Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 11-06-2009, 09:56 AM
boardspinna boardspinna is offline
Cars: 2001 325xi 2007 GSXR 600
Bad left front axle AGAIN...#3
so i noticed a vibration the other day when on the highway or during acceleration, and i thought to myself....NOT AGAIN!!!
when i got home i parked the car and turned the wheel all the way to the right and i did what any man would do, i stuck my fingers right in there. The Boot is torn yet again and not only do i have another bad axle boot for the 3rd time in 8 months BUT i now have a hand full of axle grease.
is it common for these to go out this consistently. I mean 3 times in 8 months....
is there something else that could be making these go bad??
Old 11-06-2009, 10:02 AM
16valex's Avatar
16valex 16valex is offline
Cars: 02 530I, 01 330XI
No that is not common. Try OEM boots next time.
Old 11-06-2009, 10:17 AM
tdz123 tdz123 is online now
Noob
Cars: 330xi, 4runner
Have you lowered your car? Slamming an XI can cause this sort of problem.
Old 11-06-2009, 10:26 AM
danewilson77's Avatar
danewilson77 danewilson77 is offline
Quandt member wannabe
Cars: 01.5 TiAg 325i..134k
No.....not common...
18" Enkei EKM3's w/Khumo ASX's ~ DDM Tuning Coilovers ~ Matte Black Kidneys ~ B&W Hood/Trunk Roundels ~ Smokes All Around With LED Eagle Eyes ~ Bavauto License Frames ~ M-Style Lip ~ Debadged ~ VANOS Rebuild-Done ~ GPS Mount Mod ~ Pillar Mod ~ Custom Trunk Interior~Colgan Nose Bra~Xenon Plate Bulbs~Custom Interior Trim By Feia0303
Old 11-06-2009, 11:33 AM
GCoop GCoop is offline
Cars: E46 325xi
I assume you mean the same boot? If so, then no it is not common for them to fail in such rapidity. Something is going on there. If you are talking about different ones then yes mine all failed within months of each other. (didn't do both sides at once)
Old 11-06-2009, 11:34 AM
Noob
Absent a problem causing a tear (e.g. control arm issue or something similar) a CV boot should last approximately 90k-100k miles.
Old 11-06-2009, 03:50 PM
Critter7r Critter7r is online now
Craziness ensues....
Cars: 2005 325Xi
Not normal. Provided you don't have the car lowered, and if you're using OEM boots, then I'd bet a week's wages you're running over stuff. The boots tend to last 80-100k miles. And now, the OEM boots are supposed to be made out of an even better material, so they're supposed to last even longer.
Do you live (or drive regularly) on a dirt road? Lots of construction near you? (That's a gimmie, I see you're in MI)
Any advice I may give here is - at best - tongue-in-cheek, and just as likely outright offensive. I've been doing this for a long time and I usually have a pretty good idea of that which I speak - but not always. So break out your grain of salt and try to keep up.
Old 11-06-2009, 05:13 PM
nathancarter's Avatar
nathancarter nathancarter is online now
You said 'Member'
BMW CCA Member
Cars: 2002 330i 118k
I don't have an xi, but aren't the front CV joints covered by the splash shield?
Seems like even with gravel and construction debris, the splash shield should deflect practically all of it.
Critter7r, didn't you mention some months ago that overfilling the boot with grease can cause premature failure? There should be enough to cover the joint, but NOT enough to fill the boot... right?
[Edit] After re-reading the whole thread. Are you replacing just the boot and the grease, or are you replacing the joint, or the entire axle? Post #1 kinda implies that you're replacing just the boot and grease. If the joint is already damaged to the point that it's vibrating or clicking, then replacing the boot and grease is not a sufficient repair. Replacing just the boot and grease is only acceptable if you notice the torn boot BEFORE the joint is damaged.
Old 11-06-2009, 05:53 PM
Noob
Inner yes, outer no. Even so, having one fail three times in 8 months is very odd.
Old 11-06-2009, 06:36 PM
bmwdave37 bmwdave37 is offline
What the.....?
Cars: Some
Wait one darn second. A torn cv boot does not cause a vibration. If the axle is driven for a long period of time with a torn boot, and thus no grease, then that will damage the joint and can cause a vibration.
So have you replaced the boot three times, or the axle three times?
Old 11-06-2009, 07:50 PM
shadow4bimmer shadow4bimmer is offline
Cars: 02 325 xi
This is a persistent rumor which is not true. Many people are driving lowered xi's (including me) with no problems. As noted earlier, this type of wear pattern is highly unusual. Assuming you are not using cheap Chinese knock offs, I would look at your installer to check if he is putting them on correctly. I replaced the outers boots at 54k and have never had to replace the inner boots with 72k on them and counting.
Old 11-06-2009, 07:59 PM
Noob
Well first off, having to replace boots at 54k is about 30k to 40k miles earlier than normal, so say what you want.
Also, I said "slammed" not just lowered. My XI is lowered too (but not slammed) with no problems.
Old 11-06-2009, 09:08 PM
Cars: 02 325 xi
Was unaware that you were an expert on the normal date that boots need replacing. How about a cite to an authority other than yourself for when boots normally wear out? Slammed is a meaningless term and just another word for lowered only more than normal, since there is no definition to the term. I know of no one personally or on the forums who has slammed an xi, and have seen no one credibly claim that a drop of any kind damaged their boots.
Old 11-07-2009, 06:19 AM
WHITEXi's Avatar
WHITEXi WHITEXi is offline
Cars: 2002 325xi, 98 acura integra
Sorry to hear about your troubles. I have the same issue but have changed them so often now it wont take more than an hour to change one out lol. I have aftermarket ones in there now and have changed them a few times. If I knew I could get the oem ones rebuilt I would have saved them but I didn't. I would get the oem boots like they say.
I have had mo oem axle fail with a bad cv joint and no torn boot. It gave me the worst vibration to until I changed it.
Cross drilled and slotted rotors, Akebono brake pads, r/c/r tails. Front clears and P46's with V2's, M3 rep spoiler and tint all around.
Old 11-08-2009, 09:00 PM
Noob
Haha "cite to an authority." Clever argument. Doesn't change the fact that you had to replace boots about 30k to 40k earlier than anyone else I've ever heard of, other than people with lowered cars or those who have had other issues (e.g. control arm issues).
Which is it? A "meaningless term" or "another word for lowered only more than normal"?
You lowered your car, you've had early CV boot failure and you won't admit that lowering your car may have been the cause. That you don't know anyone who has claimed "that a drop of any kind damaged their boots" isn't a big surprise. I'm sure they're in denial as well.
Old 11-08-2009, 09:24 PM
16valex's Avatar
I have to agree with TDZ123, those who slamed their XI will face the consequences, and perhaps one of those is shorten the life of outter CV boots.
Old 11-09-2009, 10:02 AM
Im replacing the whole axle... and yes i have H&R sport springs on it...so its lowered about 1.25....underlying cause? And the axles are coming from BavAuto.com
Old 11-09-2009, 10:28 AM
Settle down there bud....
Slammed is not a meaningless term to some of us....
Let's be civil
I do not think the 1.25" drop is the underlying cause.
Last edited by danewilson77; 11-09-2009 at 10:31 AM.. Reason: Automerged Doublepost
Old 11-09-2009, 12:12 PM
16valex's Avatar
Can you check your outter CV boots and see if any kind of wear and tear?
Old 11-09-2009, 02:04 PM
ill let you know later on tonight
Old 11-10-2009, 07:51 PM
the one closest tothe wheel has a small tear in it whcih is leaking grease everywhere...this is how i knew it was bad in the first place
