Well the car is almost done, We put the piping on and ran the car, man that turbo sounds AWSOME!!!!, we couldnt run it all the way cause we have to work on the advance, since it works with vacumn, we have to fix that, my dad took the car out on the street to see what it can do and he says it would have taken off if he had pushed it more but felt that the motor was holding back about of the advance, like i said couldnt run it all the way. It really sound great, all I need to do is get my BOV (sold the blitz and got a greddy type S) and need to be the piping make ( we made the mold out of PVC). all in all it is coming together great and the turbo should be done shortly. JUst thought I would let you guys know.
P.S it now spins the tires down low and didnt B4
wicked... waiting in antisipation
awesome, where the burnout vids? hehehe j/k
yeah, i wondering how the callaway kits took care of the vacuum advance.
oh yeah, i was browsing on racetep.com and found that they sell high flow (+5%) injectors for the 320i.....here's the link http://racetep.com/2002pl0902.htm it's almost at the bottom of the webpage under the bold type: Fuel Injection and D.I.S. ignition
killer .. eagerly awaiting a turn in shotgun..
*Shotgun first ride before B'fest*
-- Matthew
Attila, how much does your e21 wiegh?
: Oh yea I found these on some website a while back, they gave us mad props, it was from a group of e30's, looks like a really crappy camara though...
Thats awsome, Im not sure how much my car wieghts, do you know what the stock wieght is? It is lightened a bit but with the turbo I think it evens out..The seat are lighter, A/C comp. is off, no spare tire or jack. That camara is a good one I took that pic and I didnt focus it that well.
you took that! Did you post that somewhere? I wonder how I stumbled upon this... Stock with a full tank is 2590lbs, I minused everything you took out as well but that system in the back weighs a TON!!!
Length . 177.5
Width . . .63.4
Height ....52.3
Wheelbase .. ..100.9
Front Track .. .....54.48
Rear Track . .. 55.07
Min. Turning Circle Diameter (wheels) . ..........30.82ft
Min. Turning Circle Diameter (overall) ......................33.44ft
Vehicle Weight (full tank) .................................2590l b
Permitted Front Axle Load ........................ ..1730lb
Permitted Rear Axle Load ..... ..1840lb
Max. Permitted Gross Weight ........3530lb
Then my car is about that, I had a bigger battery to thats in back so I have a better wieght distribution. I also installed a water spray on the intercooler, you know those round oil things that you see at pepboys, well I'm going to put one of those were the spare tire was and it will get water from there. We are going to put in a pump and everything. Sadly I will no longer have a system in the car just a radio and 4 speakers,no more subs .
your crazy, my setup wont proly even have an intercooler, management of anykind, let alone spray, but perhaps some go juice
think those high flow injectors are worth it? I'm about to rebuild my head for my new engine, and if it'd be a worthy investment i might consider it. But I'm not gunna be running more than 10 psi boost
at 10 psi you won't need them. The fuel distributor will likely become your first bottle neck.
Blitz, what did you have, chrome 20s on that thing back in the day
They were 17's. I was young, new nothing of the E21, never heard of forums, and didnt know much about "period correct". Those lasted all but 6 months untill I heard about forums and quickly understood that those were not what should have been on the car.
