| 1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury. |
Thread Tools |
my 92 325i i've slowly been restoring 56k warning
When I bought the car I couldn't open the driver door from the inside and the passenger window was off the track, fixed both and they work perfect now. car has 180k miles now and runs like a champ.
things I have done to the car electric spal fan metal water pump impeller bekkers coil over kit with ground control adjustable caster/caster plates aa track pipe aa gen III catback fidanza aluminum flywheel with sache M3 clutch blacked out tail lights new headlights and foglights with 5k H.i.Ds in both and orion v2 angel eyes car is on jack stands now because i had the subframe welded and reinforcement plates installed. I just installed the poly subframe bushings and differential bushings. Now the car has the m3 subframe, m3 3.23 limited slip, m3 rear brakes, and trailing arms. I have a new guibo and new slave cylinder for the ZF trans i'm about to install as well as the new poly mounts with the UUC enforcer cup things haha. I pulled the getrag out because I found out the m3 driveshast wont bolt to it. I'm waiting for the m3 ssk from understeer to come in and I should be good to go. ![]() ![]() ![]() ![]() ![]() i forgot to add the m3 front and rear bumper with diffuser and m3 side moldings Last edited by johncow; 09-09-2009 at 02:07 AM.. Reason: Automerged Doublepost |
The pictures are a little small. anyway these can be made larger?
![]() Looks like a great start!
| Bookmarks |
| Thread Tools | |
