Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1983 - 1991 (E30)
1983 - 1991 (E30) (1983 - 1991) Born from the sporty character of the 2002 and the sharp design lines of the E21, the E30 was a blend of the best of BMW's heritage. The second generation 3 Series provided a thrilling driving experience that used the best technology available.
Old 10-18-2009, 10:52 PM
futbolnice futbolnice is offline
Cars: 1991 318is
Rear Tire Wobble...Please help
Hi, Gang
I was riding down the road the other day minding my own business...this guy rolled up to my right, and signaled me to down my windows...i'm thinking this must be a fellow e30 enthusiasts giving me props. Instead "your left rear wheel is wobbling!!!". I'm thinking SH*T. Went home that day, put the rear on jacks and put car in 5th...and sure enough...left wheel is wobbling *not noticeable during driving*. I've since changed tires but its still there...please give me all the advice/help
(other thread http://forums.bimmerforums.com/forum....php?t=1326983 regarding what i think is the drive shaft, but im not entirely sure now)
Old 10-18-2009, 11:03 PM
Ranger1's Avatar
Ranger1 Ranger1 is offline
Voice of reason
Cars: E30, E36 DD, Ram Tow
How much is it wobbling?
Failed tire carcass? Bent wheel? Loose lugbolts? If not, remove wheel and lift rear end with jackstands.. Start car, let it idle in gear and see if rear rotor wobbles. See what wobbles and what doesn't. Find the first thing that wobbles and either tighten or replace it.
Porsche Certified Performance Driving Instructor
www.Gress.org
Old 10-18-2009, 11:27 PM
Rigmaster's Avatar
Rigmaster Rigmaster is offline
<Yes, that really is me
Cars: too many
failed/failing wheel bearing (assuming you put a different wheel on when you said you changed tires)
Old 10-19-2009, 01:34 AM
djb2 djb2 is online now
Cars: 1987 325is, Z3
Take the wheel off and check the run-out at the brake rotor.
I once had an ATE brake rotor that was machined with non-parallel surfaces on the hat. It took me about two years to figure out the problem. It's unlikely that you have the same problem, but it's a good place to isolate the problem to the hub or to the wheel.
Old 10-19-2009, 08:00 AM
Cars: 1991 318is
not too much..cant tell while im driving...will do
yes..different wheel
Do you guys know if a bad cv drive shaft can cause the problem?
Old 10-19-2009, 09:08 AM
2slo4me 2slo4me is offline
Cars: V8 volvo aka sleeper soon to have a 325i
Send a message via AIM to 2slo4me
jack the the rear of the car up.... then try and move wheel side to side... might be a bad wheel bearing just replaced mine.
Old 10-19-2009, 09:27 AM
Ranger1's Avatar
Voice of reason
I would be surprised if a bad CV shaft ends up being the cause.
www.Gress.org
Old 10-19-2009, 01:07 PM
Pennyw1se Pennyw1se is offline
Cars: 88' 325e
+1 for wheel bearing
Old 10-19-2009, 01:44 PM
Rigmaster's Avatar
Cars: too many
No, unless the wheel bearing AND the halfshaft (driveshaft with CV joints) are both bad...
Old 10-19-2009, 08:32 PM
Cars: 1991 318is
oh thanks..will do first thing tomor
got it looked at by a mechanic today...says it may be the axle. is that true (/potentially(?. can someone please explain to me what the difference between the halfshaft (driveshaft with CV joints) and axle? pictures would be much appreciated; im too confused to differentiate the aforementioned parts
Old 10-19-2009, 09:27 PM
Rigmaster's Avatar
Cars: too many
#1 is the halfshaft (axle shaft with 2 CV joints).
I don't see how this could cause the wheel to wobble- I still vote for the rear wheel bearing.
Old 10-19-2009, 09:47 PM
Cars: 1991 318is
ahhhhhhhhhhhhhhhh.....much thanks...would you happen to have pics of the wheel bearing?
http://www.teamdfl.com/bmw/e30/rear_...ngs/index.html
http://www.unofficialbmw.com/e30/sus...eplacement.pdf
would you say they are good writeups? (this will most likely be a shop job...but just for interest)
wheel did not move side-to-side. other suggestions?
