| 1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury. |
Thread Tools |
CEL light on and can not remove
had cel come on. I read it with a scanner which said spark plug misfire...I replaced plugs and then REMOVED CODES....but can not remove CEL light from dash with my scanner...I took it to shop who now says they tried 4 different scanners underneath dash and on engine outlet and says they can not remove....what now?
stashed in garage: 70TorinoGT/CJ 300hp conv
68 Olds 442 conv 455ci.385hp 68 GTO conv 400RA 1 366hp 68 Coronet RT 440sixpack 430hp DD 01 Sierra step side 270hp Vortec
I've studied the schematics in the Bentley Manual for my E36, but my Manual ends with 1998 models. You should check Bentley for your vehicle.
The CEL is driven directly from the engine computer (DME). If the light is on and you think it shouldn't, then the fault is with the DME; or maybe the wire between DME and lamp has a hard short to ground keeping it always lit. There could also be a short within the Instrument Cluster, but I think that is the least likely cause. Good luck |
Is it possible that it's still misfiring? just my $.02
![]() 1998 328is 5sp Cosmos schwarz Metalic CDV delete urethane LCAB OEM Sachs replacement clutch tranny mounts and shifter bushings Sparco strut brace ASC-T delete blacked out corners, tails and side markers and smoked fogs Apexcone Ellipsoid w/6000K HID angel eyes/smoked Lamin-X Prosport gauges 35% tint all around |
the engine runs perfectly after replacing all plugs..I removed CEL codes and they do not come back. The shop says they could not remove and are only getting a ERROR msg...help please.
| Bookmarks |
| Thread Tools | |
