Results 1 to 13 of 13
Thread: Are you supposed to grease your steering rack?
    ma
    1994 325is
    I dunno this may be a really dumb question im not sure. When doing my tierods it seems like there is grease on the steering rack gear teeth already.
    So am i supposed to put grease on these teeth or not?
    1994 325is - s50/zf trans/TRM chip/s52 headers/21.5lb injctrs/3.5 HFM/M3 brakes/billy sports/hr springs/reinforced subframe/camber plates/adj ctrl arms/3.15 LSD
    2004 Volvo s40 T5 - Daily
    2000 GMC k2500 5.7 - 33's/frame off resto'd
    1989 Chevrolet k2500 5.7 rclb
    Dec 2005
    Berkley, MI
    2000 E39 M5
    I'm sure adding some wouldn't hurt?
    ma
    1994 325is
    i thought there was ps fluid inside the rack where the steering gears are thats why im asking, it seems like mixing grease and ps fluid might be bad.. i dunno.
    Mar 2006
    Ohio
    1994 325is, 2006 A4
    No, the PS fluid just provides the hydraulic boost. The teeth themselves are greased.
    ma
    1994 325is
    ahh i see, what the heck is the purpose of those two lines that run along the back of the rack then?
    so there is no harm at all in greasing those teeth. would it hurt to throw a little grease on the piston itself on both sides?
    Mar 2006
    Ohio
    1994 325is, 2006 A4
    Sorry, I don't know how to answer your question about the lines. I suppose there is no harm in greasing the teeth, but I don't think it's worth putting grease anywhere the factory didn't put it. Seeing as I don't know what kind of grease is used in that application, I don't really know what to recommend. One thing to consider: All the grease the factory used is still in the rack. Why not just re-distribute it and forget about it?
    Leesburg, VA
    98 M3 01 330Ci 98 318ti
    There's no need to add any grease to your rack teeth. I would really recommend against it since I doubt you have the proper lubricant at hand and you don't want to use the wrong kind of grease and possibly ruin the rack seals. Just replace the tie rods and reinstall the boots keeping everything nice and clean and you'll be fine.
    Nice avatar Chris! Booyaa!
    Socal
    Euro 81 628csi. 02 325i
    Here is when i did my Tie Rod DIY. No prob so far. All purpose grease.
    OLD Grease
    NEW Grease
    ma
    1994 325is
    thanks for those pics man, yeah i basically did the same thing... then i double took and was like was i supposed to do that... hahah
    how long has your rack been running like that?
    Mar 2006
    Ohio
    1994 325is, 2006 A4
    Quote Originally Posted by Tronix View Post
    Like my line says, Bruce: I'm fixin to try this at home!
    Spanish Fort, Alabama
    94 325 DMOD, 99 M3,
    Those lines equalize pressure in the boots as they move back and forth
    325i #97 DM
    ma
    1994 325is
    really? nothing besides air goes through them? hah
    Bay Area, California
    Searching...
    Quote Originally Posted by catalyst. View Post
    I believe he means the ATF pressure in this case, not air pressure. BMW's steering rack is self-bleeding, I do not believe air is a desirable substance to have in your rack.
    "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." - Hunter S. Thompson
    Suspension Overhaul FAQ
