| Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water. |
Thread Tools |
More Parts have arrived for the water/meth kit
This is what was set up when I got the car into my possession.
Which had a few leaks. So I had Jeff Howerton from Howerton Engineering make me a nice tank set up and it arrived here at the house.Tank fitted in place in the trunk Tank with level fitted no leaks It gets hot in the engine bay , melted Aquamist feed line a bit underneath this wrap So this DEI product is on it's way from Summitt racing and this for under the car Then the wiring is a mess ,electrical tape everywhere Then the mess in the trunk Then the way the Feed line from the Aquamist reservoir to the engine bed The new floor mat for the trunk will be here next week ( I hope ) as well all the other parts and then the final install will happen.....The before and after pictures will be here for you to see. NOW I have a Drum of M1 on it's way and a drum of Distilled water on it's way. SO all you experienced chemical engineers out there , what volume of meth do I use to what volume of distilled water to get an actually 50-50 mixture as I know the specific gravities of the two are different. I have been instructed by Mr. X tuner extraordinaire to not raise the AFR when adding the system and work on the formula until no afr changes happen as to not run the system richer.... I might get the tubing all run this week end as I am replacing it all from the High Speed Valve back to the trunk , pain in the rear front left tire has to come off as well as the lining and the under panels all come off. I did find a good source for the M1 in a barrel and distilled water in bulk as well... Enough said, off to sleep I go....
very nice stuff, i'm diggin the Howerton tanks......also wondering about the mix volums, i'm sure you can find a chart somewhere??
Last edited by HiTheNameIsBj; 09-05-2009 at 04:25 AM.. Reason: explained it better |
I just use the windshield washer location for my WI (next to windshild on E34). When windshild gets dirty, I pull into a gas station.
![]() ![]() The start- 4.9L M62 S/C German Muscle |
I am still waiting on bits and pieces to get this project done so I am going for a drive to get the car rinsed off at the touchless car wash in town.....
I am not worried about the methanol as a caustic chemical and actually it cuts the cost of the Water / Meth considerably. I have a business partner that still owns a boat repair facility and that is where the Methanol will be stored in the drum , next to the toluene , next to the methyl alcohol , next to the drum of west system epoxy etc... I built boats for years and was around every poison chemists could create and if you wear the proper garb it is not a problem. I promise I will be very careful and actually the mixing shall occur at the local community college.
Very nice Dave!
![]() Howerton makes this all inclusive setup. Is this what yours is going to end up looking like? How are you feeling? If you're messing with the car I'm guessing, and hoping, much better. ![]()
That does sound a bit like a benzo withdrawal. I feel you're going the right way about over coming it. Just don't push yourself too hard, I'm sure you can obviously feel when you can.
I'm looking forward to this last stage David, and then some sweet videos & pictures That one on the grass is pretty.![]()
![]() 2008-2009 Turbo/Motor Build Thread - 382whp/402wtq & 12.8@116.6 | 105k M52 Engine Part Out - LOTS OF PARTS! | S52 Engine Parts For Sale
..... Off to bed I go , 4:30 am is really early I am finding out.....I messed around with some pictures of the Aquamist system as I found the set up when the car was returned August 1 , 2009....... I had to take a break from my quarterly tax crap that I am trying to fill out.... http://s230.photobucket.com/albums/e...t=9cf2a5c6.pbr I will have the after pictures as well in a week or so if I am lucky......
You should hire me to take some pics, since the car won't be driven too much because of all that rain you'll be getting
![]() Glad to see all of the botched parts being fixed up now we need a 60-130!
More pictures when I get more parts installed.... I will get you some day to do some more shots of the car......
Sounds good to me, eventually I'm sure I'll either be making a trip down to FL or flying down there and driving back up, so I'll definitely be getting in touch with you to meet up
Not much done this week
I did not receive the parts from the BMW dealership nor did I receive all the other parts so this week was kind of a wash as far as the Water / Meth goes but , I did notice that my oil level in the car was vacillating up and down by 3/4 of a liter ( it would register full and then 3/4s of a liter over full) and so I am pulling the accusump system apart as well to check it out , so I am dumping the oil today after I go for a short easy drive.( I just pumped 1 liter of oil out of the engine , now it reads 1/4 of a liter shy of the full mark )Hopefully next week the rest of the parts will show up.....
FED-X arrives with the BMW parts today on a Saturday.As it has been true to this car they sent the wrong piece for the trunk.....Plus ICS does not look like they are going to come to the window on the parts to correct the Aquamist nor the panels in the trunk that got trashed as they have not contacted me since George emailed me that email about taking care of the parts, oh well....
-G
![]() GeorgeKakaletris@gmail.com (203) 653-2394 ICS Performance www.ICSperformance.com Technique Tuning Authorized Dealer and installer. Custom software available. Authorized HKS Dealer and Pro Tuner. Latest ICS Performance Stage 1 Dyno Video. http://www.youtube.com/user/Icsperformance |
What type of valve are you using for the accusump? |
I only use the system as a pre-oiler. Unfortunately the switch for the system was not tied into the ignition and I left the switch on the other day and I went to check the oil before starting the car and the car engine was flooded with oil. Ever since then the amount of oil has been inconsistent at the volume left in the engine.So today a short drive with the wife and then all the oil is going to be dumped and the system is coming apart. For some reason there is no pressure relief valve on the reservoir it's self and Canton Racing is mailing me one. Then when the New Trunk Mat gets here the whole trunk , Aquamist system and the accusump system will be put back into the car in a week or two....
24-270 - ACCUSUMP ELECTRIC VALVE KIT (24-270) Electric Accusump Valve kit provides a convenient way of operating the Accusump. They are useful when the accumulator is mounted in a hard to access location. When wired directly into the ignition switch the Accusump can be operated automatically to provide pre-oiling. The kit comes with the electric valve which has 1/2" N.P.T. female threads, a 1/2" N.P.T. pipe nipple, a toggle switch, a length of wire, terminals and installation instructions. Recommended for use in street and pre-oiling applications only. For the convenience of an electric valve in racing applications see our EPC electric valve listed below. Quote:
The Crystal Coast.
The replacement parts arrived from BMW just now I am just missing the heat shield from DEI.The parts to replace the panels in the trunk with their fasteners. I will have it together all the way to the engine this weekend ( I'm dreaming ) and have pictures of after I get finished..... All I got completed was running the 6mm Aquamist line through the 1/4" vacuum hose. There are a lot of abrasive edges as well as the AN stainless steel braided lines and since I am running a new single line ( No Unions under the car ) from the trunk mounted reservoir tank to the High Flow Valve in the engine bed I thought it better to protect the aquamist line from any possibility to be harmed. I know Active uses 1/4" braided line for their water/Meth applications , this cost me .50 $ a foot and a little grease....... Forgot to add this picture before I went sailing.... ![]()
| Bookmarks |
| Thread Tools | |
