Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
Track, Auto-X & Drag Racing sponsored by Bimmerparts.com Discuss "organized" racing, bmw club racing, car set-ups, driving techniques, track tips, events, driving schools, maintenance and more. www.bimmerparts.com.
Old 10-29-2009, 05:41 PM
sstecker's Avatar
sstecker sstecker is offline
Cars: 325ci 2001, track ca
diy scales
with all the cool diy projects people have been doing on here, figured id post my latest one. i saw the design online, improved by going digital. wanted a project to mess around with conversational programming on a mill.
digital scales/turn plates/toe plates.
plates and blocks aluminum
top plate & block slide on the stainless bars
with weight on a central stainless piston
piston rests on a 1/2" bolt in the bottom block to raise/lower/level the corner, with a water level next to it (small slot on left side of top block);
shows piston (it now has double o-ring grooves) and bolt - have a few inches of travel to level each corner
already have an 8 bit micro controller with lcd waiting for the sensors. bolt pattern for bmw and miata.
almost complete - waiting for sight glass and 5v pressure sensors to show up and need to order 1/2" bolts, only have shcs around shop.
i was going to put the roller bearings in double shear but sight glass got in the way
Old 10-29-2009, 05:54 PM
tigruppe tigruppe is offline
Cars: '01 325, '89 325is ks car ;-)
If these are bolted to the hub, do you see some loss or friction in the slide design in high camber applications?
Patrick Spikes
Guinness....not just for breakfast anymore...
Old 10-29-2009, 06:14 PM
sstecker's Avatar
when filled with hydraulic oil the only vertical slide movement, if i get all the air out, is the head of the sensor to pickup pressure. ill find out soon if it binds.
Old 10-29-2009, 07:04 PM
rgconway rgconway is offline
Cars: E30 track E36 street
Awesome project! I saw this on some formula ford site and think it's a great design. I was considering using load cells instead of hydraulics, and adapting to mount to my turntables. Do you intend to have the roller bearings roll on your garage floor? (your garage must be nicer than mine!) If you haven't, I'd consider using a steel insert in the aluminum block for the jacking bolt.
How do you expect to align the two rear hubs? With an LSD this could be difficult.
How do you plan to level the four pads? I made a water level for this as I was not satisfied with the precision of the carpenter lasers.
Did you farm-out the machine work?
I'm asking questions because I'd like to do the same. Please keep us posted
Bob
Bob Conway
NJ Chapter BMWCCA Board Member, Instructor
'89 325i - Track DIY special
'97 M3 coupe - Street
'90 325i - Spare track
'92 325is - Spare street
F350 7.3L PSD, 6sp, dually - Tow (anything)
No automatics!
Old 10-30-2009, 12:31 AM
sstecker's Avatar
Bob
hey Thanks! should be up and running late next week.
i figure a piece of plywood will take care of rough surfaces
rear should slip
there's a water level built with push lock fittings. still waiting for the sight tubes to show up that ill epoxy into the bottom block(and goes up thru the top block). in the single picture you can see where the tube will be seen in the top block - slot on the left side. machined a 'level' mark into the top blocks.
yeah worried about the 1/2" bolt galling. i could always upsize to 3/4"
i machined everything myself. i am not a machinist, work the front office, but learning.
Old 10-30-2009, 10:37 AM
endoforce5 endoforce5 is offline
Cars: BMW 325i race car
This looks like an old Sherline system I had in my FF days. Even though the car weighed <1000lbs. it didn't work well at all - too much binding with the rollers on the floor - even with steel plates placed on the floor to reduce friction. Seems like a great idea though. Maybe you'll have better luck if you've used higher quality components. We used both water levels and lasers to level. The laser worked better and was less hassle. We did use a higher end ART laser - not the Home depot stuff, but I bet you could make it work with a cheap laser if you took the time to make a high quality holder for the laser light source and calibrate it carefully.
Old 10-30-2009, 11:54 AM
BobWright's Avatar
BobWright BobWright is offline
Wheel Stud
Cars: 98 IP M3, and others
I would think you would want to know that your scales are right? Longacre Clearance Bin sounds like the ticket
30" of snow...no power...send gas, firewood, dog food, Diet Pepsi and PFC01 brake pads.....
Old 10-30-2009, 12:29 PM
Cory M Cory M is offline
Cars: 911, 944, WRX, HD2500
Let us know how they work, here is a similar thread with some pics of the Porsche system:
http://forums.bimmerforums.com/forum....php?t=1242293
Old 10-30-2009, 12:57 PM
sstecker's Avatar
could be the bearings cant deal with scrub? a caster type system might work better.
yeah i have a balance scale/weights to calibrate accuracy
nice! i like how they brought the roller bearings back the the center line
Old 11-01-2009, 05:24 PM
sstecker's Avatar
tested rear plates. easier to mount than wheels. i could push on the car and see the bearings roll.
front plates need a spacer to get by wilwood calipers
also need to make/mount 17" angle pieces on plate to measure toe. 8" not wide enough
Old 11-01-2009, 09:03 PM
Very nice! I see from pic that your garage floor is way nicer than mine
BTW, regarding calibration, if you know piston/bore size precisely (I'm sure you do) and have a highly accurate pressure gauge, I would think that you could use your scales to calibrate the load cell type, instead of vice-versa.
Bob
Bob Conway
No automatics!
