Thread Tools |
Question for the E39 540i folks..
I recently purchased a 540i TB (OBD II, cable not drive-by-wire) for a project on my e36. I noticed the TB butterfly has added plates, which I suspect are for gas mileage, and added as part of the OBD II changes. Reason I say suspect is because the e36 line had something similar, but to the bore instead of butterfly. Question is... Has anyone removed these added plates in a quest for more HP/TQ? Its an obvious obstruction to flow. I did a quick search and found tons of posts, nothing in particular about this. Apologies if this is a frequently discussed topic. |
The "extra" throttle plate in front of your throttle body is for the ASC system. The throttle body is naturally in the fully open position and is used to limit engine power output in the event of ASC activation.
1st pic is the backside of the TB, fully open. 2nd pic is front, part throttle (showing the screw holes), 3rd is front, fully open. Pretty certain this was an OBD II change. Anyone remove these for a power increase? It will hurt gas mileage, and part throttle should be more reactive (25% throttle is more like 35% w/plates). A similar approach was taken on the e36 OBD-II cars, where they added a ridge to the bore. Last edited by creeves328; 09-08-2009 at 10:05 PM.. |
Indeed.
![]() I've seen those things on some of the 6 cylinder motors, and I've honestly never paid much attention to them. It's possible they were added for a vacuum port (again, I'm only guessing, since I don't have the throttle body in my hand) or for part throttle operation. They are certainly impeding airflow at full throttle. How much impedence is unknown, but it's probably minimal, and would not be something that would register on a butt dyno. However, if you're bored, and like to tinker, take them out and see what happens. Make sure to Loc-tite and/or stake the throttle body screws if you put the parts back on, or they may come loose and be inhaled by your engine. Last edited by CBi; 09-08-2009 at 10:19 PM.. |
^^^ For me, I don't think they'll make any difference, performance-wise, for my project (its an e36 m52 2.8L).
However, for those with a 540i and wanting performance, here are the measurements.. Total butterfly diameter = 3 1/16" Total area of butterfly = 7.36" WOT area, taking into acct area consumed by TB butterfly w/ plates = little less than 6.59" WOT, taking into acct area consumed by TB butterfly, W/O these plates = 6.97" So, you would gain roughly 5.5% total throttle body area, at the TB venturi (butterfly), without the plates. These measurements are estimates, I didn't mic these, but should be close. |
Addl Pic --- Closeup showing the joining of the butterfly and the plate. The combination is about 1/4" thick, and the butterfly itself is thinner than this addl plate.
Anyway, hope someone finds this useful. As I mentioned, it won't help me for my project, but if you want a Big Bore TB for the 540i, I'd check it out on your car. The Dinan TB has a new butterfly, and as expected, they never created new versions of these plates. Last edited by creeves328; 09-09-2009 at 12:10 AM.. |
That plate is actually somewhat important and I would recommend leaving it in. The plate increases apparent throttle resolution at low throttle angles. Basically, it gives you finer control of the throttle at low throttle levels. Removing it makes part-throttle application a lot less smooth. I have BTDT with a couple different VWs and did not like the results. There was no apparent increase in power and it just made part throttle "jerkier".
Richard
BMW Convert Let us redefine "progress" to mean that just because we CAN mod a thing, it does not necessarily follow that we MUST mod that thing. |
I doubt the intention was for smooth throttle operation as a performance mod. But you have to have a dme that is smart enough to adapt for the new air or get a reflash to allow more fuel for the additional air.
98 EuroSpec E36 M3 (SMG)
99 M3 Daily Driver 93 325is Track Car m52b28 with m50 head S52 Cams & Lifters, OBD1 Intake, custom exhaust, S52 headers converted to OBD1, Motec M600 standalone,(220hp/200tq on 20lb injectors) KW Racing Coilovers M3, M3 Fly/Clutch/P-Plate, BBS Modis wheels, Corbeau race seats w/ 5 point belts. 5 Speed conversion with 3:91 LSD. Yokohama Advan A048 MH Semi-Slicks. 13.7 @ 102 / 2.1 60ft on 225/50/16 road race semi's turbo coming soon Build Thread http://forums.bimmerforums.com/forum...1#post17395931 |
Happy modding! |
The only time this could be of any advantage would be when you exceed the flow capacity of the TB. IF the vacuum droips to 0 during WOT then there is no point or value to opening up the TB.
NNY528i, '97 528i, 156200 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler
BFC OT Lego Club #48 ![]() |
partially correct. If you used a MAP sensor to watch the actual manifold pressure you would see you are not getting maxium flow after 4500. You will probably see pressure numbers of 95-88 depending on what type of intake restrictions you have. I thought my car had 0 manifold vacuum under wot but was incorrect which i found the other night on the dyno.
The only time the vacuum in my intake manifold reads zero is when the car is not running. Should this occur during normal driving, then your gauge is incorrect. Fluids flow from areas of high pressure to low pressure. A naturally aspirated car will always have some deviation from ambient pressure in the intake manifold.
Richard
around peak torque i have ambiant pressure under WOT, after peak torque as closing to redline the issues in flow related to the filter, pipes and size of the plenum will cause vacuum to develop. Do some reseach on port tuning like formula one uses and you will see they use resonance to acheive 1.25bar which would be 3.625 PSI above atmospheric.
A good watch would be
Just go buy a big bore throttle body from Riot Racing, WestCoastRiots.com and have a simple bolt on with no issues
BIGman Looking to buy clean title E30. Even in crap condition. With manual transmission. In SoCal! |
| Bookmarks |
| Thread Tools | |
