air silencer box
Hi there, anyone can please tell me what are the function of this box?, and what are de benefit to take off this box?
Thanks ![]() PART #12 ![]() PART #4 ![]()
![]() BMW, e39, 523I, 1999, M52TU, EURO SPECS, BILSTEINS SPORTS, OEM SPORTS SPRINGS, OEM M-TECHNIC AERODYNAMIC, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, Y RESONATOR DELETE PANAMA, CIUDAD DE PANAMA Last edited by jdjg; 09-29-2009 at 11:16 PM.. |
i was gonna be like "ITS FOR TEH HELMHOLTZ"
But its definitely not and I have NO idea what thats for, or where it attaches to
![]() Evolution created man and man created Religion to explain the creation of man in the absence of the knowledge of the existence of Evolution. |
It's a silencer for your intake. It quiets the air that is being drawn in through the intake tract. Somewhat like a resonator for an exhaust. Removing it would result in a slight increase in intake sound. That's it.
![]() BMW, e39, 523I, 1999, M52TU, EURO SPECS, BILSTEINS SPORTS, OEM SPORTS SPRINGS, OEM M-TECHNIC AERODYNAMIC, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, Y RESONATOR DELETE PANAMA, CIUDAD DE PANAMA |
hmm, some reading for you... http://planetsoarer.com/resonator/resonator.html
![]() Mods: 3.15 diff, high performance coil packs, 17x9" rear wheels, clear tails, K40 stealthed radar detector, 3" exhaust, Thrush 17661 muffler
wow sounds better/louder but i am not going to take it out if my performance is reduced. as I assume it would be. BMW wouldn't design a part that cost hundreds of thousands of dollars if it was to only quite it down.
![]() ![]() Old car->1992/E34/525iA/70k |
-Easy to remove the air box -Increase air flow, hints ( lounder ), the same reason as if you have a CAI or the same effect if you have a high flow exhuast system. If anyone thinks the silencer is tuned to engine performance then why did BMW decided to remove it on all E46 M54 engines? This is fact and not fiction, the reason that it is exist in the 5 series is because BMW treats the 5 series as a luxury car and therefore can not have any loud noise. |
Please enlighten me as to what your qualifications are for making that statement. I've studied engineering and have evidence contrary to your claims. It is not just there to make the intake quieter. My 318i even has a resonator. You are comparing apples to oranges. What it will do is shift the power band. Heavier cars are generally tuned for more low end power. BTW, "straight" is not best in terms of airflow. Look at the glass packs, they flow like crap and you can see through them. I suggest leaving stuff alone that you don't understand.
If you want the sound, go for it. I wouldn't expect it to make a huge impact.
By the way, what's your evidence (Just curious)? ![]()
![]() E39 Ugly Mugs________________________________Registry Photos
http://planetsoarer.com/resonator/Re...rsAcoustic.htm
^That's one of the better articles easily found online.
[QUOTE=Cyrix2k;17553730]Please enlighten me as to what your qualifications are for making that statement. I've studied engineering and have evidence contrary to your claims. It is not just there to make the intake quieter. My 318i even has a resonator. You are comparing apples to oranges. What it will do is shift the power band. Heavier cars are generally tuned for more low end power. BTW, "straight" is not best in terms of airflow. Look at the glass packs, they flow like crap and you can see through them. I suggest leaving stuff alone that you don't understand.
One word for you RUBBISH. |
That's quite the informed response.
16valex,
Why would you respond this way and not provide any other articles or evidence to support your claim? This is the kind of post that usually sends the thread down the path towards a lock. If you are going to refute a claim, please include some scrap of info. to back up your position. TIA ![]()
For exhuast resonator you want to keep it to maintain back pressure. But intake silencer (resonator) you want to remove hints CAI, super charge. If I have to save my job to prove it then I could probably done it by measuring the intake flow vs RPM vs speed with and without silencer. But 22 years in nanotech lithography machines my gut feeling is without the silencer will have a higher flow. |
BMW uses tuned intake & exhaust systems to increase VE. The intake resonator and that large Y resonator on the 540/M5 (can't comment on the I6s as I'm not familiar with their exhaust) are there to increase VE, not simply reduce noise. Also, one goal of a good exhaust system is to reduce back pressure. I don't know why this myth is perpetuated. A tuned exhuast system creates somewhat of a vacuum that helps evacuate the combustion chamber and helps increase VE. It is also true that a target exhaust gas velocity should be maintained - this is probably where "back pressure" comes in. It is NOT the back pressure that increases efficiency; to the contrary, it decreases VE.
some reading for you. Springer Handbook for Mechanical Engineering Quote:
and for back pressure http://my.prostreetonline.com/forums...ead.php?t=1639
With all due respect, I would reiterate what I said in my earlier post.
| Bookmarks |
| Thread Tools | |
