Well Carmen's V7 Ysi aftercooler is all done and I have started work on a new project the M62/S62 intake manifold for some of my special treatment.
The intercooler will run 6 x 392mm 150hp Laminova cores, so all up good for up to 900HP of air flow, as for cooling abilities you will need to watch this space patiently
The starting point.
It will replace the stock intake and bolt straight on, well that's the plan
This one will be under wraps for a while but I'm on it
Sounds interesting
Looks like interesting project. Looking forward to the progress with pictures and all!
Hi Matt...
Good stuff. Fresh off the last badass project to the next.
how much would a block of aluminum like that cost?
Luke
03 330i
Matt, I look forward to your AWESOME work!
I think the RMS one is juts a plenum? I don't see how it could fit cores too.
Sick! What do the insides look like?
This one will suit the single throttle body for now rather than the individual set up and will be a straight swap for the original intake, pictured in the first post.
So the new intake is that for boosted aplications only , or its N/A too?
i got these parts for sale
front corner light for a 4 door E36 $20plus shipping
headlight eyebrows $20 plud shpping
M3 OEM radiator $100 plus shipping
M52 cams with trays high miles $150 shipped
M3 front calipers $150 plus shipping
18x8 offsed 35, front 18x10 offset 40 rear bsa motorsports wheels $400 plus shipping
obd2 valve covers $50 plus shipping
intake manifolds $50 plus shipping
estoril blue doors of a 96 M3 2door $200 plus shipping each
rear glass $50 plus shipping
rear trunk lid $150 plus shipping
new 1/4 is 800 ft away ))
Boost only.
Has anyone ever tested an RMS unit as to pre and post TEMP and MAP to see how efficient they are.
All our units are tested and data you will find here http://forums.bimmerforums.com/forum....php?t=1238269
Very good point. In fact a single TB is preferred in this application. But the runners are intakes and not TB runners (you knew that).
Yes, RMS has N/A stage 1and boosted stage 1 and 2. Sorry for OT as this is your thread, thanks again for BMW V8 love.
Here's a peek so far.
Now for the intake rails and runner from the housing to the runners
The intake currently is equal to 2.85" I may play with this a little more to achieve the ideal 3" which it was originally. But lost a little to allow for the bolt holes and factory gasket at the top and bottom.
Popped in to BMW @ Doncaster here in Melbourne today and picked up two new genuine gaskets to check against the machining once completed.
Question time
The back of the plenum has and orange rubber with a hole in it (see pic below), purpose?
Also two smaller outlets with yellow around them one is used and looks like a vacuum line would fit the other has a factory blank.
Coulpe of views of a segment of the intake close up where the injector will sit.
appears to be part of vacuum control system per realoem...
edit: btw, very impressive work. this will be very fun to watch unfold. wondering how much time you anticipate designing, building and testing this takes.
Some pics to help maybe.
