hooRAH, thanks for askin about status.....
So we get over there and check the general condition of the car. Pretty nice ride...straight body, with a above average interior. Pop the hood, and it was obvious made his engine stop running. The radiator was cracked (I think thermally stressed due to excessive heat) right at the hose connection. Not the hose, but the actual radiator, where the hose attaches.
We asked, "man....what would cause that?"...so we're looking around som more and see that bot belts are broken. We pull out the long serpentine belt, and the belt is brand new, shows no evidence of wear, but is sliced as if by a knife. We pull out the other hose for the AC (which didn't work prior to this), and this belt is severely worn and cracked and is also broke. He said all of his S1 and S2 inspections are up to date...but I can tell you....that belt probably had 100k on it...just sayin.
So....what I think happened was this.
THEORY
1) AC stops working....still don't know why (could be clutch, compressor, etc....)
2) AC Belt never changed out...gets old, and breaks.....
3) Broken AC belt slices through new belt running accesory belt, that drives water pump.
4) Water pump stops turning....car begins to heat up...he keeps driving for 5 minutes and the engine temp was too great for the coolant expansion tank joint ....
5) At this point he either blew head gasket (but there is still oil level in the car), melted the top of the pistons, or cracked block.....don't know for sure...
INDICATIONS ON SITE
~Oil level was present...though dirty...and a little lower than normal.
~Obviously no coolant remaining.
~Oil was present below car in driveway.
~Car did turn over once...but battery died.
~No stored codes...mmmmm
After this happened we asked him what the first light was that he saw, when this was all going on, and said his battery light came on first (this musta been when the accesory belt got sliced)....soon thereafter....check engine.....coolant temp went high then low as he blew the coolant outta his car.
If anyone has any goo advice where to get a rebuilt or used engine...please let me know.
Apppreciate all the help thus far, and will post pics (I have a bunch) tomorrow, while Jason is doing his VANOS in my garage...hehe.
Pics as promised......
More...
Wow, bad day for the owner! The last pic shows the idler pulley in the center. It has very heavy fretting/wear on the pulley where the back of the belt contacts it. This looks unusual to me. Maybe, this pulley seized and caused the belt to break. Try to give it a spin and let us know. I'm Curious.
Also, do you know the motor is kaput? I would expect there to be an overfill of oil due to coolant in there? Not always, but most of the time. Why not replace the belts, radiator and hoses and give it a try? Just get some used stuff for now. Cheaper than a new motor! Even if you have to replace the head gasket and plane the head, still cheaper.
+1 on the above-----may be able to just fix it all up and drive off--if it's a 528, that would mean that it has a cast iron block--that type of block can be fixed up with a head gasket and last--alu blocks are problems when refurbishing--the head bolts sometimes strip out when doing the reinstall.
+1 on trying to see if the engine IS really seized/damaged before you start looking for a replacement.
You might get away with a cooling system + belt overhaul.
Also, that pulley mentioned by stoopid above definitely does not look right- I'd be curious to know what caused that wear.
The 528 for '99 and '00 (I think) had the M52TU, thus dual VANOS and aluminum blocks. I had my head gasket replaced this winter with 250,000kms on the clock and no issues with stripped threads. Don't tell anyone, but it only cost me about $600, including parts. Working like a top ever since... well, er, other than the two rear wheel speed sensors, fan clutch, vanos seals, cd changer... ;-0
Did they mean hold no compression in the cylinders, or hold no pressure when they pressure tested the coolant system? If it is the first one, that ain't good! If it was the second one, I hope they noticed the big hole in the radiator hose!!! LOL!
Does anybody see anything wrong with this photo? The arrow is pointing to where there is supposed to be a pulley. All that's left is the hub and inner race of the ball bearing. My guess is that the pulley failed (well, actually, it was the bearing that failed and caused the pulley to depart the engine).
The exact same thing happened to my wife's 2000 E46 323i with basically the same engine. Bearing failed, pulley went flying, belt got shredded, battery light came on, car began to overheat within 30 seconds. Fortunately I was behind the wheel and had the presence of mind to shut it down. In the end, no damage was done beyond the pulley and belt.
Those pulleys are crap and in addition to the one in the E46, I've replaced one in a '99 528i, my E36 M3, and an '05 325i.
1998 ///M3/4/5 | 1999 528iT | 2003 Z4 3.0i
My view is that the pulleys and tensioners should be replaced with the entire cooling system by about 100k miles. It is about $600 in parts to do it all and takes much of the day for a first timer, but that is much less than the ultimate cost of deferring the maintenance.
The E39 are great cars, but they were $40,000 to $60,000 new and you should expect to have to put a few thousand in at their "half life." In addition to the cooling system, the suspension usually also needs attention at about the same point and one can easily spend $1000 on parts (shocks, mounts, bushings).
Well said! It's just a fact of life that pretty much all BMWs built since the E36 3-Series in the early '90's have a 100K mile cooling system. Replace it at that interval or deal with the [very expensive] consequences.My view is that the pulleys and tensioners should be replaced with the entire cooling system by about 100k miles. It is about $600 in parts to do it all and takes much of the day for a first timer, but that is much less than the ultimate cost of deferring the maintenance.
The drama at the expansion tank is likely a result of the pulley failure. When that thing lets go, it starts a cascade of failures.
Honestly, though, I am a little confused about something. Has the car been sitting for a while after the "incident"? The remains of that pulley look pretty rusty - as if it's been that way for awhile. The one in my wife's E46 was highly polished after it failed. Or is it just the way it looks in the photo?
No...he drove it right till he end.....I took the pics maybe 4 days after the event occurred (I guess it coulda rusted then). He did mention his AC didn't work though(for probably a year).
Having it towed this week to my house for the engine pull. Still looking for advice on a tustworthy place to get a good rebuilt motor
