Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 08-07-2009, 05:07 PM
yeomgon's Avatar
yeomgon yeomgon is offline
License Suspended
Cars: E46 325i E36 325i
Stroker Project Final Check up
After months of talking I've finally managed to gather all the parts I THINK I need to do this project. So here it goes:
M50TUB25 Block
M50TUB25 Pistons X 6 ?
M52 Piston Rods X 6
S50 Crankshaft
24# Injectors X 6
Misc. Gaskets
ECU tune from AA
Dr.Vanos Stage II
and
MLS Headgasket(not purchased yet)
So this is a Vanos 2.9L stroker based on 325i using S50 Crankshaft. However, I have three more questions that I need to take care of.
1)I am thinking of boring the cylinder into 84.48mm, whilst using .48mm oversized piston rings on M50 Pistons(84mm bore). Would it be wiser to not bore it and go with the standard size pistons?
2)To my calculation, the piston will stick out 0.4 mm out of the block. Therfore I am planning to shave the piston by 0.4mm. If I use stock headgasket my compression ratio would be closer to 11.8:1. Which headgasket should I need?
3)Is there something that I am missing here?
DRIVE LIKE HELL.. YOU'LL GET THERE!
Old 08-07-2009, 05:40 PM
TCarlisle's Avatar
TCarlisle TCarlisle is offline
Cars: 1997 328is
In your calculations, have you taken into consideration heat expansion? If the piston sticks out of the block and you shave just that amount, what happens when it heats up and things expand? Also from below it sounds like you might end up with a lot of pisto to cylinder clearance. A machine shop might be able to tell you what the clearances should be.
My pistons are notched to creat clearance for the valves. So if I were to stroke it and just shave the surface of the pistons, if I didnt also increase the depth of the notch I would smack a valve. Has all the homework been done on all this?
Thomas
1997 328is -- Arctic Silver w/Black Interior
Performance Mods:
S52 Cams / M50 Manifold / Conforti CAI / Conforti Shark for S52 Cams / Borla Exhaust / UUC Pulleys / ASC Delete / Fan Delete / Bilstein + H&R Sport / Turner Adjustable Rear LCA's / UUC RTABs
Audio Mods:
Headunits & Sources: Pioneer Premier DEH690UB + XM Satellite + iPod into Rockford Fosgate 3Sixty.1 Sound Processor
Amplifiers: Soundstream 1002, Audiobahn A4801T
Speakers: Subs -- (3) Soundstream Exact 10" / Rear -- Polk Audio db 6500 / Front -- Soundstream Exact 6.3
Cosmetic Mods:
Clear Tail, Corner, and Side Lights / M3 Style Rear Diffuser / Bumper Trim and Side Moldings Painted Arctic Silver / Sport Package 16" Wheels Refinished
Old 08-07-2009, 07:46 PM
yeomgon's Avatar
License Suspended
I am thinking that the stock clearance calculation has taken the heat expansion issue into consideration, right? Since my calculation is based on the stock clearance, heat expansion won't be too much of trouble. Now, after hours of thinking I still can not decide which headgasket to use. Although the thickest I can find is 3.98mm, the thicker it gets the lower the compression. My goal is to have a CR of 11.3~11.5. I am squeezing numbers in but the only problem is that I do not have any data as how the HG thickness will affect the CR ratio. All of my calculations are based on 'if' the HG is at stock thickness.
Anyone else might want to add to this...?
