| Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water. |
Thread Tools |
flamers come in!!! Fello made a top mount!hahaha
ok so i made a top mount.
it started by me making a jig out of a 666 top mount so i know were the flanges will sit. the manifold i made is by no means a good flowing manifold. i will be just using it wile i collect all the right parts to make a nice one up also wen i do make a good one i will allredy have a DP and oil lines ect... everything will match up. remember i will not be using this manny for a long time !!!its 4 mok up so here it is! FLAME AWAY!!!!!!! ![]() so 2day i installed the turbo witch is my good ol 50 trim. i then made a 2.25 mandrel bent hot side ic pipe.& a 3" mandrel bent down pipe. and here that is ![]() ![]() ![]() ![]() so thats it for now. ill post some more once i put the new motor in the drift car this week. feel free to flame & do what ever you want. i d say i did ok with on scrap peaces. i sent $0 on this hole new set up ![]()
![]() BFC #420-01 B.watts 4 Prez!!!!!!!! ![]() ![]() |
Could you post pictures of the manifold? Placement seems pretty decent.
One thing of concern, I'm pretty sure you installed your camber plates wrong... I could be wrong, but that's not the angle of any that I have seen installed or installed as per instructions myself. You need to rotate, at least the passenger one, one hole counter clockwise.
![]() 2008-2009 Turbo/Motor Build Thread - 382whp/402wtq & 12.8@116.6 | 105k M52 Engine Part Out - LOTS OF PARTS! | S52 Engine Parts For Sale
as far as the camber plate . this car has a Tweaked strut tower from a incident & that was the only way we could get the camber & caster to match up. also redrilling the tower & adding shims down at the strut
Try running the MAF as blow through maybe?
haha its copper paint. i sprayd it wen i did my sisters m3 rims .
i use mild steel for all IC pipeing. the hotside is caremic coated. its a TMR tune u think it would run ok? i keep hearing people talk about it but never seen a good answer.
![]() BFC #420-01 B.watts 4 Prez!!!!!!!! ![]() ![]() Last edited by The Fello; 09-05-2009 at 11:51 PM.. Reason: Automerged Doublepost |
I smell melting plastic all the way over here.
how is that 50 trim working for you?
"...I mean, at Westboro, they are just afraid, and it makes sense. If I want to sleep at night and assure myself I am 'going to heaven' and that God loves me, the easiest way to go about it is to rationalize why everyone different from me is 'going to hell.'" -The Words of Ryan Brock, The only Christian who can make a atheist feel good about a religion. |
im thinking the same . im going to rum a OBD1 valve cover but still think that might not do it . i m also going to head rap the DP i will start looking into making a heat cove for it to.
yes sir! i like it spools up at around 2800 and keeps pulling . i allways ran it at 15 PSI but on this build im going to keep it at 10 since it will b my DD
![]() BFC #420-01 B.watts 4 Prez!!!!!!!! ![]() ![]() Last edited by The Fello; 09-06-2009 at 12:02 AM.. Reason: Automerged Doublepost |
Sweeeet!
1997 BMW 328is
5000k HIDs|DDE Thinline Angel Eyes|M3 Front Bumper|Unleaded Fuel Only Sticker Delete Mod Entire M52 worth of parts for sale! http://forums.bimmerforums.com/forum....php?t=1273951 Cheap deals! (promise )
e36 top mounts are difficult... Im glad I will be doing this in an e30 with more room.
Good job, lets see the mani naked! Take the wrap off and show us your bird turd welds! ![]()
From this
to this. Teaseruzuzzz///M3 Widebody > http://www.e30tech.com/fFromorum/showthread.php?t=71901 |
i placed the WG were the compresor should go.on the real manni im gonna build im going to make it AC friendly. as far as the naked manni. it doesnt look THAT bad. yea its bad but it will work for a month or so. my welds have gone a long way, since i worked at a fabrication shop & learnd how to weld properly
nice work fello, Im glad it worked man, we are always moving forward
Signature Disabled - Check the Signature Rules... Fix your signature FIRST!
Afterwards post in the signature/avatar request thread in the forum suggestions forum. |
| Bookmarks |
| Thread Tools | |
