Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 8 Series (E31)
8 Series (E31) (1991 - 1997) As the last E24 rolled off the production line in 1989, its replacement was quick on its heels to fulfill the fantasies of those looking for a touring coupe with all of the luxury, performance, and prestige of a BMW, only now with both 8 and 12 cylinder engines.
Old 08-25-2003, 10:22 PM
AKkid918 AKkid918 is offline
New Member
Cars: 1991 850i
Engine overheating
i just pulled my 850i out of storage after three months. It seems to be running fine except that the engine overheats at idle or low speeds. Heat goes back down when i hit the highway. Anyone else have this problem or have any suggestions? Anyone know where i can get a good 8-series repair manual?
Old 08-25-2003, 10:26 PM
quickslvr387 quickslvr387 is offline
Cars: 92 325is
probably your fan if it cools down after you get going
Signature Disabled - Check the Signature Rules... Fix your signature FIRST!
Afterwards post in the signature/avatar request thread in the forum suggestions forum.
Old 08-25-2003, 11:12 PM
TerryY's Avatar
TerryY TerryY is offline
Cars: '95 840Ci, '98 SVT Cobra, '00 Range Rover Vitesse
Bleed the coolant system several times. Run it a bit between bleeds.
It shouldn't over heat at idle if the fan spins at all.
Don't let it run hot !! Headgaskets can go away!!
Also check for coolant in the oil before you start.
Terry
'95 840Ci Arctic Silver
'98 SVT Cobra Mustang Convertible
www.wuffer.net
www.8coupe.com
www.8er.org
Old 08-25-2003, 11:26 PM
TerryY's Avatar
The Bentley for the e32 7 series (89 thru 94) is as close as you can get. A lot of common ground between e31 and e32.
About $84 at Amazon so shop around.
Terry
www.wuffer.net
www.8coupe.com
www.8er.org
Old 08-26-2003, 01:51 PM
ajw45 ajw45 is offline
Cars: E31, e28
Definitely sounds like the fan clutch going..... Also, aside from the radiators tendancy to crack at the top connection, the low riding 8's tend to suck up all sorts of crap that coats the radiator. There was a cool picture on radfly of a guy who still had the outline of a bird on his radiator.....
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
