| 1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life. |
Thread Tools |
Style 40 M Roadstar on '00 328i?
The front tires are 225/45-17 and rear 245/40-17 Kumho ECSTA ASX. I guess the wheels are 7.5x17 and 9x17 - haven't heard back from seller. Will these work without any spacers or different lug bolts, or fender rolling?
My 3828i is stock in height and brakes, running the usual 17x8 Style 44s. Thanks in advance! ![]()
John in VA
'74 tii "Juanita" '85 325e "Ol' Blue" '86 535i "M-POSSTR" '00 328i "Fern" |
Was da question senor? Will they fit?
![]() 18" Enkei EKM3's w/Khumo ASX's ~ DDM Tuning Coilovers ~ Matte Black Kidneys ~ B&W Hood/Trunk Roundels ~ Smokes All Around With LED Eagle Eyes ~ Bavauto License Frames ~ M-Style Lip ~ Debadged ~ VANOS Rebuild-Done ~ GPS Mount Mod ~ Pillar Mod ~ Custom Trunk Interior~Colgan Nose Bra~Xenon Plate Bulbs~Custom Interior Trim By Feia0303
Sorry - yes, I was wondering if they'd fit without any spacers or different lug bolts, or fender rolling?
John in VA
Lugs should be gtg...but we gotta figure out what the offset is...
Actually, I think they'll fit fine...but lets check out the offset. I think you may be able to go up to 255's in theback with no rub or roll o the fenders.....but larger, and you would have to roll them.
Last edited by danewilson77; 10-27-2009 at 11:00 PM.. Reason: Automerged Doublepost |
If I wasn't lazy I would swap the wheels from my m roadster and put em on the 325, but truth is I'm lazy. I also don't think they will look good, especially with the rear wheels having a nice dish and lip.
-Mike/Michael/Mikey...
![]() http://www.cwithersmedia.com/ ^^Tracking Pswirley ^^Click Here!! ^^ !!!!!!!!NEW LINK!!!!!!!!!! |
front 7.5x17 offset 41
rear 9x17 offset 8 - I thought that had to be a typo, but I guess not. Not having seen them in person, I don't know about the amount of dish/lip. I have a staggered set of Alpinas 16" on my E28 but the difference is only ~12mm offset front vs. back. Lip is good, no?
John in VA
Specs for my rims are
Offset: +42mm Backspacing: 6.10" Bolt Pattern: 5-120 Rec. Tire Size: 225/40-18 Weight: 24.2lbs. cept I have 245's all the way around. I think you'll be fine...but may want hail Pswirley on this one.
I've seen them on an E46 even though in theory they should NOT fit. The fronts will fit fine, but the rears have way too low of an offset. Bolt pattern is a-ok though.
The fronts would fit, the rears will not fit, whatsoever. Maybe on an M, with a stretch, but definitely not a non-M. I put one on the back just to see a while back, and it stuck out a good 2" further than the body. Looked like a lowrider.
if they fit an e36 they will fit an e46
![]() ![]() however, you will need to run some stretched tires and roll your fenders.
Yeah, it's looks spaced a bit too far out for my tastes, at least on the wagon pictured above. Thanks for your help!
John in VA
Like I said, I put them on my car, without tires on them, they stuck out an absurd amount, there is NO way they'd fit an E46 without widebody rear flares. No amount of stretching would make them fit. Do you know if that E36 owner did any other modifications to make them tuck? I doubt it's as simple as a stretch and rolling.
| Bookmarks |
| Thread Tools | |
