Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 08-13-2009, 12:54 AM
hooRAH hooRAH is offline
Cars: 93 525i 5spd / 01 330Ci 5spd
Send a message via AIM to hooRAH
Carsoft - if you haven't looked in awhile, look again. This thing is neat!
So a long time ago, I looked into a carsoft solution for my E34. It was....odd. You needed 2 serial ports, the computer couldn't be too fast, and it was in german only. No thanks.
I recently took another look at it and it has come a long way. Without going into too many details (as there is a whole other forum for this), I am extremely pleased with the result. I can read quite a few computers in my 2001 330Ci.
I bought the unit because I had an airbag light on and wanted to diagnose it without taking it somewhere. I read the light, reset it, and it immediately came back, within 10 seconds.
Because I had recently replaced the seatbelt tensioner within the last 15 months, I thought it was odd it failed so early. I dug under the seat and wiggled some of the wires around. Reset the light again, and now its staying off.
So, with multiple reset ability (rather than just taking it to a shop) I've been able to tell that the error is actually pointing to a loose wire rather than a failing tensioner, I think anyway.
I was also able to read the memory in the DME, the instrument cluster, the ZKM (whatever that is), the ABS/ASC system, and a handful of others. The ABS/ASC will be handy if I ever lose an ABS sensor.
If you want to read more about it, DJ Genius has a review thread in the E36 forum, and theres a lot of info in the diagnostic software subforum.
One last thing - anyone in South Florida is willing to come by for a read/reset for just beer money.
93 525i 5spd - SOLD / 01 330Ci 5spd / 98 Camry / 91 Volvo 240
Old 08-13-2009, 12:59 AM
Phillips0417's Avatar
Phillips0417 Phillips0417 is offline
3D RC Heli Pilot
Cars: E36 RIP..01 330Ci
Good info! Just had mine reset from the dealer when I had my lcm flashed for bi-xenon. Hasn't returned.
Old 08-13-2009, 09:59 AM
I don't think I can do any flashing with it to change the light type, but I'm not sure. There are a few sections for "coding", which I believe refers to putting a new DME/airbag/ABS computer in the car and writing the information from the old one onto the new one, but I might be wrong about that. I just got the setup yesterday and haven't played around with it.
Its also got a handful of other features, definitely going to have to explore what I can do with this thing.
Old 08-17-2009, 06:14 PM
nathancarter's Avatar
nathancarter nathancarter is offline
You said 'Member'
BMW CCA Member
Cars: 2002 330i 118k
Thanks for the info! Keep us updated as you learn new tricks...
Old 08-17-2009, 10:54 PM
moonshine motor moonshine motor is offline
Cars: 84 325e, 02 330ci
I have seen a few references to the car soft scan tool. Is this a PC based unit or a stand alone? I am having problems between my EWS and the DME. Is this something that this scan tool will cover? Where can I get one and how much $$ . Thanks
