Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > MINI (Cooper & Cooper S)
MINI (Cooper & Cooper S) (2001 - current) The rebirth of a classic. The MINI is a blast back into the past when the Austin Mini was king of the small car world. BMW in engineering, but British in the design, the new MINI has many more changes from Austin’s Mini than just the capitalization of its name, but is not without it’s tributes to the old Mini, like front wheel drive, and a body so compact it seems impossible. But fear not, unlike the old Mini, the new MINI is able to sit people as tall as 6’6.
Old 08-22-2009, 04:27 PM
Teal94gt50 Teal94gt50 is offline
Cars: '94 Mustang 07 civic
Looking into a used S.. things to watch out for?
Hi all. I own an '07 Civic EX coupe as a daily driver, and I've gotten bored with it. It's not a bad car, just too mainstream for me, lol. Anyhow, I own the car outright (original owner) and have been contemplating getting rid of it for a used Cooper S, probably at least an '04 Model year (looking to spend no more than 15K)
Will these cars last at least 170K miles without anything major happening like the Hondas? I haven't seen a mini cooper for sale with much over 100K, so that might be uncharted territory.
Is there anything that is a common expensive problem with them (S model) I am an Auto Tech for a living, so I know my way around a car, just looking for an area of concern ahead of time.
I have found an '04 locally w/ 85K miles with intake/exhaust/ecu and 3 sets of wheel factory/summer/winter that appears to have been well taken car of for $13,000... too much or too many miles?
Thanks for any help and insight!!
Will
Old 08-25-2009, 11:37 AM
siuformula siuformula is offline
Cars: Mini Cooper S '04
I have an '04 S and i absolutely love it.
Things that i don't love.
*The battery clamps. I have broken 2 of the T bolts and you will not find them at the local parts store.
*The runflat factory tires are way expensive and have less than desireable treadwear for the spirited driver
For $13k and with 3 sets of wheels. I would snatch it up quick
Old 09-03-2009, 01:30 AM
Nanajoth Nanajoth is offline
"Dead Last" 2008
Cars: 87' BMW 528e
Make sure both of the xenon headlights work.
Old 09-03-2009, 04:28 PM
beken beken is offline
Cars: 2006 BMW 525i, 2005 MINI Cooper S
The supercharger was built to last 100k miles. Many have lasted longer. But the S/C also drives the waterpump. There have been reported water pump issues as the car ages that have turned out to be a problem caused by the oil seal of the supercharger shaft that drives the waterpump, or something in that vein. I do not know of anybody personally that has run into this issue yet.
Secondly, check the power steering pump fan under the car. It should be working. But it does not have anything covering it so many don't know it has failed. In the early years of MINI (2000-2004), the power steering pump and fan circuit was also the radiator fan circuit. If your rad fan is not working, your engine can overheat if idling too long in summer rush hour traffic. I have seen one car where this happened, the dealer fix was to switch the rad fan power to a separate circuit. It was covered under warranty. However, a 2004 would be out of warranty but you should check if the MINI dealer will cover it as a recall or goodwill from MINI if it hasn't been addressed already.
If everything checks out, that sounds like a good price.
2006 525i, 2005 MINI Cooper S
