I got some complaints about my first attempt of a build thread, so I got my buddy with a DSLR to swing by.
The Car:
95 325is
Everything that matters is stock
The Goods:
M50 Block
Weisco 84.5mm 8.5:1 Coated Pistons from Max PSI
Eagle Rods
S52 Crank
Calcite? coated main and rod bearings
Arp Main and Rod studs
Supertech valve springs
Precision BB GT35R t4
Good&Tight top mount manifold
Synapse Wastegate
Progress thus far:
9/14
Block is machined, bored, and honed
Rotating assembly is balanced, and installed
Heads are being assembled, will be ready any day now.
Machining marks in ports are smoothed
All new engine bolts, studs, and nuts are ordered
Block is painted with KBS Black top
10/22
Radial valve job complete
Head fully assembled
Head mocked up
Turbo clocked
Oil lines cut, fittings installed
Waiting on engine bolts, timing tools
Thanks So Far:
Maximum PSI
Diamond Racing Engines
Good&Tight
A+ wish i had the money to do my motor...
You figure out why the ring was broken?
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Pics of their installer? I broke a ring with a SnapOn installed (has a non-contact point at the clamp-end of things) and bought a $7 screw-type compressor from Sears and had no more issues.. Reinstalled rings twice even :p
They sell them in .5mm increments. Just put some assembly lube on it and no more tapping with a hammer handle, you can just push down with your thumbs.
I did this with a craftsman adjustable sleeve compressor.
I pulled all the pistons back out, inspected all of them, and scrubbed the block clean. Once I got the the new ring pack and compressor they all went in without an issue.
If anyone wants to borrow the wiseco compressor lemme know, just pay shipping both ways. Just obviously it''ll only work with 84.5mm
I'd like to see the compressor sir. I've never had an issue with an adjustable sleeve, but I guess next time around I'll buy a Wiseco compressor, that sounds really simple!
it's just a tapered sleeve that fits the bore exactly.
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
'97 M3- GC Track/School|Spraco strut bar|X-brace|UUC Swaybarbarians|w/ VMC adj End links| UUC systemU|SouthBend stg5 clutch|Powerflex RTAB/LCAB|UUC Red Tranny mounts|M50mani|Greddy EBC|Innovate LC-1M52 Crank, Cams, Pistons, Rods:
pics of the Gutenteight manifold?
Not high res but this is what I could dig up.
The placement is pretty tight between the WG and turbo. I mocked it up in my friends car, and clearly there is no room for the washer tank, and I may be able to work something out with the ac lines. I have 3.5 flexible conduit laying around, so I ran that down the top of the manifold and between #4 runner and the strut tower, it's close but fits.
Here's one more pic of it.
Nice.
Looking good Brian!
85' Turbo M50 E30 | 95' M3 Nitrous, Coilovers, DJ Autos, UUC SSK
DON'T!!! I would imagine that during the welding process some slight distortion took place. When you separate the cylinders they are allowed to move into the distorted position. This would make it very difficult to get in place. Although in most cases having separate cylinders on the flange is optimal, the BMW M50 motors have so many head studs we really don't have problems with studs shearing with thermal expansion.
I just wanted to shave some weight...
Joking of course. I was kind of going back and forth with it because yes we do have a lot (24 if IIRC) of head studs, but it is a long flange, allowing for more distortion. I suppose the best route, although impossible, would be to cut it while it was in position, after one heat cycle it should distort to the proper orientation.
G&T there are a few people asking about your manifold on r3v.
what are you going to do about the heat with the top mount will wraping it be enough or you going to run a lower thermostat?
I already run a lower t-stat because the car had an fdm. Header wrap is being applied to the manifold, adhesive shielding to the strut tower and underside of manifold.
Over the winter or spring I plan on picking up a mishimoto rad and stewert pump. For now I'm mainly just concerned with getting the car up and going on low boost.
yea getting it running is always prioity haha i was just curious but sounds like you got that under wraps goodluck on the build
Pretty much if the car's not ready by the first time it snows (late october normally) I'm just going to go ahead with stage 2 and do full suspension, all new cooling, dpi meth, cams, and maybe just maybe a maxpsi manifold. The build is pretty much taking forever, but cash flow is low, and I'd rather not cheap out and get crap that's going to fall apart. If it's worth doing, it's worth doing right.
