Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 10-25-2009, 07:54 AM
lasmariaspr's Avatar
lasmariaspr lasmariaspr is offline
Cars: 325is
New radio unit, Bad reception
My problem is that the radio antenna is not working properly. And the problem is bad reception. I know the antenna in an E36 is behind the passenger side C-pillar. I found this somewhere:
Can somebody explain this to me who has done this procedure:
There is an antenna amplifier behind the driver's side C-pillar. If you have changed your head unit and/or amplifier lately, you may no longer be sending power to the antenna amplifier. If this is the case, you will need to run a wire from your remote amp turn-on lead to the antenna amplifier, and all will be well. (I suffered with bad reception for about a year before figuring this out.)
If you have not made any changes to your in-dash or amplifier, then check for 12V at the power lead of the antenna amp. If there is power, replace the antenna amp. If there is no power, run a jumper line to the amp and see if it works.
Need help with that wiring 12V of antenna. Where do I input 12V cable?
Old 10-25-2009, 08:07 AM
Cars: 325is
Amp wires in trunk were cut by previous owner.
Brown cable was missing 12 v, up and running.
Got it working, brown cable needed 12V.
Last edited by lasmariaspr; 10-25-2009 at 04:45 PM.. Reason: Automerged Doublepost
