| 1983 - 1991 (E30) (1983 - 1991) Born from the sporty character of the 2002 and the sharp design lines of the E21, the E30 was a blend of the best of BMW's heritage. The second generation 3 Series provided a thrilling driving experience that used the best technology available. |
Thread Tools |
why do i have a fog light switch if car has no fog lights stock
why is there a fog light switch to the right of the headlight pull lever? my 1985 318i has no factory fogs but has the button and when i press it the fog indicator lights up on the dash? help please.
Were they deleted by a previous owner?
Disclaimer: At any time, any single thing I say or do could be entirely or partly incorrect, wrong, or just plain in dramatic error. Take all comments, advice, and criticism at face value, and research all references I give in my posts. ![]() |
Get that VIN decoder guy to find out if the car was sold with fog lights stock. It could be like halmotors said and they removed them, or also, maybe the light controls broke and they replaced it with one from the junkyard that had fog lights. That's if they are the same unit rather than coming apart, I cant remember right now. Do you have wires that would connect to the fog lights?
A side note about the fog lights: If you leave the lights off, but the foglight button on, the lights will all be off, but one of the relays involved in that mess will stay on and drain a little current. Enough to kill your battery in under a month if you leave the car sitting in the garage, and way faster if the battery has been deep cycled before. |
I'm not sure off the top of my head, but there probably are. I only know about that one because it burned me pretty good. I thought I had an electrical short or something for a long time until I got out my multimeter and started measuring current when the car was off and various switches were on.
You're right, there's no current draw to the fog lights that aren't there. What he's saying is that if you leave the switch on, the relay windings will be energized and THAT will draw a few hundred more milliamps.
Are you certain that the relay coil remains energized with factory wiring?
On my model year, the relay current is switched through the low beam relay. Only if you do a sleazy bypass of the wiring to allow the fog lights to be switched on alone or with the high beams will the relay coil remain energized with the ignition off. About the original question: your fog lights may have been removed as a quick way to pass inspection or comply with a fix-it ticket. In Maryland you don't need fog lights, but if they are on the car they must work and have clear uncracked lenses. Yes, they are completely optional but you will fail the inspection if they aren't perfect. So the quick solution is to just remove them. |
djb2 is correct about the current draw. On an unmodified harness, there is no current draw when the foglight switch is left on and the car ignition is off.
"Never cared one way or another about BMW until I had to work on one... Now look at me." ![]() Things that move me 1986 Delphin 528e - Wife's car 1989 Zinnoberrot 325iX Sedan - My winter snowmobile 1998 Avus Blau 328iC - My topless summer girl with only 60k miles |
| Bookmarks |
| Thread Tools | |
