Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Bimmer Rides & Styling sponsored by DDM Tuning
Bimmer Rides & Styling sponsored by DDM Tuning We want to see your Bimmer! Post pictures of your ride and discuss body improvements with DDM Tuning.
Old 10-18-2009, 02:33 AM
BeemerBuyer's Avatar
BeemerBuyer BeemerBuyer is offline
Loves White Wheels
Cars: 86 325e, 97 M3
Post BeemerBuyer's BBS Style 5 Thread - DIY Wheel Refinishing
I bought a set of 4 BBS style 5s last spring with intention of refinishing them and Im now just getting around to it.
The specs for style 5s are pretty generic but for those that don't know the wheels are:
17x8 et20 From an E39 528i with sport package.
I plan on running 205/40/17 Falken ZE-912 UHPAS.
*As well it should be noted that to properly mate these wheels to an E36 they need hubcentric rings. The hub bore on the E39 is 74.1 and the E36 is 72.5 - just slightly smaller. The hubcentric ring just makes up for that small gap.
BBS RC090
I started yesterday with a trip to the hardware store to get all the necessities. I bought:
A 10mm 12 point socket - to remove the bolts ($3)
A 10 inch extension - to be able to reach all the way in to the wheel ($10)
A "Nail set" *the grey one* - this is to tap out all the bolts after removing the nuts. They come in different colors, each represents a different size. The grey one is a good size. ($5)
Jasco - Paint and epoxy remover ($10)
Sand paper - 150, 220, 400, 600, 1500 grit (>$2 each)
You will also need some sort of extension for the socket, it made taking the bolts off a piece of cake. I used a random piece of pipe that fit over the end of my socket handle. You can see it in my third and fifth picture.
AND
A dead blow hammer
OR a piece of wood, I used a 4x4 block that was laying around in the yard This is for pounding on the center after taking out the bolts. Just be sure to wrap it in a towel so you don't damage your wheel.
Today I started the disassembly process:
Close up of the worst areas:
I flipped all the wheels over and sprayed them all with PB Blaster, to loosen the bolts up a little before trying to take them apart.
Then I used the pipe extension around my socket wrench to go to town on the bolts. I separated the nuts and bolts into two different jars each full of vinegar.
This is the wheel with all the nuts off.
Now that you have all the nuts off, you have to use the "nail set" to tap the bolts out. Now this may seem easier than it really is. You have to smack the bolts pretty damn hard, some come out on the first hit some take 3 or 4 hits. You will figure out your own technique on how you want to hold the nail set and at which angle you find more comfortable. I say that because I hit my thumb a few times and scratched the wheel a few times This is the hardest part of taking them apart. It is very tedious work, so remember that the slower you go the less likely you will scratch, gouge or hit your wheel.
It was a pain in the ass doing the first wheel but by the time I was doing the 4th I totally had the hang of it. It gets easier as you go.
Now that you have the bolts out, flip the wheel over, get your wood block wrapped in a towel or your dead blow hammer. Place it on the center of the wheel - hit it. Now move the block to one edge (3 o'clock postion) - hit it, rotate the wheel - hit it, rotate the wheel - hit it so on and so forth.... They'll come out eventually, and like those damn bolts some come out easier than others. It took 4 or 5 hits before they came out.
After doing this same process to each of the 4 wheels, I sprayed them all with some degreaser and gave them a light scrub down. They were so dirty from years of road grime and PB Blaster.
This is what I was left with.
The bolts and nuts are still soaking in their jars of vinegar.
DAY #2
UPDATE:
What you will need:
Some things I list I'm just going to go ahead and assume you will have lying around.
Jasco
Paint brush
Metal container
Old rags
Any open area
I started by taking the barrels out to a very well ventilated area where I could apply the Jasco. This is to remove the clear coat from the barrels.
Note: the nuts and bolts in vinegar.
This stuff is nasty.
Do not breathe it and DO NOT GET IT ON YOUR SKIN. Wear long sleeves and thick gloves. I accidentally let my wrist brush against one of the wheels after the Jasco was applied and even though it was dry it started burning me instantly. Just be safe, use your head.
Pour the Jasco in to a shallow metal container. I used a plastic container lined with aluminum foil, which worked just fine. Then with your paint brush, brush the Jasco on to your lips. I found that the more you use the more clear coat it eats away and the easier it is to get off.
This was my first coat, which was pretty light - but go ahead and glob it on. The more the merrier.
After applying it to all 4 wheels let it dry for 20 to 30 minutes. It works pretty fast. I could hear one of the wheels making a hissing noise within seconds after applying the Jasco.
I drained out my vinegar jars and took a look at the nuts and bolts.
The vinegar did a good job cleaning them up. It loosened all the grime and blue loctite was gone.
While waiting for the Jasco to dry I wiped each bolt... Yes, individually. And put them separately in other clean jars.
30 minutes later, the lips should be dry and are ready to be wiped down.
Get your gloves and your old rag, and start wiping the lip. I found that one of three possible outcomes will occur.
1.It is easy to wipe off and your left with nice smooth bare metal.
or
2. It doesn't come off at all.
or
3. Where it sort of comes off but leaves behind a residue.
This is the first coat...
Second or third coat and a lot of wiping later...
Still a lot of residue, but getting there...
So depending on how much you can get off with the first round of Jasco, just keep doing what we did before. Apply - Wait - Rub off, Apply - Wait - Rub off... Until its all gone. It took me 4 maybe 5 different coats before I got it all off.
*Remember, as in accordance with the rest of this project, it takes a while.
Since it might take a while... What do you do with all that in between time?
Clean up your centers!
I've found that the Mr.Clean magic eraser is a wonderful tool to use. They are $2.50 for a 2 pack and happen to work great for stuff like this.
Note: The bottom left one is clean
This
To This
Back out side the lips are almost there, about 95% clear coat free. It takes a lot of scrubbing to get it all off.
Here is one of the lips all done. I haven't even started sanding yet and it looks way better with out the clear coat.
I will again update soon, I still have a lot more work to do!
Thanks for reading.
-Nick
Old 10-18-2009, 02:38 AM
MC EUROS's Avatar
MC EUROS MC EUROS is offline
Not My Problem
Cars: 04 gti vr6, 89 325i
very nice i look forward to the rest of the write up!
Doesn't have a signature
Old 10-18-2009, 02:43 AM
mpower5266's Avatar
mpower5266 mpower5266 is online now
Cars: 97 740i, 74 2002
Send a message via AIM to mpower5266
Nice man I am about to start a set for a buddy of mine. Just remember to take your time polishing aluminum, its not going to come out perfect the first time you polish it.
Old 10-18-2009, 02:50 AM
Mossman11 Mossman11 is offline
Cars: 85 635CSi, 89 325ic, 89 325is turbo project
Send a message via AIM to Mossman11
I think you're gonna need more than 2 dollars worth of sand paper and if you value your time I'd get at the minimum a jitterbug 1/4 sheet sander to speed up sanding time. Also start at 80 or 100 grit especially in those pitted areas.
http://www.bimmerfarmer.com
Used wheels I have ready for refinishing to your specs and powdercoating any color/finish you want:
17X8 et20 Style 5's, Style 19's, Style 42's
18x8.5 et43 SSR GT3
18x8.5 et13 Hamann HM2
Old 10-18-2009, 02:52 AM
NotherM3 NotherM3 is offline
Cars: ///M3
Nice write up so far!
99 TitanSilber ///M3
Old 10-18-2009, 02:53 AM
Tony Soprano's Avatar
Tony Soprano Tony Soprano is offline
Go Rays/Rox/M's!!!!!!!!!!
Cars: 97 M3 & 05 Acura TSX
good work bro!
212rwhp/195rwtq...14.4@98...oh yea, its auto too.
Old 10-18-2009, 03:07 AM
EuroCar's Avatar
EuroCar EuroCar is online now
Brilliantly interesting
Cars: 95 M3
Send a message via AIM to EuroCar
Where are the FM10's going?!
Looks like a good buildup, very similar to mine
Old 10-18-2009, 03:15 AM
Emsan's Avatar
Emsan Emsan is offline
Diamantschwarz-metallic
Cars: E36 M3 S50B30
This is a great thread. I am looking forward to updates. I planned on sending my Style 5's to get refinished this winter but if this DIY turns out to be a viable option then I am all up for it.
Great pics and great write up so far. Everything is very clear and easy to follow.
Old 10-18-2009, 03:16 AM
mpower5266's Avatar
I think he meant 2 bucks per pack, and he probably wont need to go as harsh as 80 or 100 grit.
And if you really want to make it go quicker pick up some of this.
This works kinda like a cutting compound.
Then this for polish.
Old 10-18-2009, 03:17 AM
nismoracer65789's Avatar
nismoracer65789 nismoracer65789 is offline
Cars: 1995 Bmw 525i
Nice job so far! And yeah... Those bolts can be a PITA to knock out with the nail set.
Old 10-18-2009, 03:43 AM
jhstealth's Avatar
jhstealth jhstealth is online now
my_nameaintearl
Cars: 97 540i6
Nice I'm gonna hafta save this for when I do my style 19's
VV Will trade for M3!!!
Old 10-18-2009, 03:53 AM
southpaw's Avatar
southpaw southpaw is offline
srs front bumper is srs
Cars: E30/E46
great job!! looks incredible
Old 10-18-2009, 04:04 AM
Sam Son's Avatar
Sam Son Sam Son is offline
NY E34 Ambassador
Cars: 1995 E34 Snow Plow
god those pics bring back horrid memories of refinishing my wheels...i never wanna do it again....good luck man i cant wait to see the finished product
Originally Posted by AndrewH View Post
nice pics but for some reason sam sons car always looks dirty to me
Old 10-18-2009, 04:28 AM
87shark's Avatar
87shark 87shark is online now
Dat ass.
Cars: 1990 535i
If you are using jasco wear gloves, it really burns when you don't. I have two completed. Try starting with 320 grit sand paper.
Style 5s almost done.
BMWCCA #429029
Old 10-18-2009, 04:43 AM
Loves White Wheels
They aren't going anywhere.
The style 5s are kind of acting as my guinea pig to practice on. Im planning to refinish the FM10s for this coming summer. I just got some summer tires for the FM10s and I thought it'd be cool to use the style 5s for the winter months with some all season tires.
Thanks for the inspiration guys.
-Nick
Old 10-18-2009, 12:14 PM
oomz1975 oomz1975 is offline
Champion
Cars: BMW Vert & Touring
I will be keeping a close eye on the progress, got a set of five 'style 29s' to polish the lips on.
Old 10-18-2009, 01:57 PM
bjh102 bjh102 is offline
Cars: 96 328is, 85 635csi
looks good man. im gonna suggest you get some 2000 grit sand paper aswell and a file to file out the curb rash. but so far so good.
84 528e- G/c coils, hrs wheels- sold
96 328is- g/c coils, borbet type A's, Fikse Fm 5's sparco seat, crow harness, every suspension and brake part replaced.
Old 10-18-2009, 03:05 PM
UselessTurbo's Avatar
UselessTurbo UselessTurbo is offline
I can has taste
Cars: 1995 Avus M3
Send a message via AIM to UselessTurbo
In for the updates!
Means of Transport:
1995 M3
Previous:
1987 528e Sold
1985 325e/4 Sold
Old 10-18-2009, 03:58 PM
BoostedAvant BoostedAvant is offline
Cars: '04 B6 QT6MT Avant
Looks awesome Nick I can't wait to see the final product. I'll call you a little later today and ask how they're going. BTW Tom's account is Teege12 he wanted me to tell you that. P.S. Scott's rockin' khaki's and hiking shoes? Haha.
Old 10-18-2009, 08:07 PM
Loves White Wheels
Originally Posted by UselessTurbo View Post
In for the updates!
Are the 5s in your sig real? Photoshop?
I want to see pictures.
Thanks dude.
Yeah... Its all about khakis and hiking shoes. haha. So hot right now.
-Nick
Last edited by BeemerBuyer; 10-18-2009 at 08:10 PM.. Reason: Automerged Doublepost
Old 10-18-2009, 08:17 PM
Bone Stock e36 Bone Stock e36 is offline
Cars: 1995 325i
Damn, this is one hell of a writeup. Keep up the good work!
Old 10-18-2009, 08:44 PM
pennpen's Avatar
pennpen pennpen is offline
bah.....
Cars: 89' 325i, 99' mazda millenia
Send a message via AIM to pennpen
subscribed, i wanna to see how this ends up
Old 10-19-2009, 12:08 AM
bluffrides's Avatar
bluffrides bluffrides is offline
Cars: 740iL/Alpine M3
same here....
BEAST IN THE MAKING
PROJECT DESSERT STORM
Old 10-19-2009, 12:52 AM
DRIFTM42CANO's Avatar
DRIFTM42CANO DRIFTM42CANO is offline
The Real Panda
Cars: E36 Panda Club#1
Send a message via AIM to DRIFTM42CANO
subscribed
please dont let us down lol
this thread will be godly
LocalSceneMedia.com-KennyCano.com--BSAINTMEDIA.com
The Panda Brotherhood Member No.1
Old 10-19-2009, 04:36 AM
1FCKolon 1FCKolon is offline
Cars: 1999 E36 M3
Great thread, just picked up a set of Style 5's tonight, so this thread is going to be very use-full. Im going to pm you some questions for sure.
Originally Posted by riffman12 View Post
basically any of the slammed cars with stretched tires will run low 8's
