| Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water. |
Thread Tools |
Mods please close
ITB's!
![]() Dreams To Reality Performance One Lap of America 2010 car build http://forums.bimmerforums.com/forum/showthread.php?t=1268384 |
The plenum is from a RB26. I will have nearly 10" of runners at 2.25 ID. Should make some descent adds to the torque numbers. Willalso be running a 90mm Q45 TB.
Total cost all done will be about $580 including powdercoating. Should be pushing 2 bar again by Nov 15 with new O-ringed block (maybe, but I have the tools and materials in case) and SCE copper gasket with compression rings. My nitrous will be here by the end of the month for a 100 shot down low in the RPM's until the HX55 spools and my meth up top to keep the temps down.
when i read stuff like this, it seriously makes me ![]() You guys take this stuff so lightly lol. This type of work blows my mind away. BEST of luck man! really cant wait to see more progress!! and those HK55`s are HUGE!!! should be some insane power out of that tractor motor ![]() ![]()
I hope it works out for you. Im interested to see the finished product.
![]() You know you love rock climbing: Walltopia USA Widebody Turbo Build "A realist in a world of dreamers" |
That is the beauty of this mani. I am not too concerned with Uber high boost as this is a dedicated drag car that is raced on only 150 meters.
I have felt my performance with 26 psi, no traction, open diff, OEM manifold, and auto slushbox. I am now running 26 psi, LSD, drag slicks, and 5 speed. I need to ditch the OEM intake. With 4.27 LSD my top speed is about 90 MPH. I am looking for max power/performance in the 150 meter. THe good thing about the mani design is that the runners are only bent at the last 2 inches near the head. We can literally tune this manifold for best performance by removing 1/2 inch cross sections at a time on each runner and TIG back together. THe plenum should be sized appropriatly as it works great for a twin cam 2.8. We will be playing with runner length. The jig is mounted on threaded rod and can be adjusted to any length. As it sits in the pic it is setup for 12" of runner material. I only have slightly less that 8" available stock. Xatlas What runner lentgth do you expect that would give the best results? I can easily trim down to any length.
Have you USA guys ever thought about using the S50B30/B32 airbox. It seemst to be highly effective when it comest to Forced induction.
Im not sure how easy it is to fit to the single throttle body application of the M5x (usa S-motor) though, but It might be a good starting point ![]()
1995 E36 M3 GT #111
-370mm Carbon-Ceramic disks / 8 Piston Brembo calipers / Steel brake:lines -H&R Clubsport Coilovers / H&R adjustable sway bars F/R / Intrax adjustable camber/caster plates / Powerflex bushes Front/Rear -BBS 18x8.5 +CUP 235F/265R:Stock 5speed and S2.65 from a Diesel -Scorpion Exhaust / SuperSprint De-cat: 5puck clutch, OEM ECU. -OEM Cabrio X-brace:Recaro PP seats:Momo Corsa weel:Heigo halfcage, Schroth 4points -Forged pistonsa (CP) 8.5:1 / Forged conrods / coated bearings / ARP / Cometic MLS -Twin Turbo Garrett GT2252 / Custom tubular manifolds (ceramic coated) 470hp @ 12psi Last edited by GT110; 11-03-2009 at 06:15 AM.. |
Most BMWs have a distance of about 3.5" from the center of the intake valve head to the edge of the intake port. 13.5" is shorter than both the S50B32 and S54B32 total intake lengths.
Just measured my runners on my OEM manifold. ~16 inches
With the RB26 plenum larger than OEM (by nearly 3 times) and considerably shorter runners (all done I will most likely have around 9" from head to plenum) I hope to see quite an increase over my previous setup. I will have more pics in about 8 hours. I am going to work on it in about 2 hrs from now.
Moar pics
Total runner length is ~9.5". OEM is 16" Standard 2JZ (3.0L) short runner intake manifold is about 6" for max power at ~7500-8000. I am looking for max power at 5500-6000. Still in progress...
That plenum should be good for a decent amount of top end HP... I usually aim for 125% of engine Volume inside the plenum for a better spread of power. Closer to 100% of engine volume I believe gives less lower end midrange and more top. Have you checked the volume to see about where it is? Just my .02 Looking good though!
Kevin, thanks for that info. I'd like to see a graph ( ) of how your manifold measures up, but from the videos it performs as ordered!
![]() 2008-2009 Turbo/Motor Build Thread - 382whp/402wtq & 12.8@116.6 | 105k M52 Engine Part Out - LOTS OF PARTS! | S52 Engine Parts For Sale
Has anyone discussed plenum volume? RB26, M30B35.
Yes it was mentioned by Kevin. He was saying you should have 100-125% of motor displacement in manifold volume, so that is 3.5~4L correct? That manifold looks vastly smaller than two two-liter bottles.
Its deceiving comparing it to 2 2L bottles. But, you're about right. The issue I think is that the manifold may have 4L of volume considering the plenum + 6 runners, but its not manifold volume you want, its plenum volume.
Ah yes, I used a poor choice of words. I meant plenum volume, not total manifold volume. My bad.
| Bookmarks |
| Thread Tools | |
