Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Diagnostic Software
Diagnostic Software Do you need help with diagnostic software or have installation questions? DIS, INPA, EDIABAS, IBUS, CANBUS, CARSOFT
Old 09-07-2009, 11:39 AM
MadMonkeyMan MadMonkeyMan is offline
BMW CCA Member
Cars: BMW 520IT 2000
Question BMW SSS Progman with OBD interface
Hi
Now that GT1 is ok I`am starting one progman. does any one have a pointer to witch php file and tabel, to alter to get Progman to use ediabas / OBD ?
regards
mmm
Beer: The cause of, and solution to, all of life's problems.
Old 09-15-2009, 05:50 PM
randomy's Avatar
randomy randomy is offline
Roadrunner
Cars: 96 328i, 01 325xi
I would love to help you, but I can't seem to find SSS Progman for download, and I'm curious to try it myself.
Old 09-15-2009, 06:10 PM
infinkc infinkc is offline
Cars: some
not sure what you are asking, but i have it installed.
Old 09-16-2009, 12:05 AM
randomy's Avatar
Roadrunner
I'd like to obtain and install it.
Old 09-16-2009, 03:16 AM
invictus1 invictus1 is offline
Cars: E39 525TDS '98>175HP
Send a message via ICQ to invictus1 Send a message via MSN to invictus1 Send a message via Yahoo to invictus1 Send a message via Skype™ to invictus1
Guys , it's a long shot with sad story for some including me
I've just burned the CAS module for a '05 E60 Euro. i have used a generator of max 30Amps and took all the precautions but still bricked the car.
Don't get me wrong. I love challenges but now is getting so expensive :P i think i need a new module, new keys, new locks for the car and serious recoding. CAS module is something like the old EWS but ore secure and handle more security features. The car is completely dead without it. No lights on dash, no ignition , no central lock, no seats. like the car has no power. Only when you open the door of the trunk there is a light and the backdoors power windows works.
I've took the module to a guy to see if he can reprogram the flash inside the MCU. For that he needs the same firmware that it was originally before i started the Progman 32 update.
I'll post updates. but long story short: don't mess with Progman if the car works you may end like me! or not
Chris
Old 09-16-2009, 09:46 AM
randomy's Avatar
Roadrunner
Oh man that is the worst story I've heard on here. I will be oh so cautious.
Old 09-16-2009, 10:07 PM
Cars: some
Chris
what were you trying to do? What interface were you using with SSS?
Old 09-18-2009, 03:06 AM
trying to program the latest v32 software for the modules. it's an old car CIP v27. to do coding like disable seat belt warning i needed to be at the baseline with v32 for about 5 modules. it started to program over DIAGBUS and at the first module, error, red X.
i use VMware images for SSS/Progman v32 and another vmware machine for OPS head emulation (basically ediabas ifshelp32 with usb inpa interface 192.168.68.1)
Chris
Old 09-21-2009, 09:15 AM
randomy's Avatar
Roadrunner
Did you have to adjust anything on the SSS\progman system to connect to your OBD interface? This si what I am trying to acheive now.
I found this file on a polish BMW forum that has the modified fiels to use progman with the OBD interface. I have not yet tested it though: http://rapidshare.com/files/166005128/changes.rar
Old 10-14-2009, 08:37 AM
TheMatrixz TheMatrixz is offline
Cars: 540 IT
Hi Randomy
Did you try the emulator yet? I was wondering if it can help Carsoft working to a Can-bus car (E60).
Tan
<img src="http://members.roadfly.org/thematrixz/twin.jpg">
540IT, Dinan CAI, DME and Tranny software. M5 rear sway bar, M-Technik Aerodynamic, Phatbox, MBQuart all around.
528IT, bare bone stock.
07 530XiT, need this for bad NE winters.
Album: http://forums.bimmerforums.com/forum...hp?albumid=174
E39 540 Secondary airpump forsale: http://forums.bimmerforums.com/forum...0#post17763980
Old 10-14-2009, 11:33 AM
randomy's Avatar
Roadrunner
I got SSS working by using the script in the changes.rar file I linked to.
Old 10-15-2009, 08:38 AM
Cars: 540 IT
I got the ISO you linked, but I'm lost at what to do with those files. Could you explain where the files should go?
Tan
Old 10-17-2009, 10:00 AM
randomy's Avatar
Roadrunner
This is from memory, but it is something like this:
You need to edit the registry on the virtual machine to make the shell explorer.exe. Boot the virtual machine and it will load the Windows XP desktop. Then load the ISO as the CD drive for the virtual machine so that the contents of the ISO are visible in your virtual machine, and run the bat file that is on it.
Old 01-08-2010, 06:46 AM
siulian siulian is offline
Cars: bmw 525d
Hi randomy,
I also have SSS in vmware but i don't know how to open regedit ( because when windows starts is auto-lunching progman).
Can you tell how to avoid this ?
Best regards,
