Results 1 to 18 of 18
Thread: 1998 BMW 528i Wiper Does Not Shut OFF!!!
    California
    98' BMW 528i
    So...i've this car for a while. It does not have rain sensor, so there is no "auto" switching my wipers.
    Just recently, wipers start whenever i turn my engine on, and never turns off, even when it is in OFF position. It swivels every 10/15 sec or so.
    I am so frustrated, before anybody post a message "do some search". I've done the research, and according to that i tried to change WIPER RELAY MODULE. However the problem still persists.
    I want to try to repair this problem on my own, since the dealer ship charges like $175 just to check what can be the problem...what a rippp off i must say...
    Please guys shed some light on my situation and if you have any idea to repair it.
    Canton
    85 M635,85 535i,01 DINAN
    Probably a fried relay in the E-Box. Updated relays are available from the dealer. If you have access to a GT1, inputs from the switch can be checked to ensure the switch is working correctly, but my money is on the relay....
    My fleet:
    85 535iM Cinnabar, 85 M635 Cinnabar, 93 325iA Bronzit, 97 318i Silver, 99 540i 6-spd Scwartz
    Omaha, NE
    1998 528i 5-spd 102K
    Remove the passenger side Cabin Air Filter/Box.
    Underneath is the Fusebox.
    Look for a Tan (Salmon) color Relay.
    Best to to activate wipers, then remove the relay. If this shuts down the wiper, then it is the correct relay.
    Go to local dealer and get a new relay for $20.
    California
    98' BMW 528i
    Guys,
    I've tried to exchange the RELAY and still it does not work as mentioned in original post.
    Thanks!!
    Anybody have any suggestions...please i dont want to spend big bucks at the stealership
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Have you done anything (checked, replaced, etc) the wiper stalk? If changing the relay does nothing...perhaps it's because a signal is being sent that the wipers have been requested to operate...and that would come from the stalk on the steering column.
    Just a thought.
    Omaha, NE
    Quote Originally Posted by gameover View Post
    Guys,
    Thanks!!
    Did the wiper stop when you remove the relay?
    California
    98' BMW 528i
    Quote Originally Posted by cnn View Post
    Yes, the wiper did stop when i remove the relay. As matter of fact, i am driving w/ out the wiper relay (its so annoying when you are driving and wiper is on all the time)
    ganesht's Avatar
    ganesht is offline (oOO)\(lll)°(lll)/(OOo) BMW CCA Member
    Sep 2008
    san diego, ca
    98 528i 5 speed
    does the knurled wheel potentiometer on the stock work? ie if you move the knob does it go faster or slower?
    you could either have a bad wiper stalk, or a bad gm..
    if you have a volt meter you can check pins 2 and 4 on x295 they should both read 0 volts
    if the stock is bad, for your case you should see voltage on pin 4 but not pin 2
    it might be easier to access the wires at the gm:
    pins 4 and 5 at x332:
    this is behind the glove box
    here a bad stalk would have voltage on pin5 but not pin 4
    Alida:
    Born: Friday, 9th January 1998
    Arktissilber Metallic on Schwarz 528i/5
    Claudia:
    Born: Friday, 2nd May 2003
    Sterlinggrau Metallic on Schwarz 540i/6
    California
    98' BMW 528i
    When the relay was inside, the "potentiometer" did work!!
    As for the voltmeter issue, i think i might have to go buy one. Do you DIY to take apart the stering wheel or something like that so that i can take the reading.
    Or do you have DIY for the process to check the voltage that you have mentioned (it looks tough) but feels like its not...right
    California
    98' BMW 528i
    bump!!
    ganesht's Avatar
    Sep 2008
    san diego, ca
    98 528i 5 speed
    sorry man, hmm i tried searching both forums because i swear i remember someone showing the steps to removing the glove box to get to the gm, but i cna't find it now.. anyhow your best be would be to find yourself a copy of the e39 Bentley manual, there are used ones on ebay all the time.. will show you exactly how to remove/inspect/replace almost everything in your car.
    Alida:
    Claudia:
    California
    98' BMW 528i
    it has been long time......
    So it started raining yesterday and it was so hazardous for me driving w/out my wipers working.....i want to get this fixed ASAP.
    The problem is: the wipers does not shut off
    Possible Sol'n and Suggestions I've Tried:
    1. Changed the wiper module relay with the new one from dealer - Still Problem Presists
    2. Changed the speed of the wiper to see if potentiometer works - IT DOES WORK; wiper is able to change speed!!
    Anybody have any other suggestions before i go to the dealer as a final step. I really do not want to spend $175 just for the diagnostic. I am afraid that they would just try to rip me off and plus not knowing what the exact problem is and going thru trial and error method to see what can be the problem and charging me for it for each trial and error steps they take like changing relay, changing switch, etc....
    If some1 out there is expert on this electrician stuff for BMW, who lives in Bay Area and would like to help me out solve this, please let me know how i can contact you. I do not mind paying if the problem can be solved. Feel like i can trust the forum members much more than the dealers...lol
    Omaha, NE
    Find a good friend with the same car and swap a wiper stalk.
    PANAMA
    530i 11/00
    maybe the windshield rain sensor is bad
    just a thought
    96 318is Sport --sold
    96 528ia Premium Comfort seats --sold
    98 528ia euro sport pack BR41880-- sold
    01 530ia Premium CE52247
    02 540ia Individual GG91507
    California
    98' BMW 528i
    What is a wiper stalk? Can i get that from a dealer ship?
    I do not have windshield rain sensor. I have 98 BMW 528i!
    PANAMA
    530i 11/00
    oh sorry i have it and i have a 98 528ia
    Omaha, NE
    Dec 2009
    melbourne, Victorian, Australia
    1998 BMW 528
    hi guys
    does any have a broken down diagram of removed wiper motor
    on 528i
