I already miss my stick shift knob, not accustomed to the new shape of mine.
FINALLY got the car to my house. I had it towed, because I was too lazy to re-install the exhaust in the lot at the shop and I could not work out a time with the shop owner to use the lift.
I also have a ton of parts and maintainance bits to install. I got brake pads (still need rotors), spark plugs, oil/filter, new battery (old one was toast after sitting), and a stock is spoiler (black). I need to clean it- badly!
Pics, after a quick rinse and wipe-down:
Looks promising...knowing what you do with cars...this one is going to be something worth talking about shortly.
BMWCCA #389756
e39 Touring SOLD.
Thread that I started over on R3V about a stroker build SPECIFICALLY on an S-eta:
http://www.r3vlimited.com/board/showthread.php?p=1687690#post1687690
Any help or input is appreciated!
My parasitic drain thread:
http://forums.bimmerforums.com/forum....php?t=1313809
Nice pick up for sure. Im new here but on R3v a lot and e30tech. Just had a nice pick up myself, but ....not jumpin your thread...
Congrats and get to modding
Took her for a drive today in my neighborhood. I re-installed the midsection of the exhaust (took no time with a helper to align the front) and drove it in my neighborhood. This was the first time that I had actually driven it anywhere other than a parking lot.
Impressions are good. Throttle response was pretty good and the idle smoothed out after I had driven it for a few minutes.
There is a squeak from one of the wheel bearings (front, I think) and a weird odd thunk or thump coming from an unidentified area in the engine bay. It is only audible at idle, and is only audible- not evident by feel.
I think it may be related to the timing belt. I did not want to run it for too long with the sound. I am afraid to let it run, but I can't diagnose it with the motor off. I am kinda stuck...
I know I am not giving much to go on there, but...Thoughts?
If you turn it into an autocrosser, are you going to leave the sunroof in?
Update: Already needing a timing belt, I decided that since the car won't be on the street or track until spring, I might as well build this right. I have located an "i" donor car and am getting everything that I can from it to do ao budget stroker build using the S-eta bottom end and pistons and the complete head, TB, IM, 173, cluster, alternator, radiator, etc. from the donor car. I also found a few other nice random parts on the donor (sail panel tweeters, vert FSB). I am basically taking everything forward and on top of the head.
I might need a few things off of the car that I am forgetting, but I can always get them later. Aything from my thread on R3V that stands out that I need to grab?
For now, probably. If I get more serious, I will either weld it shut or look for a slicktop and start fresh or swap in parts.
Sourced the majority of my top end rebuild parts today. I grabbed everything from the head on up and forward:
325i 153 DME/ECU
325i head, including:
325i inner valve springs
325i cam
325i intake manifold
325i throttle body
325i throttle position switch (should be in there somewhere)
325i intake bellows
325i air flow meter
325i 3.0 fuel pressure regulator (Should be in there somewhere)
325i vacuum line from brake booster, to bellows, and to throttle body
325i Gauge Cluster (still have to go back to pick it up)
325i Alternator
325i radiator
325i airbox
A lot of other random stuff- hoses, lines, what looks like a full motronic 1.1/1.3 harness, coolant tank, plug wire set...
The also threw in a vert front sway bar (endlink to endlink) and A-pillar tweeters. I am trying to get them to give me a spart i muffler that was cut behind the mounting flange.
Pics:
Swapped in a passenger sport seat to the driver's side, just for now. I aso have the driver's side frame and will work on swapping the controls to the proper side, but I don't need much in the way of adjustments. I have it where I want it, which is good enough for now.
Height comparison:
Also grabbed a shifter assembly from a Z3 M to tighten up my sloppy stock shifter.
looks like progress.. carefully check those hoses for nicks though. new hoses arn't that expensive.
'91 SpecE30 #523
'12 F30 328i Sport Line
'00 F-350 Dually
BMWCCA #360858 NASA # 128290
https://www.facebook.com/COTABBR
Nice work Pat...she's coming along...
BMWCCA #389756
e39 Touring SOLD.
I plan to replace all of those hoses, rather than re-using them, but they included them when I got the head at the JY.
Thank you. I am worried that the head swap will have me in over my head. Bolt-ons are one thing, but doing the top end swap is a new challenge for me.
Given that I have to do the timing belt anyway, I figured that over-my-head was inevitable.
head swap is cake difficulty wise, its just a pita. removing heat tightened and hard to reach exhaust manifold bolts are a b****. i've had to do it twice this year due to broken rockers and hope i dont have to do another for a looong time!
'91 SpecE30 #523
'00 F-350 Dually
'91 SpecE30 #523
'00 F-350 Dually
Knock on wood, but the ones on my existing 325 came right off. Hopefully, the ones on the to-be-swapped head will as well.
More JY parts...
Eclipse 5.25s sourced from a clunkered Cherokee, E?? leather e-brake handle and boot, and a "spare" Motronic DME (this one a 380, since my "build package" did not come with a 173, like we thought) for my build. They let me keep the 153 as a spare.
For my reference:
http://forums.bimmerforums.com/forum....php?t=1200334
Have fun! It's always an adventure when playing with the M20
I'm toying with the idea of forced induction myself. BTW Where'd that bronzit paint on the tires come from?? ..........
Shut the $%&*nig hood and drive it!
1. 85' EtaCoupe - Sold
2. 86' EtaSedan - Swapped m20b25 - Sold
3. 89' 325i Sedan- Sold
4. 90' 325i Sedan- Sold
5. 90' Cabrio - Tree'd
6. 88' sedan - M50 swapped DD
Another reference thread:
Caliper Rebuild: http://forums.bimmerforums.com/forum...6852&highlight
Also, bought some H&R springs to get started on the suspension rebuild.
Bought some Brembo and PBR rotors (from magnetic1- GREAT vendor!) and have Mintex pads for the street.
Found some light 15s for track wheels, and awaiting paypal payment info to pay for them. Probably going with Falken Azenis RT-615s in 205/50/15 for tires.
