| 1983 - 1991 (E30) (1983 - 1991) Born from the sporty character of the 2002 and the sharp design lines of the E21, the E30 was a blend of the best of BMW's heritage. The second generation 3 Series provided a thrilling driving experience that used the best technology available. |
Thread Tools |
Anyone ever have cam one tooth off?
My 87 325is have approx 114k and reads above 150 psi compression on all but one cylinder which is only a tad below that. But, it only pulls 12hg of vacuum whereas another 87 325is (same mileage) pulled closer to 17hg.
The car doesn't run terrible, but it "lopes" while idling. Not violently, but constintently. I have no vacuum leaks, or at least none that could account for a 5hg loss in vacuum. Is it possible to have a cam out of time? I know how to check this but I want to know if someone has or has had the same symptoms. |
Yes it's possible. When I bought my 325ic four years ago, the shop I had do a timing belt replacement (bavarian professionals in Berkeley, CA) told me that skipped teeth (or sheared-off teeth) is a more common failure than a completely broken belt.
1997 328is, 90.5k-118.7k miles, Cosmos Schwartz Metallic
1992 325ic, 148k-162.2k miles, Lagunengruen Metallic 1991 535i, 127.5-136k miles, CalypsoRot Metallic SÜNDE REISEN |
The belt on the m20 will not skip a single tooth and continue driving the cam. If it skips at all, it's over for the belt. |
YOu can adjust the valve timing somewhat by adjusting the cam via moving it one tooth, I wouldn't do it more than that, I forget exactly how many degrees that moves the timing, but it's quite a bit. Advancing the cam will move the torque curve down the rpm scale some, giving it more low rpm grunt, at the expense of some top end power. Most of us could use more low rpm torque in our 325i engines.
Pat
Southern National Congress ____Quis custodiet ipsos custodes? Hostilis Civitas! _____The '98 Z3 1.9L + '90 325iCab, '87 535iS, '72 3.0 CSi |
I highly doubt you know more about this subject than a shop that's done thousands of timing belt replacements and works on M20s every day. But besides that, I've seen more than once on this very forum that somebody's found that their timing belt is one tooth off. Now htf do you suppose that happened?! Either they are complete idiots and set the timing wrong in the first place (possible) or the timing belt skipped a tooth (also possible).
Pat
Thanks for the feed back. Yes if the cam is off by one tooth it happened when I changed the belt three years ago. If the torque curve theory is correct, then I must have retarded the cam by one tooth because the car has good top end, torque is marginal. But would that confirm my loss of vacuum?
I had a lobe come off a cam in my hand.
That sucked.
Originally posted by pup "yeah. stick to pedophilia, racism, misogyny, homosexuality, the disabled and the poor"
Originally posted by Aindriu "It is made to be a crusing machine. Top down, cruise control on at Autobahn speeds, bit of classy music and an attractive woman in the passenger seat with the IQ of a peanut." |
| Bookmarks |
| Thread Tools | |
