Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 11-04-2009, 03:07 PM
Kraut.Burner's Avatar
Kraut.Burner Kraut.Burner is online now
the local fuzz
Cars: Several.....
Fuel Leak Found.... Pics inside
Hi there guys, I posted a thread about a really strong fuel smell that was coming from the inside of the cabin. A few responses led me to search under my back seat. Well, looks like I've found the problem; Gas seems to be leaking from one of the hoses.
So, here is the initial damage after taking off the tank covers, nothing too concerning:
But, after closer inspection, the puddle can be found:
But, unlike the other common leaking situations. The leak isn't originating from the two hoses that are clamped in the center of the fuel pump? Its coming from this crimped Blue/Black hose in the upper corner. Every time I give it a flick, gas can be seen dripping out.
another shot:
So, that seems to be the problem on the top side. But I always look around for other relating problems, and I came across some more gas leaking from the bottom of the fuel sending lines that run across the bottom of the car....
Side shot (drivers side looking towards pass.):
another
another
last one:
So my main question would be where should I start. Im really hesitant to take apart the upper hose because its Crimped. Does anyone have any experience with this problem.
Any help is much appreciated
1992 E36- black/black 5spd
1998 K1200RS..... RIP
1974 R75/6
2005 Chevy Tahoe Z71
Old 11-04-2009, 04:19 PM
LockDots84's Avatar
LockDots84 LockDots84 is online now
Interwebs Tough Guy
Cars: '94 325i Vert
Send a message via AIM to LockDots84 Send a message via Skype™ to LockDots84
If it's crimped you really can't take it apart unless you have new crimps and a crimp tool for the new hose. I'd take it off and bring it to a machine shop or autoparts store with a shop and have them make you new hoses.
change that oil!!!
PS3 ID: LockDots
Old 11-05-2009, 01:27 PM
the local fuzz
Cars: Several.....
bump.... anyone know how I might be able to fix the crimped wire?
1974 R75/6
Old 11-05-2009, 02:05 PM
E36 For Life's Avatar
E36 For Life E36 For Life is offline
Cars: e36 i e30 ix e46 xi
Get one from the dealer, don't play games when it comes to fuel leaks.
Old 11-05-2009, 03:24 PM
jijacob's Avatar
jijacob jijacob is offline
sudo make me a sandwich
Cars: 95 325i,SL65 AMG Blk
Send a message via AIM to jijacob Send a message via MSN to jijacob
You could probably jbweld that mofo that would work for at least a little while till you figure out what to do.
Strömung Exhaust // Bilstein Sport/H&R Sport Suspension // Microsuede Interior // 6000k HIDs // Cosmos V2 Intake // Manual ZF Swap // Jim Conforti Chip
Old 11-05-2009, 05:25 PM
the local fuzz
Cars: Several.....
^ thanks for the idea. Looks like I'll be trying this out
1974 R75/6
Old 11-05-2009, 05:39 PM
Do not use jb weld. They make a gas tank repair, but that is for an area that is not under high pressure (on a hot day maybe only 1 or 2 psi). There is only one repair for fuel leaks replacement with oem or better. I have never seen any car come from the factory with jb weld patches and to answer your next question, yes I have used jb weld for repairs before, but only in my high school days and it never lasted long.
Old 11-05-2009, 05:41 PM
E3625i's Avatar
E3625i E3625i is offline
Cars: M5, 325i, ML320
Send a message via AIM to E3625i
I might have the same problem...
E36M3
Old 11-05-2009, 05:56 PM
In your post you said all your lines look good.
Old 11-05-2009, 06:03 PM
110reef's Avatar
110reef 110reef is online now
Verts rule!
Cars: 98 328i vert, 00 For
By the looks of it I would replace it all. Looks like someone previously "rigged" it up and now you are stuck with the results...
- Ken -
Old 11-05-2009, 08:44 PM
the local fuzz
Cars: Several.....
where might I be able to pick this up?
1974 R75/6
Old 11-05-2009, 11:41 PM
Meatball546's Avatar
Meatball546 Meatball546 is offline
Slow children at play
Cars: 1996 328iC
I hate those crimps BMW uses on their hoses....
Anyway, when I had a leak in my power steering hoses running from the reservoir, I initially wanted to tighten down the clamps, but I found they were those crimps. So, I cut them off (it was a bitch to do) and replaced them with normal hose clamps. You could also use a T-clamp. I'd recommend replacing your crimps with real adjustable clamps.
Old 11-06-2009, 02:36 AM
the local fuzz
Cars: Several.....
How do you figure? you must be seeing something I dont... Please elaborate
This ^ might just be the way to go.... Looks like I have another winter project ahead of me
1974 R75/6
Old 11-06-2009, 02:59 AM
Cars: 1996 328iC
If the hoses are cracked or damaged, then you'll probably have to replace them too. I'd definitely go with the hose clamp upgrade.
Old 11-06-2009, 10:32 AM
jijacob's Avatar
I've never seen a car come from the factory 15 years old, either. JB weld works great on radiator holes, which are under more than just 2psi also. Considering the area of the leak, I would be surprised if jb weld didn't solve the problem at least temporarily until he found a replacement part somewhere. And if they have a specific gas tank repair kit, even better!
Old 11-06-2009, 11:05 AM
[QUOTE=jijacob;17839779] JB weld works great on radiator holes
My bad I thought it was a fuel leak.
Old 11-06-2009, 11:46 AM
the local fuzz
Cars: Several.....
it is a fuel leak
1974 R75/6
Old 11-06-2009, 01:26 PM
jijacob's Avatar
Old 11-06-2009, 06:58 PM
darkislight's Avatar
darkislight darkislight is online now
Cars: 92 325i, 95 318ic
Exclamation Take precautions!!!!!!!!
Be very cautious with gas leaks. Do repairs outside away from the house with a fire extiguisher nearby.
As you can see from this thread the mechanic simply wanted to tighten a line but static from his body started a nice fire. He was burnt on his hands and arms.
http://www.bmwquebec.ca/forum/showthread.php?t=4529
darkislight
Old 11-06-2009, 07:53 PM
the local fuzz
Cars: Several.....
1974 R75/6
Old 11-06-2009, 08:31 PM
epmedia's Avatar
epmedia epmedia is online now
E21, E36 Thread Troll
Cars: 78 BMW 320i
That first blue line attached to the rubber does not look proper - may have slipped out abit?
If the blue lines are cracked, or leaking - need to replace them.
If it's just the coupling leaking on the other blue line - should be able to get new orings?
I'm not sure what your lines connect to - but don't even bother with JB Wels on pressurized plastic fuel components, may only last a day, and be worse afterwards.
Some fuel filter kits come with orings for those couplings too. Not sure about yours though.
Robert
'78 320i, 15x7 BBS RS 070, Motorsport additions some time ago - unsure of all it's history.
Still passes CA smog
Old 11-23-2009, 04:58 PM
the local fuzz
Cars: Several.....
Alright guys, reviving this thread for a progress update. Im happy to say that everything's fixed and working the way it should be. No more gas leak, no more fumes in the cabin.
I found out that the crimped tube was part of the line that can be seen here on the far left (underneath car):
It was also routed to the fuel sending unit on the right side of the tank. Thankfully, both ends were attached by screw type clamps, and were easy to remove. This also allowed me to go out to kragen and buy one solid piece of 180psi rated fuel hose (about 2-3ft). I just routed the hose from the fuel sending unit on the right, to where it connected to the fuel rails underneath the car on the left, and bingo!
I have no idea why BMW used the crimped style hose that seemed extremely prone to cracking
Anyways, problem solved for about $20
1974 R75/6
Old 11-23-2009, 10:26 PM
Cars: 1996 328iC
Good job!
Old 11-23-2009, 11:12 PM
95325i5sp 95325i5sp is online now
Cars: 95 325i 5 speed
Robert
to clear it up for anyone searching and finding this thread- the blue line is the vacuum source for the EVAP system, it carries no fuel. it comes from a valve under the intake boot in the engine bay.
Old 11-23-2009, 11:19 PM
the local fuzz
Cars: Several.....
What? If you're talking about the blue line that runs into the crimped tube, you're nuts. When I removed the other side of the line that connected to the right side of the tank, fuel came shooting out under pressure.
The line was constructed in this order:
Black Tube-Crimp-Blue tube-crimp-Black Tube
the blue tube was used i guess for fitment space between the tanks. But I had no trouble fitting a single fuel hose through the middle on top of the tanks
1974 R75/6
