Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 10-11-2009, 10:26 PM
Mormon328i Mormon328i is offline
Cars: 2003 330i zhp
Help! 122 and -40 readings
So I posted a thread recently about my temp sensor problem...
I just bought a 330i zhp and the outside temp sensor hasn't worked since I bought it a month ago.
I bought a new sensor and replaced the one that the tip was scuffed down. Obviously the previous owner ran over something and it got ripped down. Possibility of someone stealing the fog lights and ripping things out as well since both fog lights are missing.
Anyways, I put the new sensor in and no change after 100 miles of driving. I noticed there is two blue wires that I am not sure what they go to and they are on the same strand as the fog light and the outside temp sensor.
After taking some advice from a member on the forum I decided to wire the two blue wires together and see what happens.
My temp sensor immediately changed from always showing 122 to now showing -40 degrees.
What do you think the blue wires go to so that I can get this temp sensor finally working!
And yes my horn works when my car is on
Here are the pics! (the one on the far right is the mystery wires)
(I had to put the one that I took from the back side with my eyes staring at you cause that wasn't planned but turned out pretty funny)
Old 10-12-2009, 12:25 AM
bmwdave37 bmwdave37 is offline
What the.....?
Cars: Some
Are you sure both horns are connected? I'm pretty sure the two blue wires torn off by the ziptie are ambient temp sensor wires. The grey connector looks like a fog or headlight connector.
Old 10-12-2009, 11:45 AM
DavidF DavidF is offline
Cars: E24, E46, E38, R52
Send a message via AIM to DavidF
The blue wires are for the outside air temperature sensor. Twisting the wires together confirmed this when a short circuit took the display to -40 degrees (by design). An open circuit is +122 degrees.
Air temp sensor wire colors: BL/BR (blue w/brown stripe) and BL/RT (blue w/red stripe)
Your pictures show that you have the horn connected to the temp sensor. Possibility you damaged the sensor by apply voltage to it when testing the horn. The unconnected wire(s) are for the fog light.
Old 10-12-2009, 01:17 PM
fermunky's Avatar
fermunky fermunky is offline
I am NOT impressed.
Cars: 01 330i, Unicycle
Send a message via AIM to fermunky
Old 10-13-2009, 12:18 PM
Cars: 2003 330i zhp
Interesting, well when I installed the new temp sensor (where you see it currently located in the pictures) I pulled out the old one which was definately a temp sensor that had been beat up. That's why I have the temp sensor where it is currently installed.
So are you telling me that the previous owner tried to fix the problem and wired the temp sensor plug in to the wrong wires somehow?
What do you recommend I do?
I know that my horn doesn't work when its off but does when the engine is on if that helps...
Old 10-13-2009, 12:25 PM
I recommend you wire it correctly. You are probably just hearing the horn on the other side of the car (there are two horns). IT IS NOT WIRED CORRECTLY (sorry for yelling).
Old 10-13-2009, 12:26 PM
Cars: 2003 330i zhp
I am thinking I Should cut the wires to the sensor and wire them to the blue ones based on the info you have provided me. If thats a yes then what should I now do with the two wires that would be now cut and open?
Old 10-13-2009, 12:44 PM
Are you serious? Fix one problem by creating a new problem? Leave the horn and foglight wiring/sockets intact and fix the temp sensor wiring. Go to the dealer and get a repair pigtail for the temp sensor (part numbers: 61.13.8.365.340 and 61.13.0.006.665 x2)
Old 10-13-2009, 12:51 PM
Cars: 2003 330i zhp
I hate the dealer but I will do as you say... so the connector where I currently have the temp sensor plugged into should be plugged into my horn then is what you are saying? and the blue wires are supposed to be connected to a connector (which is missing) and have the temp sensor plugged into that?
I was just confused cause the old temp sensor was plugged into where you currently see the new one but the previous owner wasn't very smart I am beginning to realize.
Old 10-13-2009, 12:54 PM
I give up. Not sure how the above can be any more clear.
Old 10-13-2009, 01:20 PM
Cars: 2003 330i zhp
okay, I've done some searching and cannot find any pics where to plug that into the horn at. I'm guessing when I jack it up it won't be to difficult to find.
So when pull that temp sensor out of that plug will that plug fit right into the horn or do I need to cut the connector off?
Old 10-14-2009, 11:42 AM
What the.....?
Cars: Some
If in fact the connector is for the horn (it looks like it is) it should just plug in. then get the repair pigtail and connector from dealer, wire it into the two blue wires, plug in temp sensor, and you should be good to go.
Old 10-14-2009, 11:56 AM
Ok, since you (Moron328i) are going to ask anyway (and I am subscribed to this thread), the blue/red wire goes to pin 2 of the air temperature sensor. Now, just so there is no ambiguity, the other wire (blue/brown) goes to pin 1.
Old 10-14-2009, 05:54 PM
nathancarter's Avatar
nathancarter nathancarter is online now
You said 'Member'
BMW CCA Member
Cars: 2002 330i 118k
That was a little harsh. Not everyone sprang from Zeus's head fully formed, with a torque wrench in their hand.
Old 10-14-2009, 06:39 PM
What the.....?
Cars: Some
