Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39)
Old 11-02-2009, 02:50 PM
cmhoward cmhoward is offline
Cars: '00 M Roadster, '01
Please help me diagnose strange fluid build-up
Hey guys, can you please help me diagnose why there is a fluid building up inside my engine bay and in the front left wheel well? I believe that I might have a brake fluid leak, but I'm not sure. All I know is that there is a fluid building up at the tip of the blue arrow in the picture, underneath that silver cylinder thing in the picture (which I am guessing is the brake fluid pump??).
By the way, my car is not actually pink. This is just the only clear picture I could find online of an E39 4.4V8 motor from a 540i.
Thanks in advance!
Here's the photo:
http://9103418493786630949-a-greenbl...attredirects=0
Old 11-02-2009, 03:30 PM
mattmartindrift mattmartindrift is offline
Cars: 98 540i6
that's your oil filter housing.
Let me guess: you recently had the oil changed and they used an STP filter, or pinched the new o-ring.
other possibilities:
- loose oil-filter housing cap
- cracked oil-filter housing
- failing oil hose
Old 11-02-2009, 04:10 PM
jamesdc4's Avatar
jamesdc4 jamesdc4 is offline
Rogue Moderator ಠಠ
Cars: 98 540iA (Prd 11/97)
Welcome to Bimmerforums.
Matt is right about the possibility of the housing leaking because of a bad or pinched O ring. Check and see if you can locate the exact source of the leak.
Is the fluid coming from where the cap threads into the housing or are the hose connections underneath the housing leaking?
E39 Ugly Mugs________________________________Registry Photos
Old 11-02-2009, 04:28 PM
f355spider's Avatar
f355spider f355spider is offline
Cars: 2001 540 M-Sport (cdn)
Oil pressure sensor can also start leaking too, it is threaded into the base of oil filter housing. But like the others, check the cap. Remove it, make sure the o-ring is properly seated and tighten it up. If it still leaks, get a new o-ring from the dealer, that is about the only place to get them individually.
Other possibilities:
1) Cracked plastic oil filter cap.
2) Leaking oil hoses, or where the hoses meet the oil filter housing (replace the o-rings on each hose fitting)
You need to examine everything closely with the engine running to find the leak.
2001 540 M-Sport (cdn), Bilstein B14 PSS coilovers, M5 rear stabilizer bar, Dinan Stage 1 software, M-Audio subs, factory bluetooth intergration, SS brake lines, Porterfield R4S brake pads, Brembo oem rotors.
Old 11-02-2009, 04:41 PM
Wow, thanks very much guys! Yes, I did recently have the oil changed, at Mr. Lube, so who knows whether the tech was careful with the O ring. The leak appears to be coming from where the oil hoses meet the oil filter housing, but I'll check everything.
And here I thought that oil filter housing was for brake fluid. Oops... :-)
Thank you very much for your help!
Old 11-02-2009, 07:05 PM
Cantesanu's Avatar
Cantesanu Cantesanu is offline
Cars: 2002 BMW 525i
Did the "Mr. Lube" guy used synthetic oil? Need to make sure you get a good quality filter and fully synthetic oil...like Mobil 1
Old 11-02-2009, 09:15 PM
f355spider's Avatar
Those "Mr. Lube" places seem really snarky to me...like the other guy asked, find out what brand oil filter they used...if it was not Mahle, Mann or Hegnst, then most likely the problem is with the o-ring. All the other brand filters use mis-matched o-ring sizes that don't fit properly. Always use the above mentioned filters only. I too wonder what brand/type oil they used too...there is a reason oil changes cost more at The BMW Store and Jessel.
