ones I sent you are Philips superflux same as the piranhas. Theyre the exact same thing, except Philips is name brand.
http://www.philipslumileds.com/
LOL I cant believe nobody here has a MM but let a noob ask a question about rotors and pads and everyone will chime in about what to use even though its been asked a million and one times.
You think Walmart has them or maybe try Autozone, I know one of those places should have a cheapy MM for around 10 bucks or so. Also radioshack......
click my sig pic
Old 11-07-2009, 03:59 PM
cal45fan's Avatar
Out and About
I have a good MM. I just need to know what the input voltage is on a North American spec CELIS so I can change the resistors and make the European spec accept a direct 12VDC and GET RID of those stupid Hella 'ballasts'.
My God! I am doing this just so people here will not have to buy ballasts that are astronomically expensive when they retrofit their 97-00 E39 with 01-03 tails!
People, throw me a bone. Don't be a mark!
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-07-2009, 04:43 PM
allamer35's Avatar
allamer35 allamer35 is offline
maintenance>drop>wheels
Cars: 01 525i 06/01 95k mi
When I get home Ill get this voltage for you.
Old 11-07-2009, 05:40 PM
SpeedsterBek's Avatar
SpeedsterBek SpeedsterBek is offline
Cars: 97 540iA and 95 525i
I'm in the same boat as you. I have a pair of CELIS tails laying around in basement, just don't have enough time to install them (damn exams).
Anyway I will try to go with a different route. I will be using LCM that came with the lights. Everything came off from 2002 540i, so I thought I might as well swap out LCM since I'll be putting Hella facefilt Xenons and CELIS. Will see how they turn out.
Old 11-07-2009, 06:03 PM
cal45fan's Avatar
Out and About
When you put a new LCM in, you will have to get it re-coded for mileage. The mileage is stored in the LCM and IKE computers (instrument cluster). IF they do not match because of a direct swap, the tamper light will come on and you will have a hell of a hard time registering the car. Just my 2 cents.
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-07-2009, 06:24 PM
Cars: 98 540i6
sorry, I meant "would you" rather than "can you". I know you can.
Old 11-08-2009, 01:09 AM
FP5241's Avatar
FP5241 FP5241 is offline
unce, unce, unce, unce...
Cars: Anthracite E39
Send a message via AIM to FP5241
-2000 528i M-sport-
Old 11-08-2009, 11:39 AM
Cars: 98 540i6
haven't heard this before!
Old 11-08-2009, 11:50 AM
cal45fan's Avatar
Out and About
Well Matt, you better recognize. Some people actually do push through.
FP5241,
I did not know they served popcorn in the sidelines...
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-08-2009, 09:08 PM
amancuso's Avatar
Who, me?
I actually tried to get the numbers for you today, but my crappy digital multimeter from radio shack. It was giving me weird numbers, so i went to get new batteries for it, and zilch! I need to pick up a new meter, then I'll try again.
Turns out I just needed to replace the fuse. Now the reading I got for the CELIS was 10.75 V. It appears that 2 of the wires and a ground go to the "ballast" and one comes out. I measured the one that comes out of the "ballast"
No, it's not a 525i
Old 11-09-2009, 12:33 AM
cal45fan's Avatar
Out and About
As it turns out, the Euro specs (yours) has the 10VDC system courtesy of the 'ballasts'.
The North American Specs has 12VDC.
Note: Those 2 wires, plus ground, that go in your 'ballasts' are the parking light wires for the older (97-00) E39's. Only one wire gets used for the retrofit CELIS. I wonder where the other wire connects to...maybe just a resistor to cancel the bulb out warning.
If I could find out what is inside those ballasts, I can totally replicate it! This will save our fellow members $$$ by not buying the Hella ballasts.
Shoot, if I can build fighter jets, I can build a simple 'ballast'.
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
Old 11-09-2009, 08:52 AM
Cars: 98 540i6
why not just buy an appropriate LED driver, that uses 10-18vDC?
Old 11-09-2009, 03:46 PM
540IForMe's Avatar
540IForMe 540IForMe is offline
Cars: 2000 540i M-sport
Dude, I'm subscribing. I've got this flicker(bulb test I believe, but enough current to light leds when they aren't on). I can probably get rid of the flicker with ballasts.
2000 540i M-sport
1991 Camaro RS LT1/T56 Procharger ATI
"The laws of physics cannot be repealed,
even with ASC+T/DSC" --As stated in the driver's manual.
Old 11-09-2009, 05:02 PM
nickMANDERFIELD's Avatar
nickMANDERFIELD nickMANDERFIELD is offline
i <3 spastic
Cars: E36 (RIP), E39 540
Send a message via AIM to nickMANDERFIELD
i did all this already, make a retrofit kit that isnt from hella, etc, but gave up the project
if you need any help let me know via pm!
Signature Disabled - Check the Signature Rules... Fix your signature FIRST!
Afterwards post in the signature/avatar request thread in the forum suggestions forum.
Old 11-09-2009, 05:05 PM
Cars: 98 540i6
get rid of the flicker by re-programming your LCM for retrofitted LED tail lights.
I watched my LCM get coded last week w /a GT1 and there's a "retrofit" menu for cars that retrofitted HIDs and/or LED (celis) tail lights.
Old 11-09-2009, 09:15 PM
where did you get your LCM coded? Can you pm me the info? Thanks
Old 11-14-2009, 12:55 AM
alexbenz alexbenz is offline
Cars: 98 e320
here's my problem...i have the us spec lights with ballasts installed on a 98 but i'm not sure if it's me but the led's/celis look a little dim but i'll have to check out another 5er to verify...can something like that happen?
Widebody-----W210-----SOLD
www.europrojektz.com
Current line up........e30=sold, bmw e39, lexus es300
Old 11-14-2009, 01:02 AM
cal45fan's Avatar
Out and About
Your CELIS lights are dim because you have US spec tails AND the HELLA 'ballasts' are driving them. The US Spec tails are 12VDC and you are feeding it 10VDC. The 'ballasts' are only for EURO Spec tails. Find you a 01+ E39 and just buy the pigtails for the tail lights and splice them in.
FS:
Fan Clutch $40
PM me.
PLUS SHIPPING...
