This post is a conglomeration of the thread on e30tech. Most of the important information has been taken and put here.
[/quote]
1 5/8 304 .065 wall
4 into one merge collector (true merge, made by the same guy that does Porsche motorsport headers)
2 inch bend into t3 gasketless 3d machined transition 304 flange.
Porsche 930 turbo wastegate.
back pressure port (-4)
3 inch downpipe, with 2 o2's (1 for dyno ETAS, and 1 for NGK AFX)
Engine has a Schrick 304 with Schrick valve springs, ti retainers, m3 crank, m3 rods
63mm throttle body.
Continued:
Freaking real time updates BRAH!
People that know it all, cant do it all. (quoting Otis)
Meh, thermal coatings FTL.
BLuuuurrrr.
Well today it made 365 hp and 330 something torque.
Im switching to a new turbo, with a larger exhaust housing (the one on there has some major FOD on the exhaust wheel)
Better glow picture.
This thing sounds like a fucking raped ape.
I dont have the equipment to take a proper video at this time. Tchao has the right stuff.
These are all cell phone pictures.
Its a scavenge pump for the turbo, driven off of the power steering pump with a little belt. It seems to be working fine, and i believe it sucks air most of the time (which it should)
Pics of scavenge.
Lets not throw around wheel numbers just yet. Remember, I only have an engine dyno. Absolutely no % loss numbers in here until i get it on a wheel dyno.
This thread is my offical m10 build/ tune thread. This backpressure stuff is perfect! I did see a TREMENDOUS gain in power when I switched to the .63. It holds 1psi less back pressure (im not 100% positive, because right now im looking at a mechanical gauge, not logged) EXEPT at the torque peak, which i think it drops off even more. (less back pressure)
I *may* try a .82 housing (largest I can get with my footprint) and see what that does. I have the Garrett speed sensor, and I will be installing it. With that I can see exactly what cfm and boost I am at. Therefore I can continue to tailor the turbo to what I want*.
*What I want may vary from what you may want
This motor is hardly "high horsepower"
Garrett....check
Wiggins......Check
Proper manifold......Check
Proper ECU.....Check
M10.....Check
Having a motor that has burned over 15 gallons of pump gas and all it has done is heat up water......
Priceless.
420hp/ 380tq at 18 psi on pump gas.
ECU/Harness 3.5k?
M10 longblock $650
S14 crank $250
S14 rods $250
Mahle motorsport pistons $200
bearings, seals $250
Turbo manifold (500 in material, labor very expensive)
Turbo...too good of a deal to list
Intercooler, on the dyno it is a mitsu evo8. In the car may be a Garrett tube and fin.
Misc custom machined parts 1-2k
The pump thingamajigger. $300
other misc costs, $800
~ $8000 over a span of 2-3 years.
Maybe. Its scary seeing an m10 ripping through the high rpm's.
My intercooler may be limiting me.
This weekend I pulled the timing chain cover off of my old engine to blast a hole through it for the bigger crank seal, and to machine the water pump area to accept an M3 water pump.
Ok guys, UPDATE.
Im selling my engine harness (hopefully, if not o-well) to an e30 m3 guy.
I am making a new harness for the EURO4, which does sequential staged injection, sequential spark, traction control, drive by wire, launch control, anti lag, and a bunch of other stuff.
I received my Schrick rocker arms today. At 200 euros a pop, im sure there arent many of these floating around. They are beautiful. Expect a photoshoot with the rockers.
This was all concieved when I broke the intake and exhaust rocker on cyl 2 at the drag strip. The fastest I ran was 13.3 at 117mph (not at full boost!)
Then I will be re-tuning it for the new managment and upping the power a little bit. Maybe 225/liter just to bust ben and dan's crank claim.
That is a comparison between stock, schrick, Porsche stock, and Porsche RSR/962 rockers
I got the bill today and they were $200 usd each. I though i got quoted 200 euro each. Inkk quoted $3200 in aus dollars.
Then Jon tries to come in and start more shit. Take a chill pill bro.
show'em how it's done Mitch!
I like how you were ragging on Jon using stainless steel lines with synthetic rubber on his car, and all you can see hanging off your bypass valve piping is a bunch of poorly cut radiator hoses.
Way to use the best there...
Start of Project_20_Days
I have 20 days to get my car running/reliable with the m10 turbo for my trip to bimmerfest.
$3000 to spend.
Original m20 motor is being removed from the car this weekend.
Exhaust/ intake piping /muffler is being ordered tomorrow.
E36m3 rad/ e30m3 expansion tank/cooling accesories ordered
Wiring harness is in production right now, should be complete next wed.
This weekend m10 turbo will be test fit with gearbox to check for clearance, and finalize wiring harness measurements/ fab exhaust/ fab intercooler piping/fab intake/fab cooling hoses/ fab fuh raze shifter.
Aim dash is being ordered tomorrow as well.
I think its possible, I have ~120~ hours availible to work on it.
[quote=biodose;828498]An Aim dash is a data aquisition/ digital display.
I am using this:
http://aim-sportline.com/pages/car/section_car_evo4.htm
Coupled with a special version of this:
http://aim-sportline.com/pages/car/s...r_mychron3.htm
It replaces the factory gauges and logs data and displays it with warning indicators and shift lights.
Ill see you there.
Oh, and im already 2 days into it.
So now i have 18 days.....
Thats a long drive for you. Double check everything!
There is no suspension/brakes/or wheels done. They will be completed after bimmerfest.
Plus i just want to go fast(for now), and im sick of this sbox m20.
Are there zr rated 205/60/14's? I think its a straight line to kalifornia.
Tchao, all we have to do this weekend is pull the m20, install and fit m10 and work on intercooler piping.
Clutch discs are on thier way. Im switching to a full organic ZF Sachs Race Engineering disc(x2) It should make the engagement a little less on off, so i can actually drive the thing in stop-and-go situations.
Should hold 500ft lbs.
My discount on the discs rivals that of a full sponsored race team.
Borla 40575 ordered.
http://www.borla.com/products/product_multi_detail.aspx?cat=5&type=76&desc=XR-1%26reg%3b+Racing+Exhaust|XR-1%26reg%3b+Multi-core+Racing+Mufflers
e36 m3 radiator received, along with e30m3 expansion tank and other cooling bits.
Aim dash being ordered now/along with the setup of our dealer account. Look for a group buy in the future.
Sub $1500.
That is an incredible deal when you know what you get.
3 axis accellerometer
GPS logging
Track mapping
All ecu channels
5 anolouge inputs
lots more....
Uhh ok, progress pics in a second.....
Thats the kind of encouragement I need!
My wallet is already feeling it.....
$500 gone, another $400 on monday + $1300 on the aim system......
This E30 came with an m20b25.
My first car was a henna early model 318i...this was when I knew nothing about e30's, but had the resources to turbocharge anything. This was 3 years ago....
So I bought an m10, and assembled it for boost, and its first start was on new years 09.
Then Bimmerfest comes along and i want to go, but the henna is nowhere near to being complete, no emmisions test, no time to get it through emmisions etc...
So i putting it in my daily driver. alpinewhite 89 325i
Imagine the couch is my budget. Purchased AIM dash today
Thanks for the kind words elbob. You better be coming to Bfest.
Mitsubishi Evolution 9 intercooler works well in a pinch. Im still honing my aluminum welding skills.
Just a little done today, lots of time moving the intercooler inlet and outlet.
I would have to run some sort of electric AC compressor or remove/relocate power steering to get AC again.
Im building a 3.73 lsd for the trip. The m10 is mated to a 265 gearbox out of an m3.
Thanks, I wouldnt mind you being here helping!
BTW, pm sent, i have a non e30 q...
New clutch dics compared to old discs, with flywheel and cover.
More IC routing.
AANND
Aim Dash. It is a MyChron3 with an EVO4 logger.
A 8.5x11 sheet of paper for size reference.
Thanks dude.
No this is the dash underneath the flagship MXL dash. This one can do everything that the MXL Pista can do, for cheaper.
Thanks!
This flywheel/clutch setup would work in an m20. It uses an m20 starter
Mychron over MXL....Well, this dash with the EVO4 can do everything that the mxl can do for less money. I dont have $2500 for an MXL Pista, GPS addon, and memory key. The EVO4 and MC3 combo costs $1400, and has a tri axis accelerometer, and GPS logging built in.
Absolutely. If you want one PM me.
Mtech2 wheel, aluminum/plastic/possibly OEM evo3 knob. Evo3 knob is currently installed. ICE cosists of 2 factory prem-o sound front speakers and a CD player head unit.
Thanks!
$1400 retail. That is compared to the $2500 you would spend on an MXL to get the same options. There will be a group buy for all aim products soon.
Gotta pay to play!
For one, it will log EVERYTHING from the ECU + the 5 extra analog sensors that I have.
Things like
MAP
Intake Air Temp
Turbo Outlet Temp
Oil pressure
Oil temp
Water Pressure
RPM
Literally everything, along with GPS position, speed long/lat/vert G-force all in a user friendly format for PC viewing afterwards....IE, no bullshiting how fast you went/personal race improvment etc.
Being digital, it takes up less space. Most of the time it ends up being cheaper in the long run.
All of the ECU's sensors are fed through 2 wires, over the CAN bus.
Im a dealer, so PM me for more q's. There is another person in AUS that wants a few(possibly) so that may be an avenue for cheaper shipping.
PS: They also have protocols for connecting to MEGASQUIRT ECU'S!!! (over RS-232)
Exhaust is 87% complete.
.049 wall 3 inch steel. (thats 18 gauge)
This thing is lightweight.
Exhaust complete minus the rear muffler hangars.
MY exhaust weighs 26lbs, the whole thing as it is sitting in the picture.
The factory exhaust weighs in at 64 pounds!!!!
No east new Sweden bullshit turndown here.
Nothing like making some teflon stainless braided -4 lines for wastegate control. This *should* eliminate the hoses popping off and ruining my day.
Hmm not to bad on the Brown and Miller racing solutons hose order..
Damage was $381. $170 of that was just my oil cooler lines!
I got the regulator on ebay for like $30 shipped.
This is a quick+durty30+(cheap) way to get two boost levels, with the high boost user controlled.
A simple solenoid valve, and the regulator and bam, 2 boost levels.
Im really burned out + im waiting on some silicone to do the inercooler plumbing and cooling system. I discovered that wiggins everywhere isnt a good idea, because they dont like vibration (note- i have a buzz happy 4cyl). Smallsnails wiggins on bf.c will probably wear out and become loose/pop off (if it ever runs like it should) I will have a wiggins only on the throttle body, as that is the hardest one to get a good connection to.
Got $400 in oil + fuel lines today....
Nomex braided convoluted teflon with mandrel bent 90*'s + crimped ends.
Raychem DR-25 for the majority and Raychem ATUM 3:1 and 4:1 for sealing the breakouts.
Then the Raychem tefzel wire, i forgot which series. I can look that up if you want.
Tilton Hydraulic release bearing, and fuel pressure sensor, and general engine shot.
There is a small issue with the pulsation. Im monitioring fuel pressure to detect pump failure/ not enough capacity.
Some more progress... Tuesday is the deadline.
Project is 99% complete, (as all car projects are never finished)
Goal is 100% accomplished.
There ya go, all progress condensed into a neat, non 56k friendly thread.
I started a project like this in 2003 when I bought my first 2002.
I gave up in 2004 when I realized how much better modern motors are.
Nice work making the most out of the old tech.
No PMs. Email through forum please.
Looks just like a Bosch bypass valve.
No idea why you'd be routing that up to the head if you wanted to do it "right," but I guess Germans do like to route coolant all over the damn place for no reason.
What kind of quick disconnects are those? If those are even QDs... your pics are all out of focus.
Those rockers look like sweet pieces
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
thanks for telling me, i would have come up there and helped spin a wrench or 2 or do some welding for ya..........
looks good mitch
Becoming a Professional OT Troll . CAN Bus Project: http://www.youtube.com/watch?v=2QuRBQzGs-c VGT/VNT +LDA controller: http://dmn.kuulalaakeri.org/vnt-lda/
Originally Posted by [B]SilverBeam[/B]Diesel > gasOriginally Posted by sparkchaser
I'm lost...WTF is going on here?
I'm a lil tea cup with teh hickup!?!? Lol
Turbo E30s. The New Supercars.
Originally Posted by mazur
I think brett posted that under your name at bfest.
In case you were wondering, the thermostat didnt work with the m3 radiator and I ran with no thermostat to bimmerfest. I now have an m3 thermostat that should work a little bit better.
That hose that goes to the top of the motor is the bypass pipe, for when the thermostat is closed. The thermostat regulates the inlet, when the motor gets hot it sucks in cold water.
It was designed in the late sixties.
Whats the point of the wiggins clamp with the 3 feet of silicone tubing right before?
Nice job Mitch
It was just a simple question. Im not trying to say you are doing it wrong. Calm down.
So apparently there is clearance issues.
Thanks for answering.
