Just getting this posted on the internetz for everyone else that will run into the same issue I did for the last 2 weeks. The porche bosche 803 3.5" HFM is not entirely plug and play.
OBD2 applications have 4 prong connectors at the MAF. There are 2 grounds, black and brown/orange. On the stock MAF the ground pins 1 and 4 have continuity and are essentially the same point. On the Porsche HFM, the ground pins 1 and 4 do not have continuity - they are open. You MUST get continuity between these points just like the stock MAF. Doesn't matter where you do it, so it doesn't necessarily have to be on the pins where they plug in. I did it in the wire harness leading up to the plug.
Spliced mine together this morning and voila, no more jerky car when started, no more bucking bronco feeling when trying to take off, no more stumbling idle that shuts the car off, no more table 11 code 08's. Nice and smooth now from the get. Was very very very happy to finally figured this out after getting some help from a fellow member (Matt). Unfortunately everywhere I searched I could not find the solution to the issue, luckily he chimed in on one of my local threads here.
Writing this up to help future obd2 guys. Hope this helped, good luck!
AFAIK this was common knowledge.
Tenured Automotive Service Professional - Avid BMW Enthusiast
So, you are saying that the OBD-2 won't just plug into the 803 maf without problems??
I actually did not know this. I knew the obd-1 had to be modified.
This is my signature....
is this good for obd1 with 803 maf ? OBD2 [COLOR=blue !important][COLOR=blue !important]applications[/COLOR][/COLOR] have 4 prong [COLOR=blue !important][COLOR=blue !important]connectors[/COLOR][/COLOR]
at the MAF. There are 2 grounds, black and brown/orange. On the [COLOR=blue !important][COLOR=blue !important]stock[/COLOR][/COLOR] MAF the ground pins 1 and 4 have continuity and are essentially the same point. On the Porsche HFM, the ground pins 1 and 4 do not have continuity - they are open. You MUST get continuity between these points just like the stock MAF. Doesn't matter where you do it, so it doesn't necessarily have to be on the pins where they plug in. I did it in the wire harness leading up to the plug.
Very different.
Here is the problem with the 803: On OBD2 cars it plugs right in but it needs electrical modification. On OBD1 cars, the plug doesn't work (you can "modify" it) but you don't have to do any special splicing.
Either way you need software programmed specifically for the 803. It is NOT the same as a euro/540 3.5" MAF.
No PMs. Email through forum please.
well it must have been so common that during a search it didn't pop up on any site I checked, and in my box from bimmerworld no instructions came with anything. Now common knowledge or not, the next idiot that tries to straight plug and play it will be able to find this thread and not spend a few hundred bucks troubleshooting like i did.
FYI ...TMS has an adaptor for the Porsche MAF - I got it a couple of years ago and was in the ballpark of 70 - 100 dollars.
Like me, not that im the idiot, lol, but i sure as hell have had massive problems with my 803 meter, and have found no help until this thread. Including calling turner motorsports, asking them why the hell my 803 meter isn't working, saying the code is saying short to ground, and why it's not working with my software. And they had no answers for me except, reinstall the software! So Thank you very much Mike30 for this thread!
95 BMW M3 Alpine-
<GO...JIC Cross Coilovers- UUC RCAB, AKG FCAB, Rogue Engineering TM bushings- AA Gen3 Exhaust- Dinan F&R Strut Bars- Dinan F&R Sway Bars- X-Brace- Mishimoto Rad- BBS RK 17x8"- TRM Chip- Dinan BBTB- DIY CAI- JP Performance Headers- 21.5 injectors- JB Racing Flywheel- Bimmerworld TB boot- 540i MAF><SHOW...OE euro clear exterior lights- Depo w/ HID- Hurricane Alcantara interior- Stereo (Kenwood,Sony,MB Quart,Rockford Fosgate,JL Audio)- Black kidneys- Euro 3 Spoke- ZHP Knob- AutoDim Mirror>
Agreed! I have the correct software, that was obvious, the wiring part is not. Every single vendor who sells the 803, or says you need the 803 to work with their software, say it's plug and play. It's very much not, and now my car is running great because of this post!
can you further explain what you did to get it to work? and this is not the "Euro/540" MAF? is 803 the last part of the part number on it or something? i'm curious if i have the porsche MAF and maybe this is why my car has never run right with it...
UUC EVO III SSK | M50 Intake Manifold | Conforti 3.5" CAI | AA Software | 3.5" HFM (unplugged)
Fan Delete | Strömung Exhaust | UUC Stg2 Ltw Flywheel | X-Brace | AA Track Pipe | 3.46 Differential
1/4 mile: 13.3@104.2mph; 8.6 in 1/8; 2.04 60' | Best 1/8 mile: 8.3@83mph; 1.81 60'
Dyno: 242rwhp/232rwtq SOLD
IIRC 803 is the last 3 digits in the part number....that and it'll have a porsche insignia on it...I am not at all sure of that and I have no experience on the matter as I have the Euro 3.5.
Is that on your OBD1 e36? Or on your OBD2 M3?
Either way, running with your MAF unplugged is stupid.
I have the Euro MAF and for some reason I keep getting the code thrown for MAF. It looks like the PO never installed the turner wiring adapter.
1999 M3 vert, Rogue SSK, Conforti intake, SS replica catback, UUC adj rear control arms, Eibach springs, Konis, Beyern rims, cross-drilled Zimmermans w/Akebono Euro ceramic pads, ASC delete, Bosch Euro lamps, ZKW Euro foglamps
Yes it does.Originally Posted by Uliman
