Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums Regionals & Events > Regional Discussions & Events > Southeastern - US sponsored by United BMW Roswell > Georgia sponsored by Harrison Motorsports
Georgia sponsored by Harrison Motorsports For the good 'ole Georgia boys and girls brought to you by Harrison Motorsports.
Old 11-03-2009, 09:43 PM
SixSquared's Avatar
SixSquared SixSquared is offline
Cars: 94 E36
Just to make sure....
I've got an auto shutoff to prevent overheated engines, right? Ie when the engine gets above a certain temp it will automatically shut off?
Old 11-03-2009, 09:44 PM
328iJunkie's Avatar
328iJunkie 328iJunkie is offline
236whp230wtq. TRM tuned
Cars: 98 S52 E36; 87i E30
Send a message via AIM to 328iJunkie
On your E36? No.
Scoring FTW!
E30 Parts!!!!!!!!
Old 11-03-2009, 09:46 PM
SixSquared's Avatar
Cars: 94 E36
... Great.
Old 11-03-2009, 10:09 PM
Matt Matt is online now
///Marketing
Cars: G650Xmoto
Send a message via AIM to Matt
I don't think any cars have that.
Story time?
"Anyone can do any amount of work provided it isn't the work he is supposed to be doing at the moment." -Robert Benchley
PM Box is full. Email me.
Old 11-03-2009, 10:12 PM
s14realm3's Avatar
s14realm3 s14realm3 is offline
Cars: 95 m3,92 325ic M-Tec
yes you do, when your engine MELTS, psiton will lock up, thats your shut down.
Tim Ng
CCA#36497
2006 330ia
1995 M3 BuzznM3
1994 325i track DE car
1992 325ic M-technic
1991 M3 classic
Old 11-03-2009, 10:22 PM
Mr Estoril Mr Estoril is offline
Cars: 1999 M3
How far into the red did it go?
/// 99 M3 Coupe
Old 11-03-2009, 10:25 PM
JordanMD88's Avatar
JordanMD88 JordanMD88 is offline
Senior Member
Supporting Vendor
Cars: TRM Turbo 2.8L
:facepalm
I know a great shop not too far from Athens
Racersmarket.net
SixSquared's Avatar
Cars: 94 E36
Not far. It starts right up, just doesn't stay on I'll fiddle with it in the AM
Old 11-03-2009, 11:23 PM
328iJunkie's Avatar
coolant/oil mixture?
Scoring FTW!
E30 Parts!!!!!!!!
Old 11-03-2009, 11:34 PM
SixSquared's Avatar
Cars: 94 E36
I really haven't looked too much since it's dark out. I'll check it out first thing in the AM and report my findings.
Old 11-03-2009, 11:40 PM
Simon Tibbett Simon Tibbett is offline
simontibbett.weebly.com
Cars: E30 325ES, E39 528I
Eh if it starts right up and shuts right off it's usually an easy fix.
But yeah what car shuts off when it overheats?
Future SCCA ITA
Old 11-03-2009, 11:48 PM
SixSquared's Avatar
Cars: 94 E36
Quite a few mid-high end cars have a shut off when the engine temps climb above a set point. It's a feature found in newer cars, generally 2003ish and up, but I thought that maybe BMW was ahead of the curve on it lol. It's starting to trickle down to be a pretty standard feature as far as I know. My mother's 2010 Nissan Cube shuts off when it gets too hot or if the coolant level gets too low.
Old 11-03-2009, 11:54 PM
Oh ok, never heard of it, yeah, BMW's aren't high end cars, they don't have that. lol
Future SCCA ITA
Old 11-03-2009, 11:59 PM
SixSquared's Avatar
Cars: 94 E36
well they're high-er endish lol.
Old 11-04-2009, 12:28 AM
JeremyDS JeremyDS is offline
Cars: '07 335i
Having a car shut off at any point in time because the temperature is too high is a huge safety risk. Imagine what would happen on the highway if your car just turned off- it would not only rob you of engine power, but also power steering, brakes, etc..
Newer cars will trigger a limp mode when they overheat, an attempt to protect the engine while limiting the danger to the customer.
Old 11-04-2009, 12:34 AM
SixSquared's Avatar
Cars: 94 E36
^^That's more or less what I was talking about. According to the guy who sold my mom her Cube, the car will enter limp mode and then will shut off after a warning period.
Old 11-04-2009, 01:00 AM
///Marketing
Cars: G650Xmoto
What he said.
Priority #1 is to protect the catalyst since it has a longer warranty than the motor.
Old 11-04-2009, 07:16 AM
Doctor Wha Doctor Wha is offline
Eh?
Cars: Yes
The Z4s had that function (as many found out the hard way before the ignition coil recall that afeccted the very early model years). I believe BMWs from around that time and since have a similar precaution in their programs.
Similar to what's been mentioned, however, I've never heard of a car (BMW or otherwise) just shutting itself off, though.
Good luck, OP.
Old 11-04-2009, 09:28 AM
M3forJTB's Avatar
M3forJTB M3forJTB is offline
s52 Bent Rod Club Member
Cars: '03 330i '90 332is
Send a message via AIM to M3forJTB
They ought to put a water/coolant temp guage in these darn things
Movin' on to bigger and faster BMWs
Old 11-04-2009, 09:30 AM
///M3Mike ///M3Mike is offline
Cars: 05 M3, 91 318is
Damn near every Volkswagen made after 1999 had this feature. Except it was totally random and had nothing to do with the engine temperature. Or anything else.
Old 11-04-2009, 09:59 AM
What, limp mode? EVERY car has limp mode, old Civics from the 80's have limp mode.
Future SCCA ITA
Old 11-04-2009, 10:10 AM
///Marketing
Cars: G650Xmoto
Actually, they have dozens of different limp modes for different errors.
For example, if you have a MAF error, there is a backup table used to calculate mass flow from RPM and throttle position. Or if you have a speed signal error, your RPM limit will drop to the RPM that would give you your max allowable speed in top gear. If you have a lambda heater error, your fuel trims will be locked to 0. Etc etc.
Old 11-04-2009, 10:21 AM
Steve528's Avatar
Steve528 Steve528 is offline
Cars: 97 528i
N54 = Limp Mode extravaganza
Tsw Volcano Staggered 19's, H&R and Bilsteins,
M5 Rear sway, Ceramics and cross drilled Rotors, Supersprint Rear, Kelleners Pully Kit,
M50 Manifold,
The ghetto cut out of the intake silencer CAI, Shark (soon to be replaced by AA for manifold),
Hamann Rear roof spoiler,
Hella Euros, Dice and XM
5 for 5
Old 11-04-2009, 10:25 AM
mpower5266's Avatar
mpower5266 mpower5266 is online now
Cars: 97 740i, 74 2002
Send a message via AIM to mpower5266
Old 11-04-2009, 10:27 AM
SixSquared's Avatar
Cars: 94 E36
Ok findings for the morning...
Upper rad hose popped off rad... Rectified.
Little to no coolant... Rectified.
Oil low, very thick... Being rectified later with an oil change.
No signs of water or cloudiness in oil. I think the spot where the hose connects to the radiator has been broken on the radiator side... It comes out further on too than on bottom. The hose itself is intact and pretty new. Clamped it back on and ensured tight fit. White spray above engine and around bay, looks like coolant. Car turns on and stays on like nothing ever happened.
Just out of curiosity, could the shutoff be something to do with the trans? It was sluggish shifting gears up and down last night and I think maybe the reason it was losing lpower coming up the hill was maybe bc it was in the wrong gear?
