Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 09-28-2009, 04:29 PM
Cool 318ti Cool 318ti is offline
Cars: 318ti
Air Conditioning keeps blowing fuse!
I recently had the A/C on my 98 318ti serviced, the repair shop recharged the system and it worked great for about a month and the all of a sudden the A/C stops blowing cool air. I check the fuse to find its been burned straight through. I replaced the fuse turn on the A/C and with in seconds the fuse blows again. What's the deal? Why would it run well for a month then start blowing fuses like crazy?
Old 09-29-2009, 12:17 AM
e36ukengr e36ukengr is offline
Cars: 328is
Sounds like your compressor's going out. Mine does the same thing. You could put a bigger fuse in and it should work, but i wouldn't advise it...apparently it was good enough for the used dealership i bought it from though..
Old 09-29-2009, 12:59 AM
Brent 930 Brent 930 is online now
Idiots on my ignore list
Cars: 328is M3 Killer
Don't put a bigger fuse in it.
What fuse is blowing? There are several in that circuit.
Old 09-29-2009, 01:16 PM
fun2drive's Avatar
fun2drive fun2drive is offline
Cars: M-3 4dr/ 335 Convertible/M-3 Convertible
You compressor clutch is shot. You are better replacing the entire thing than just pull the clutch because the compressor will not be far behind...
