Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1988 - 1996 (E34)
Old 10-29-2009, 11:54 PM
TGreene TGreene is offline
Cars: 1989 535i
Dinan Sway Bar - same bushings as a normal front sway bar?
I bought a front Dinan sway bar from a member here because it was cheap, I hate body roll, and for me, over-steer equates to +50hp.
I want to install it with the other members at the Raleigh meet on the 7th, so I figured I would get some new sway bushings, as mine is most likely original after 183k miles.
Do I just get the normal sway bar bushings, or do they have to be different?
Thanks, (I did search first, btw)
Trevor
Fighting soccer moms and punting deer since 1989.
Old 10-30-2009, 12:48 AM
ArnZ's Avatar
ArnZ ArnZ is offline
Cars: 88' e34 535i Executive, RIP e21 323i
If the swaybar is thicker then your gonna need bushings to suit.
Old 10-30-2009, 12:52 AM
moroza's Avatar
moroza moroza is offline
¡Vivan los churros!
BMW CCA Member
Cars: Janky pink truck
Send a message via AIM to moroza
You installed a thicker (presumably) front bar to get more oversteer?
Unless it's just 1mm or so, you will need different bushings.
Old 10-30-2009, 12:55 AM
GarrettSR5's Avatar
GarrettSR5 GarrettSR5 is offline
I hate you.
Cars: E34 6spd, Impulse RS
Send a message via AIM to GarrettSR5
You're gonna need a bigger boat
Originally Posted by The5Guy View Post
Garrett; From my days of lurking here sourcing information, to my first post, to the day I bought my car; every one of your posts has shown you to be an arse.
You, sir, are the first person I have ever encountered that makes me embarrassed to be from Boston.
I may be an elitist, a snob, and a complete jerk at times; but you take the cake on being an arsehole daily.
Good to know I inspire
Old 10-30-2009, 03:36 AM
PetesHelga PetesHelga is offline
Straight-Six Heaven
Cars: 91 535i/5, 86 325e/5
Buy polyurethane bushings at powerflexusa.com and they have bushings in different sizes to match your sway bar thickness.
go here
If they don't have bushings of your size you can porbably find them at dinan's website. Nevermind, I just did that and found that the front bar is 25mm so you can buy the busings at powerflex. there you go.
If you want to buy cheaper ones I think M5 sway bar bushings in the front are also 25mm so you can buy those at the stealer if you wish. They are $18 each at pelican.
go here
1991 535i/5
Lazer-Blau Metallic/Dove Gray
Old 10-30-2009, 01:55 PM
mottati mottati is offline
Cars: 08 535 00 M5 91 M5
like above, 25mm bushings are needed for the front bar (either aftermarket poly, or oe m5). Probably not a bad idea to replace the end links too.
but, a bigger front bar is going to increase understeer, not oversteer.
Old 11-02-2009, 03:10 PM
Cars: 1989 535i
I forgot to subscribe to this thread, so I am sorry it took me so long time to get back to those of you who replied.
I now realize how dumb I was in asking if I needed different bushings or not. I was incorrectly imagining how the bushings were mounted (which is dumb, because I remember unbolting the sway bar via the bracket that surrounds the bushings),and for some reason thought the bushings fit around the tapered end of the swap bar, which of course makes no sense.
Yeah, you are right.
I just picked it up because it was cheap and I wanted to experiment, and feel the difference for myself.
There is a good chance I will take it off and wait until I can balance it out with a rear sway bar.
go here
go here
Thanks a lot for this post PetesHelga, it helped a lot. I will probably go with the Powerflex bushings, but I am going to try them out with the bushings that the bar came with, they seem to be in good enough shape to hold off with buying the $50 powerflex bushings.
I look forward to putting this on and seeing if I can tell a difference or not.
