Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Classifieds > Bimmer Parts For Sale sponsored by Bavarian Auto Recycling > Race Cars, Track & FI Parts
Race Cars, Track & FI Parts This forum is restricted specifically for BMW race cars, track parts and Forced Induction equipment.
Old 10-08-2009, 01:10 PM
BMMMW14's Avatar
BMMMW14 BMMMW14 is offline
Cars: GTS3 M3, 2009 135i
FS: '97 M3 GTS3/CM Racer
Price Drop - $SOLD! - still potentially interested in trades listed at bottom.
For Sale or Trade for Street E36 - Details at bottom
Well, after spending nearly a year and all of my resources putting together my dream machine, I think it is wise for me to sell it. I am not going to have time to race it, and need the money to fund a business venture. I have owned the car for almost all of its life, and its been great to me. It was sad, but very nice, to build a racer out of such a nice street car. It was built to go after the top of GTS3 and also be able to run in CM. Runs right at the limit of GTS3 with stock engine internals!
I only got it out on track one day, which resulted in laptimes within tenths of the fastest GTS3 cars in my group – this with horsepower being choked down by ~25 in order to run old Koni tires, and with no ABS. The potential in the car is huge to go out right away, or use it as a great base to really chase down the top spot. As its pretty new it could use a final weekend of sorting, but its pretty much ready to go run right away.
Its very clean looking with the interior painted with very tough white epoxy based paint.
In the last session on the day I spun the car and tagged another GTS car’s door with the front right, casuing minor body damage (nothing structural at all – I have pics before any work was done). I did hit the other car at full opposite lock so the tie rod required replacement. I am fitting a new nose panel, then fender really doesn’t need to be replaced nor does the hood – currently working on touching them up. Front bumper is in rough shape do to being towed through tall grass and the splitter grabbing. Anyways, the damage was cosmetic and not bad at all – just wanted to mention this because I don’t have the time to bring it back to showroom.
Body/Chasis:
-Built from clean 92k mile street car – At the Limit of GTS Power to Weight – With stock engine!
-2520 lbs. with ¼ tank – stock hood and trunk, rear doors skinned, front door gutted except impact bars
-AC system, Heater Core, OBD2 equipment all removed
-Custom cage ties in rear sub-frame and includes driver and passenger-side foot protection bars 1 ¾” DOM .095 wall
- Cage also tie to A pillars, B pillars, roof, and side sills.
-Rear shock mounts capped and tied into cage – ready for rear coilovers
-Front Towers have had reinforcements welded on
-Cage main hoop welded to roof structure, Gussets between B Pillar and Main Hoop, gussets between A Pillar and front legs.
- All Tar and most seam sealer have been removed
-All Non-essential wiring is gone and replaced – fuse/relay box is fully modular with Weatherpak connectors throughout
-Toggle Ignition, Fuel, Start, Lights, and Wipers.
- Nicely painted bright white with Epoxy paint
-Welded harness and sub-belt mounts
-Custom welded battery box with Braille 6 lb battery.
-Extra tabs/brackets etc. all removed. All Glass remains in place – front windows slide right in for transport/storage
-Rear doors close with Dzus buttons – all latches gone for weight savings – all 4 door can be removed in under 1 minute.
-NASA Logbook – Given NASA Annual Tech and Passed Inspection July 2009
-Passenger rocker panel cut out and reinforced with 3.5” steel tube for side exit – exhaust has Dzus tabbed lid with easy access to exhaust. SS turndown included – can be changed in minutes.
- Could still mount passenger seat
-Rear Spare Tire Well removed and replaced with aluminum panel
Safety:
- 10 lb. FireBottle Halon system
- Recaro Seat, side mounts, Fall-Line anodized floor mounts
- G-Force 6 point belts – new this year
- New window net
- Center net with quick release and thru-dash mounting
- 4-pole kill switch
- Custom Wiring – Toggle Ign, Start, and Fuel
- Momo 320mm race wheel with quick release hub – 1 day old
- Autometer Tach, Oil Pressure, and Water temp gauges mounted in custom black anodized aluminum
Brakes:
-VT Motorsport Backing plates
-SS Lines
-Fresh Full system bleed
-Converted to ’95 M3 ABS system – new hard lines for 3-chanel, ’95 M3 Pump, ’95 M3 computer
-Newer rotors (and some spares) Hawk pads
Engine:
-251 RWHP on Mustang Dyno – All stock internals!
- Full OBD-1 Conversion
- Recent Coil Packs $$
-Bimmerwold Restrictor Plate set
-Bosch Motorsport Wide Band Lambda with LED indicator mounted on dash
-S54 Oil Filter Housing, tapped with AN -8 fitting to -8 SS line going to S54 oil cooler (also tapped with -8)
-Oil Catch Can in place of separator, AN plumbing
-Custom AN Vanos oil feed line
-Plugs replaced 1k miles ago
-Evosport Pullies and new belt
-Saamco Silicone Coolant Hoses
-Dinan Carbon Fiber Cold Air Intake
-M50 Manifold
-Euro 3.5” HFM
-Turner Speed Sensor delete chip (4 tunes were tried on the dyno at Fall-Line to get this right)
-SS headers, custom merge to 3” Mandrel exhaust, 3” Borla muffler, side exit (passes sound at Autobahn) Sounds mean!
-92k Miles (owned for 65k of them)
-Never Gone more than 3,000 street miles on Mobil 1 or Royal Purple
-New Valve Cover Gasket
Suspension:
-Bilstein Group N Coilovers – 6 days since rebuild
-Turner Camber Plates
-Turner Sway Bars with adjustable links
- E30 M3 Aluminum Motorsport Control Arms
-’95 M3 Control Arm Bushings
- PowerFlex Rear Trailing arm bushings
- Balanced and aligned by Fall-Line
Driveline:
- Transmission and Clutch assembly replaced at ~ 60k miles under warranty at dealership
- UUC Trans Mounts and delay valve delete
- UUC Evo 3 Short Shifter
- Diff Breather Catch Can with welded bracket
Wheels/Tires/Spares:
-(4) Kosei 17x8.5 wheels – all in very good shape
-(8) Hoosier Koni Tires 245/45 17 – (4) scrubs still in box from Turner unopened – great lasting tires
-Some Front and Rear Rotors
-Radiator
-A few sets of pads
-Coil packs
-Injectors
-New motor mounts
Needs:
- New front bumper ( old one works fine, but it’s a bit rough)
- ABS wiring harness – I bit the bullet and changed over the hardlines, ABS pump, and ECU to a ’95 M3 system. All that is needed to complete is the harness (plug-in), which many people on the forum have sourced for about $150.
I am pricing this to sell quickly and not screw around. I know where the market has gone for race cars this year and I can’t believe I am willing to sell for this. $SOLD Seller Finacing Possible - I have over $24,000 into this in the last year to build in addition to ~450 hours of hard labor.
Will Trade + Cash - If you have a streetable E36 M3 mods or stock and thinking about moving to a full race car - save yourself a ton of money and headaches. Minimum cash to me would have to be about $5,000. Needs to be a manual trans, beyond that i am open to hearing what you have. I am sure there are some moving parts in the trade we can work out. Thanks.
Will be available to check out in the next few weeks!
Please email at the address in my sig. Thanks!
EXTRA Carbon Fiber Wing : The venture I am starting up is Brooks Motorsport Composites LLC. And am making very nice carbon race wings for E36/46 - I am running the first production batch for Feb-March delivery and will include this wing with the car, if my price is met. Retail is going to be about $900
Please see this link for one of the final prototypes testing on Scott. B’s car. http://brooksmotorsport.com/final_testing.html
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-08-2009, 02:02 PM
///M3Augy's Avatar
///M3Augy ///M3Augy is online now
Group B Fanatic
Cars: 98 M3/4, 96 318ti
Send a message via AIM to ///M3Augy Send a message via Yahoo to ///M3Augy
Damn. Free bump.
Old 10-08-2009, 02:25 PM
luv4myE36's Avatar
luv4myE36 luv4myE36 is offline
BMFH in hand
Cars: Dakar M3; Estoril MR
Send a message via AIM to luv4myE36
you don't want to trade for the same car in street trim+some cash do you?
-Mike-
SOLD
WTB: OLD/BLOWN PSS9 W/ OR W/O SPRINGS PM ME!!!
Old 10-08-2009, 02:59 PM
BMMMW14's Avatar
I don;t think i am really considering trades as I really need some cash, but send me some details of what you got. thanks
cage
exhaust
engine
damage
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-09-2009, 01:18 PM
cmargosi cmargosi is online now
Cars: 08 E93, 99 E36--S54
Tires
Want to sell those new tires? PM me a price.
Old 10-11-2009, 08:18 PM
BMMMW14's Avatar
All these pictures taken today, as you can see the damage was pretty minor - i have some more that i can't get to format correctly - will work on that. Replacing nose panel so, i removed the front end to give a good look as it is this moment, will put back together next weekend.
You can also see on my dash, there is a Bosch Motorsport wide band lambda meter, which i did not list previously. Also, as previously mentioned one of my wings will be included if the asking price is met. Please email me with any questions. Thanks
As you can see the fuse/relay box is gone. just two wires running from the x22 to the car. makes a ton of room in there, replaced firewall hol with carbon fiber blacnk plate. strut towers are capped with welded 16 ga. steel and where then painted.
as you can see the spare well is gone - which is handy because the diff fluid can be changed with out jacking the car. Also, make diffs swaps many times faster.
as you can see the inside damage ti the wheel well is minimal, non to the structure.
gussets to cage on A and B pillars
bumper - for you see damage - still useable but not all that pretty great spare-- reinforced inside wit hsome carbon fiber and resin.
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-14-2009, 11:48 AM
BMMMW14's Avatar
Bump - Buy the car at my price and get my new HANS for free :-)
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-17-2009, 03:40 PM
BMMMW14's Avatar
weekend bump
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-20-2009, 11:13 AM
BMMMW14's Avatar
Bump for price drop $13,750 for everything in post 1.
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-20-2009, 02:22 PM
savage217's Avatar
savage217 savage217 is offline
Dark Burgundy Metallic...
Cars: 95 M3 Track/Autox/DD
Send a message via AIM to savage217
Wow great deal. Good luck with sale.
Old 10-22-2009, 04:20 PM
BMMMW14's Avatar
Bump!
Brooks
'97 M3 GTS3/CM
2009 135i
Old 10-26-2009, 02:07 PM
aoH aoH is offline
Cars: 318ti
good seller, got my wheels, yay!
Old 10-27-2009, 06:20 PM
BMMMW14's Avatar
Tenativley Sold! I willl keep updated.
Brooks
'97 M3 GTS3/CM
2009 135i
