Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 10-24-2009, 10:00 PM
WHITEXi's Avatar
WHITEXi WHITEXi is offline
Cars: 2002 325xi, 98 acura integra
Talking Clunk be gone. From the makers of mighty mend it.
So I changed both my front axles from a set from FCP Groton. The clunk is gone. My dealer said I needed new axles for a vibration and that was a tie rod .The axles had play anyway and torn boots with a slight minor vibration, but the tie rod definitely was the bad wheel shake. I don't know who made the old ones but they were aftermarket ones. The FCP ones fit fine the only thing was the movement around to get the non oem clips in. it took like ten seconds to just rotate them in on both sides. I wanted oem clips but I couldn't get any in time for today. the old axles had non oem clips anyway so it didn't matter tho. Its so nice I like driving my car again. I would say the install on both sides took an hr and a half but I was looking around at other things and taking my sweet time but all in all It was 3 hrs total. To anyone not using oem lock clips DO NOT try and hammer them in. Especially on the pass side, when you start to put the axles in the cir clip will go to one side more than the other. Rotate them around while putting minor force into them and it will fall right into place. I did not hammer or slam them in.
Second there is no need to remove the hub and caliber as this is a waste of time. I simply unbolt the outer tie rod and lower ball joint and swing the whole hub/strut assembly out of the way and tie it to the sway bar. Thats all there is to it.
Thought id share
Cross drilled and slotted rotors, Akebono brake pads, r/c/r tails. Front clears and P46's with V2's, M3 rep spoiler and tint all around.
Old 10-24-2009, 10:11 PM
16valex's Avatar
16valex 16valex is offline
Cars: 02 530I, 01 330XI
Appreciate the feed back but can't make it head or tail
Old 10-24-2009, 10:14 PM
WHITEXi's Avatar
what do you mean by heads or tails, im confused. Ill explain more if you do.
Old 10-25-2009, 12:12 AM
sonspot sonspot is offline
Cars: 01 330I Sport/M/Winter package
good to know if i have to do mine, how was it dealing with FCP Groton, am thinking about buying control arms from them.
thanks
Old 10-25-2009, 12:55 AM
pphil09 pphil09 is offline
License Suspended
Cars: e46 stance primo
**Warning: Crude Language**
Old 10-25-2009, 11:43 AM
tdz123 tdz123 is online now
Noob
Cars: 330xi, 4runner
Thought id share
I wish that had worked for mine. I tried rotating and I still had to apply a tremendous amount of pressure to get them in. Good to hear the clunk is gone.
Old 10-26-2009, 12:38 PM
nathancarter's Avatar
nathancarter nathancarter is online now
You said 'Member'
BMW CCA Member
Cars: 2002 330i 118k
When you have an Xi with failing front axles, it'll make more sense.
Old 10-26-2009, 12:41 PM
Noob
Thought id share
What method do you use to put the hub back on the axle (or the axle back in the hub, to state things differently)? I used the "hammer the crap out of it" method, which I'm not very fond of.
Old 10-26-2009, 09:18 PM
WHITEXi's Avatar
I meant to get back earlier but just been busy lately. Anyways the method for the hub is this. I simply seat the axle in the diff first and them place the axle end against the hub and rotate the rotor to just have the axle grab in the teeth easily. I then just pull back and forth on the hub gently against the axle until I can get the axle nut on and then turn it on with the socket and breaker bar. Very easy.
Old 10-26-2009, 09:50 PM
Noob
Man. My job was the job from hell compared to yours or else I really wasn't doing things right. I swear to god I tried that exact thing...one hand on each side of the rotor, trying to get the stinking thing in. Fortunately I was able to get the thing fixed in the end, but it was by far the most difficult job I've done so far. Having a lift would have been helpful.
Old 10-26-2009, 10:01 PM
WHITEXi's Avatar
A lift helps as the car is level with my shoulders, but the worst so far was the wheel bearing. That was hell.
Old 11-19-2009, 11:48 PM
wilman wilman is offline
WiL d[-_-]b
Cars: bmw 325i
Talking
that mighty mend video is hilarious!! " before your fat ass ripped it.. after your fat ass fixed it" lmao
Old 11-20-2009, 03:21 PM
millertimebmw03's Avatar
millertimebmw03 millertimebmw03 is offline
Cars: 1996 328ICA, 2002 325 xiTouring
Glad to hear this worked out for you, its such a good feeling to have the car be so smooth!!!
LOOKING FOR E46 M3 WHEELS!!!!!!!!!!
I love this car.
Old 11-20-2009, 09:27 PM
sockethead sockethead is offline
Gimme a ratchet
Cars: '05 330i ZHP
http://www.youtube.com/watch?v=oQssF0v8_I4
That is friggin hilarious!
