Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1988 - 1996 (E34)
Old 08-07-2009, 03:35 PM
TGreene TGreene is offline
Cars: 1989 535i
Rusted exhaust pipes - what are my options/(question mark)
I have the exhaust off of my car, but it is at my friend's house. I don't have any pics with me, but I will get some later.
All I have to show you the problem is this short video. Hit play then pause immediately and you will get a blury picture of the problem.
Does this look like something that could be patched/
I am really trying to conserve, and want to save money wherever I can, so if you were a poor, unemployed 22 year old, what would you do/
Fighting soccer moms and punting deer since 1989.
Old 08-07-2009, 03:39 PM
billygoat777's Avatar
billygoat777 billygoat777 is online now
inspiration.
Cars: It's older than me
Straight pipe it?
Would you mind taking a video of your car running with it off?
1990. 535i. 5spd. Bilstien/Eibach suspension, RD front and rear sway bars, RD engine strut brace, S3.64.. clearcoat fail
Old 08-07-2009, 03:47 PM
Binjammin's Avatar
Binjammin Binjammin is offline
Relaximus Maximus
Cars: 1990 e34 535i, 1991
Send a message via AIM to Binjammin Send a message via Yahoo to Binjammin
need better pics to judge, but if they're totally rotted out you can have an exhaust shop make something work for really short money.
had to turn VTEC off or I could dead
Old 08-07-2009, 03:52 PM
Cars: 1989 535i
I will get pics up soon. I called the Midas near my house, and they said that putting new pipes between would be $300+ for pipes and labor at $90/hour.
Old 08-07-2009, 04:08 PM
Binjammin's Avatar
Relaximus Maximus
Find a place that isn't a chain, you'll get a much better deal at an exhaust indy.
Old 08-07-2009, 06:33 PM
Stir Fry A Lot's Avatar
Stir Fry A Lot Stir Fry A Lot is offline
No Chromo
Cars: '89 535im, '05 325ia
This. Also Walmart employee's have the same passion for your car as a Midas employees. Sans David.
-Miller W.A.R. Chip / Miller MAF conversion / 22lb Injectors / 25,20mm Sways / S3.73 LSD / Glasspack Exhaust / Bilstein HD's / Vogtland Springs
17 x 8.5" RD RGQ's / 245,45,17 Yoko S. Drives / Delrin Inserts / e60 SSK / Clutch Stop / Weighted Shifter / e30 Mtech Wheel / 9005 SS Ultras
8gb JVC HU / Ported 12" Alpine Type R sub / 1200w Sony Amplifier / Bluetooth Handsfree Adapter / Cup Holder / Cosmetic Mods
Old 08-08-2009, 09:17 PM
bam240sx's Avatar
bam240sx bam240sx is offline
hittin it sideways
Cars: 94 525i, 95 240sx
Send a message via AIM to bam240sx
you dont need an exhaust just run straight headers
havin fun when the time is right, and when it isnt
Old 08-08-2009, 09:50 PM
janders211's Avatar
janders211 janders211 is offline
Cars: NA, Turbo, and SC'd
I thought that was a good idea way back. It really gives you an appreciation for how much mufflers do.
Old 08-09-2009, 02:24 AM
nevi525's Avatar
nevi525 nevi525 is offline
Cars: e36/46/34 k2500 5.3
imo i would try a monroe ar cole muffler. midas seems to be the least reputable place around here, although not sure how they are in your area, i would say if it is that hole i see, than might as well get both of them replaced. i know it would cost you here about 70 smackers if that
Old 08-09-2009, 04:09 AM
skylinergtr's Avatar
skylinergtr skylinergtr is online now
BMW CCBC Member
Cars: 95 530i, 91 Jeep XJ
when i did my custom cat-back midas tried to charge me nearly $600 in just parts and labour not including the labour. I went to a custom shop near the shop i work at. He was kind enough to charge me $350.
1995 530i - Cosmos Schwartz Metallic - Staggered 18" Beyern Mesh wheels -Bridgestone/Nexen Low Profile Rubber - Resonator delete & custom cat back exhaust - magnaflow 14815 sport muffler - K&N filter - wokke 2000 chip - 540i MAF -clear corners, tails and signals - full red sidmarkers - 8000k HID's - JVC deck ipod ready - clarion speakers - bilstein sports/cobra lowering spring - Bosch Design III 19lb injectors - B40 Dinan Intake manifold & throttle Body - BavAuto Performance Coils - ACS rear valence -Entire Cooling System NEW! - lots of maintenance...
Old 08-09-2009, 12:20 PM
jac1d jac1d is offline
Cars: '95 540i & '92 525i
+1 on Janders comment.
I had my exhaust unexpectedly disconnect from the header, at the firewall, on my 320i, at highway speeds. Mufflers are good. You'll like the sound for about 15 seconds then no one, including you, will want to drive in your car.
-Jeff
Buying an E34? Make sure you do a Pre-Purchase Inspection (PPI)!
My 10 page E34 customized PPI: http://forums.bimmerforums.com/forum...hlight=E34+PPI
"If you don't go after what you want, you'll never have it. If you don't ask, the answer is always no. If you don't step forward, you're always in the same place." -- Nora Roberts, American Author
Old 08-09-2009, 04:22 PM
CG53's Avatar
CG53 CG53 is offline
Bavarian Fanatic
Cars: Simply too many...
I have a decent one from the '91 535i that I'm parting. You're not exactly close, but shipping likely wouldn't be too horrible. Let me take a closer look. Email me at BavarianFanatic at gmail dot com if you're interested or want pics...
Old 08-14-2009, 07:04 PM
Cars: 1989 535i
PMing you.
Took it to the shop today, and the guy said he could not put a sleeve over it because the pipes were semi-flat on the upper side. His shop did not have pipe bending stuff, and said he did not know anyone close that did. He said that it looked like the pipes were very close to rusting through in other areas, and that passing inspection would be very difficult without replacing it with a good condition used or new CENTER SILENCER (18129068595)
Part #1 in this realoem diagram:
http://www.realoem.com/bmw/showparts...71&hg=18&fg=20
The rusted out hole is on the pipe just below the #10 and #11 parts in that diagram.
He said I might be able to rig something up to pass inspection in a few months, but it would be a temporary fix at best. He was saying I could find cement puddy and stuff like that and try to patch it up after clearing away as much rust as possible.
BTW, the pics I took are on some silly little fancy new memory card so I can't get them on my computer via the memory stick port, and can't find the adapter.
I hope you guys have a good idea of the problem. I am thinking I should just try and find a used one that will last a year or two more. Anybody going to the Bear Mountain meet feel like throwing one on their roof and bringing it to me? =p
Old 08-14-2009, 07:12 PM
smash9002 smash9002 is offline
Cars: 89 325i
Send a message via AIM to smash9002
That can be patched.. it just might not be pretty and the shop you were at may not have wanted to mess with it. Find another shop or some one with a welder and bring the exhaust in off the car, it shouldn't even be too expensive. Or take a sawzall and cut out that section and have it replaced. I just did that on my car, the shop did not even charge me it was so quick.
Old 08-14-2009, 07:20 PM
Cars: 1989 535i
The exhaust was already off the car. I showed it to him in the back of our Suburban.
The guy seemed honest, he was a young guy who could tell I was looking for the cheapest way out and was going out of his way to try and help me find the cheapest way of getting in through inspections. He was not trying to sell me the part through his shop.
I have no tools or experience with welding either.
