Hi guys
I have an issue with my driver site door activator
The issue is exactly as on this Video Tube - i can open my driver door only with the key ,
my remote doesn't work for driver side - no issue for another doors
http://forums.bimmerforums.com/forum...en+driver+door
It looks like some cable that will lose tension over time need to be readjust ...
Any DIY ? Pictures ? Part # ?
found door panel removal - nice !!!
[ame]http://www.youtube.com/watch?v=zEZ-bcEYdRA&feature=PlayList&p=7E4699CCF4F578DA&index= 2[/ame]
still need help with actuator ...
I thought it was "actuator" not activator. But either way, that is likely your problem. I just replaced one on a friend's Dodge Durango. I have had one replaced on my 540 way back under warranty...it was occaisionaly intermittment....looks like it is doing it again, and may be due for replacement again.
I am having problem ...
I removed door panel , i removed all bolts, cables but i still can't remove front door latch w/lock actuator
I have Bentley manual but i still can't get this trick hot to remove it from locking mechanism
What the PITA !! don't want to brake anything
Replaced !
I was not able to DIY so i paid 100$ to my indy
He said it was a pain job ...
Now i can open/close all my doors from remote key
but sometimes it works very slow and also range is very short .
Can it be a battery issue or it's related to keys ?
Both keys looks like work the same ...
Guys,
I just got done replacing my read driver side door actuator. I had to take the latching mechanism out to pop off the actuator. It went ok. Now I need to do the same for my drivers side front door. There is an airbag I noticed. Do I need to take off the airbag? Any thing I have to be careful about. I'm planning to disconnect the battery for this job.
GTMAN
Dinan, M5 F/R Swaybars, UUC EVO3 SSK, Koni FSD
i was not able to take actuator off
send pictures how you did it - interesting
I replaced also batteries in both keys , problem solved
