Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
Track, Auto-X & Drag Racing sponsored by Bimmerparts.com Discuss "organized" racing, bmw club racing, car set-ups, driving techniques, track tips, events, driving schools, maintenance and more. www.bimmerparts.com.
Old 10-28-2009, 10:32 AM
Simon Tibbett Simon Tibbett is offline
simontibbett.weebly.com
Cars: E30 325ES, E39 528I
Tubing Needed For E30 Cage?
Does anyone know around the basic tubing amount needed for a basic 6 point cage for an E30 coupe?
Future SCCA ITA
Old 10-28-2009, 10:44 AM
rmm3 rmm3 is offline
Cars: E30 m3 DM, E30 m3/s5
4 sticks should do it...they come in random sizes 18'-22' long.
2-1.75"x.095 required bars
2- 1.75"x .065 non required bars
or all .095 if you don't need to save weight.
rick
Old 10-28-2009, 10:52 AM
Cool, thanks!
Future SCCA ITA
Old 10-28-2009, 12:22 PM
DTRguy DTRguy is offline
fabricator/welder type
Cars: 90 325is,89 325i24v
Send a message via Yahoo to DTRguy
I believe you can also run 1 5/8" or 1 1/2" .120 wall for more clearance. Just a thought. Possibly a little heavier overall but I doubt noticeable from car to car as far as handling.
I use 1 5/8" pretty exclusively. Strikes a good balance between the max and min diameters. Plus it just so happens that is the bending shoe set I have for my Mitler bros bender
Dreams To Reality Performance One Lap of America 2010 car build http://forums.bimmerforums.com/forum/showthread.php?t=1268384
Old 10-28-2009, 01:42 PM
TeamDFL's Avatar
TeamDFL TeamDFL is offline
Cars: 528e
As mentioned above, about 80' of tubing should be sufficient for a typical 6+2 point cage in an E30. DOM tubing typically comes in sticks of random length (17 to 24 feet). I believe we used about 70 feet in our LeMons E30. I'll check the bend sheets tonight to get a total. If you are new to cage building, an extra 20' of tubing comes in handy if you have to scrap a larger piece.
My personal preference is 1.5x.120 for the added clearance and smaller bend radius at the expense of an additional .1lb per linear foot over 1.75x.095. I need the helmet room. Note the under roof support that was hammered in over the driver side door to make room for the halo in the photo below.
You can't afford to go that fast.
The more Mustang parts I put in my BMW, the faster it goes.
Old 10-28-2009, 04:10 PM
clopez95m3's Avatar
clopez95m3 clopez95m3 is offline
Cars: 98 M3, 540i 6spd
Unfortunately that's not a size allowed in NASA and BMW CR road racing
Carlos.
Old 10-28-2009, 04:14 PM
Originally Posted by clopez95m3 View Post
Unfortunately that's not a size allowed in road racing (NASA, SCCA, BMW CR).
Carlos.
I believe you are mistaken... Sorry As long as it is BIGGER than what the minimum requirement and meets the wall thickness of the said size ie 1 1/2 then it is just added safety. Why would it not be allowed if it exceeds? Oh and BTW my ITC (scca) rabbit has 1 5/8 Cro Moly .095 wall and is completely legit.
Old 10-28-2009, 04:17 PM
DaveCN's Avatar
DaveCN DaveCN is offline
Smoke up, Johnny!!!!!
Cars: 1990 325i 1996 328iS
Send a message via AIM to DaveCN
Carlos.
NASA will allow it - I have checked into it. Not sure on CCA.
Weeeeee!!!!
Old 10-28-2009, 04:21 PM
clopez95m3's Avatar
And you are wrong... Sorry As long as it is BIGGER than what the minimum requirement and meets the wall thickness of the said size ie 1 1/2 then it is just added safety. Why would it not be allowed if it exceeds? Oh and BTW my ITC (scca) rabbit has 1 5/8 Cro Moly .095 wall and is completely legit.
Yeah SCCA does I edited that, NASA and BMW CR is in the rule books. At the track anything goes, I wouldn't be surprised if it didn't vary from inspector to inspector.
Carlos.
Old 10-28-2009, 04:27 PM
Cory M Cory M is offline
Cars: 911, 944, WRX, HD2500
I wouldn't recommend 1 5/8" simply because it is an oddball size. Try to go to a racing shop and get brackets for 1 5/8" - there are none, just 1.5 and 1.75. We've got a car with a 1 5/8" cage and the standard brackets for my water bottle, mirror, helmet hook, seat back brace, etc don't fit and I had to come up with my own brackets. There is nothing structurally wrong with 1 5/8", and it should be legal as long as you go with the thickness recommended for 1.5" and not the thinner 1.75", but in my experience it is just inconvenient..
Old 10-28-2009, 04:29 PM
Again, look at it logically... If say 1.5" .120 wall is allowed... then 1.625 or 1.750 .120 is allowed. When you get to a certain point, there is allowances for wall diameter hence why 1.750 you can run the smaller wall thickness. For my ITC car, there is an allowance for alloy factored in so I could run the thinner thickness wall, and even thinner diameter but I am still running the larger diameter. It is stiffer and safer. And it wasn't inspected at the track for compliance. I was inspected at my shop where I built it. All of the Lemon's cars I have built for Toyota were also 1.625. I believe that the engineers there that I was building the cars for would have not let me do it in that material if it weren't completely legal.
I have run into that... the simple fix in the case I have ran into for things like mirror mounts and helmet hooks and such is get the size for 1.5 and trim to fit. Kinda PITA... but It's how I got around it. When I purchased my bender I was figuring on having more drag car oriented things to do for people (I do like in KY) and 1 5/8" is common in drag. Had I known I'd have gone for a 1 1/2" die. My new race car is all that size. So eventually I'll be buying that set (expensive for limited uses).
Old 10-28-2009, 04:42 PM
clopez95m3's Avatar
I'm surprised they have rules for Lemons cages.
I agree with your logic but it's hard to disagree with the rule books. If you get some inspector that measures your cage at the track, yes NASA and BMW club can do this then you're SOL if they tell you you used the wrong sized tubing. A friend had to deal with an inspector at a NASA weekend who wouldn't allow his car to compete due to a weld on an optional tube, and he did this to a bunch of people.
I honestly don't see Lemons disallowing anything. Don't you just bribe the inspectors with liquor?
Carlos.
Old 10-28-2009, 04:55 PM
TeamDFL's Avatar
Cars: 528e
Carlos.
There is actually a bit of a LeMons stink going on right now regarding bribes. BS judges have always taken bribes but tech is supposed to be legitimate because insurance coverage has safety requirements. At Stafford, the tech guys were soliciting bribes which is not supposed to happen. They will probably clamp down on that ASAP.
BMWCCA/SCCA/NASA tubing requirements are minimums. You can definitely go larger in OD and/or wall thickness if you want. From BMWCCA clubracing Appendix A, 17-B:
"Size. For the purposes of determining roll bar tubing sizes, vehicle
weight is as raced, WITHOUT fuel and driver. Note: There is an
allowance of minus 0.010 inches on all tubing thicknesses. Minimum
tubing size
for the required tubes of the roll cage is:"
Carlos.
I can almost understand if a tube was installed (optional or not) and isn't welded to the specs stated within the rules... Hmmm if said tube breaks free it could maybe create a dangerous situation. So I can like I said sorta understand that. I have many many welds of mine inspected over 20 years. If you follow the rules implicitly then you have nothing to worry about with respect to that. That being said I can see where some inspector might add his .02 to the interpretation of the rules and say Nope I don't care if your car is safer with larger diam tubing. It says x you need x. So I get you. Heck on our rabbit it was a reinspection to replace the original very bad cage built prior to 2007. Car was being rebuilt in 2008... so we used 2008 rules regarding the diagonal and the Petty bar requirements in the rules. It became a question to which set of rules to use! After I explained my reasoning... the inspector agreed that the revised rules of 2008 should apply even though the car has a log number that predates 2007 rules. It almost got ugly in the shop
Z3SpdDmn Z3SpdDmn is online now
Car Whore
Cars: '06 Z4 3.0si Coupe-'87 325is KP-'07 Silverado
Send a message via AIM to Z3SpdDmn
Carlos.
Carlos,
Believe it or not, they've been scruitinizing safety very heavily this year. They actually HAVE turned cars away at the track. Kevin did the cages in our Toyota cars and we accepted the larger diameter that still had the thicker wall.
Your point is taken, though. If an inspector decides he doesn't like it, you'd need a rule to defend yourself with. Do the rulebooks not say "minimum diameter" or "minimum wall thickness"?
-Anthony
'06 Z4 3.0si Coupe, Montego Blue
'97 Z3 2.8, Atlanta Blue (on loan to Dad)
'87 BMW 325is SpecE30 #003 / #007 K-Prepared
Instructor for: BMWCCA, PCA, Chin Motorsports, Street Survival
AnthonyMagagnoliRacing.com <<>> www.MyTrackSchedule.com <<>> DTR Performance
Please help support the Street Survival / DTR Cannonball One Lap of America Effort!
Old 10-28-2009, 05:01 PM
TeamDFL's Avatar
Cars: 528e
From NASA's CCR:
"15.6.18 Roll Cage Tubing Sizes
without fuel and driver. Note: There is an allowance of m
thicknesses. Minimum tubing size for the roll cage is: "
From the SCCA 2009 GCR 9.4.F.2:
"2. The following table shows the minimum allowed tubing outer
diameter and wall thickness
by vehicle weight:"
Old 10-28-2009, 05:14 PM
Car Whore
Well, I think Simon Tibbett has had his question MORE than adequately answered
-Anthony
Old 10-28-2009, 05:21 PM
clopez95m3's Avatar
Agreed.
Carlos.
